[PATCH v2] eng: Add register block specification types
Sebastian Huber
Fri Sep 24 13:09:10 UTC 2021
A register block may be used to specify the interface of devices which
use a linear address space. Register blocks consist of register block
members specified by the ``definition`` attribute. Register block
members are either instances of registers specified by the ``registers``
attribute or instances of other register blocks specified by links with
the "register-block-include" link role. Registers consists of bit
fields. The register block members are placed into the address space of
the device relative to the base address of the register block. Register
member offests and the register block size are specified in units of the
address space granule. The address space granule is usually 8-bits also
known as one byte.
Update #3715.
For examples see:
https://git.rtems.org/rtems-central/tree/spec/dev/grlib/if
v2:
Clarify wording and remove the "register-block-type" attribute.
eng/req/items.rst | 322 ++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 322 insertions(+)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index e1b64b6..924e79d 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -103,6 +103,8 @@ The specification item types have the following hierarchy:
* :ref:`SpecTypeInterfaceVariableItemType`
+ * :ref:`SpecTypeRegisterBlockItemType`
* :ref:`SpecTypeRequirementItemType`
* :ref:`SpecTypeFunctionalRequirementItemType`
@@ -1143,6 +1145,8 @@ This type is refined by the following types:
+* :ref:`SpecTypeRegisterBlockItemType`
.. _SpecTypeApplicationConfigurationGroupItemType:
Application Configuration Group Item Type
@@ -1615,6 +1619,68 @@ name
notes
The attribute value shall be an :ref:`SpecTypeInterfaceNotes`.
+.. _SpecTypeRegisterBlockItemType:
+Register Block Item Type
+This type refines the :ref:`SpecTypeInterfaceItemType` through the
+``interface-type`` attribute if the value is ``register-block``. This set of
+attributes specifies a register block. A register block may be used to specify
+the interface of devices which use a linear address space. Register blocks
+consist of register block members specified by the ``definition`` attribute.
+Register block members are either instances of registers specified by the
+``registers`` attribute or instances of other register blocks specified by
+links with the :ref:`SpecTypeRegisterBlockIncludeRole`. Registers consists of
+bit fields (see :ref:`SpecTypeRegisterBitsDefinition`. The register block
+members are placed into the address space of the device relative to the base
+address of the register block. Register member offests and the register block
+size are specified in units of the address space granule. The address space
+granule is usually 8-bits also known as one byte. All explicit attributes shall
+be specified. The explicit attributes for this type are:
+brief
+ The attribute value shall be an :ref:`SpecTypeInterfaceBriefDescription`.
+definition
+ The attribute value shall be a list. Each list element shall be a
+ :ref:`SpecTypeRegisterBlockMemberDefinitionDirective`.
+description
+ The attribute value shall be an :ref:`SpecTypeInterfaceDescription`.
+identifier
+ The attribute value shall be an :ref:`SpecTypeInterfaceGroupIdentifier`.
+name
+ The attribute value shall be a string. It shall be the name of the register
+ block.
+notes
+ The attribute value shall be an :ref:`SpecTypeInterfaceNotes`.
+register-block-group
+ interface group defined for the register block. For the group identifier
+ see the ``identifier`` attribute.
+register-block-size
+ The attribute value shall be an integer number. It shall be the size of the
+ register block in units of the address space granule.
+register-prefix
+ The attribute value shall be an optional string. If the value is present,
+ then it will be used to prefix register bit field names, otherwise the
+ value of the ``name`` attribute will be used.
+registers
+ :ref:`SpecTypeRegisterDefinition`.
+In addition to the explicit attributes, generic attributes may be specified.
+Each generic attribute key shall be a :ref:`SpecTypeName`. The attribute value
+may have any type.
.. _SpecTypeRequirementItemType:
Requirement Item Type
@@ -3857,6 +3923,12 @@ This type is used by the following types:
+* :ref:`SpecTypeRegisterBitsDefinition`
+* :ref:`SpecTypeRegisterDefinition`
.. _SpecTypeInterfaceCompoundDefinitionKind:
Interface Compound Definition Kind
@@ -4116,6 +4188,12 @@ This type is used by the following types:
.. _SpecTypeInterfaceEnabledByExpression:
Interface Enabled-By Expression
@@ -4165,6 +4243,10 @@ This type is used by the following types:
* :ref:`SpecTypeInterfaceFunctionDefinitionVariant`
+* :ref:`SpecTypeRegisterBitsDefinitionVariant`
+* :ref:`SpecTypeRegisterBlockMemberDefinitionVariant`
.. _SpecTypeInterfaceEnumDefinitionKind:
Interface Enum Definition Kind
@@ -4306,6 +4388,8 @@ This type is used by the following types:
* :ref:`SpecTypeInterfaceGroupItemType`
.. _SpecTypeInterfaceGroupMembershipLinkRole:
Interface Group Membership Link Role
@@ -4372,6 +4456,8 @@ This type is used by the following types:
.. _SpecTypeInterfaceParameter:
Interface Parameter
@@ -4537,6 +4623,8 @@ This type is refined by the following types:
* :ref:`SpecTypePlacementOrderLinkRole`
+* :ref:`SpecTypeRegisterBlockIncludeRole`
* :ref:`SpecTypeRequirementRefinementLinkRole`
* :ref:`SpecTypeRequirementValidationLinkRole`
@@ -4585,6 +4673,10 @@ This type is used by the following types:
* :ref:`SpecTypeNonFunctionalRequirementItemType`
* :ref:`SpecTypeRootItemType`
@@ -4626,6 +4718,236 @@ value is ``placement-order``. This link role defines the placement order of
items in a container item (for example an interface function in a header file
or a documentation section).
+.. _SpecTypeRegisterBitsDefinition:
+Register Bits Definition
+A value of this type shall be of one of the following variants:
+* The value may be a set of attributes. This set of attributes specifies
+ register bits. All explicit attributes shall be specified. The explicit
+ attributes for this type are:
+ access
+ The attribute value shall be a list of strings. It shall be the list of
+ access attributes.
+ brief
+ description
+ name
+ register bit field.
+ start
+ The attribute value shall be an integer number. It shall be the start bit
+ of the bit field. Bit ``0`` is the least-significant bit.
+ width
+ The attribute value shall be an integer number. It shall be the width in
+ bits of the bit field.
+* There may be no value (null).
+This type is used by the following types:
+* :ref:`SpecTypeRegisterBitsDefinitionDirective`
+.. _SpecTypeRegisterBitsDefinitionDirective:
+Register Bits Definition Directive
+This set of attributes specifies a register bits directive. All explicit
+attributes shall be specified. The explicit attributes for this type are:
+default
+ :ref:`SpecTypeRegisterBitsDefinition`. The default definition will be used
+ if no variant-specific definition is enabled.
+variants
+ :ref:`SpecTypeRegisterBitsDefinitionVariant`.
+.. _SpecTypeRegisterBitsDefinitionVariant:
+Register Bits Definition Variant
+This set of attributes specifies a register bits variant. All explicit
+definition
+ :ref:`SpecTypeRegisterBitsDefinition`. The definition will be used if the
+ expression defined by the ``enabled-by`` attribute evaluates to true. In
+ generated header files, the expression is evaluated by the C preprocessor.
+enabled-by
+ :ref:`SpecTypeInterfaceEnabledByExpression`.
+.. _SpecTypeRegisterBlockIncludeRole:
+Register Block Include Role
+This type refines the :ref:`SpecTypeLink` through the ``role`` attribute if the
+value is ``register-block-include``. It defines the register block include role
+of links. Links of this role are used to build register blocks using other
+register blocks. All explicit attributes shall be specified. The explicit
+attributes for this type are:
+name
+ The attribute value shall be a string. It shall be the unique name to
+ identify the included register block within the item.
+.. _SpecTypeRegisterBlockMemberDefinition:
+Register Block Member Definition
+* The value may be a set of attributes. This set of attributes specifies a
+ register block member definition. All explicit attributes shall be specified.
+ The explicit attributes for this type are:
+ count
+ The attribute value shall be an integer number. It shall be the count of
+ registers of the register block member.
+ name
+ The attribute value shall be a :ref:`SpecTypeRegisterName`.
+* :ref:`SpecTypeRegisterBlockMemberDefinitionDirective`
+.. _SpecTypeRegisterBlockMemberDefinitionDirective:
+Register Block Member Definition Directive
+This set of attributes specifies a register block member definition directive.
+All explicit attributes shall be specified. The explicit attributes for this
+type are:
+default
+ :ref:`SpecTypeRegisterBlockMemberDefinition`. The default definition will
+ be used if no variant-specific definition is enabled.
+offset
+ The attribute value shall be an integer number. It shall be the offset from
+ the register block begin to the register member in units of the address
+ space granule.
+variants
+ :ref:`SpecTypeRegisterBlockMemberDefinitionVariant`.
+.. _SpecTypeRegisterBlockMemberDefinitionVariant:
+Register Block Member Definition Variant
+This set of attributes specifies a register block member definition variant.
+type are:
+definition
+ :ref:`SpecTypeRegisterBlockMemberDefinition`. The definition will be used
+ if the expression defined by the ``enabled-by`` attribute evaluates to
+ true. In generated header files, the expression is evaluated by the C
+ preprocessor.
+enabled-by
+.. _SpecTypeRegisterDefinition:
+Register Definition
+This set of attributes specifies a register. All explicit attributes shall be
+specified. The explicit attributes for this type are:
+bits
+ :ref:`SpecTypeRegisterBitsDefinitionDirective`.
+brief
+description
+name
+ identify the register definition.
+width
+ The attribute value shall be an integer number. It shall be the width of
+ the register in bits.
+may have any type.
+.. _SpecTypeRegisterName:
+Register Name
+The value shall be a string. The name consists either of an identifier, or an
+identifier and an alias. The identifier and alias are separated by a colon
+(``:``). The identifier shall match with the name of a register definition of
+the item (see :ref:`SpecTypeRegisterDefinition`) or the name of a register
+block include of the item (see :ref:`SpecTypeRegisterBlockIncludeRole`). If no
+alias is specified, then the identifier is used for the register block member
+name, otherwise the alias is used. If the register block member names are not
+unique within the item, then a postfix number is appended to the names. The
+number starts with zero for each set of names. The value shall match with the
+regular expression "``^[a-zA-Z_][a-zA-Z0-9_]*(:[a-zA-Z_][a-zA-Z0-9_]*)?$``".
+* :ref:`SpecTypeRegisterBlockMemberDefinition`
.. _SpecTypeRequirementRefinementLinkRole:
Requirement Refinement Link Role
2.31.1
