[PATCH] score: Add Thread_queue_Deadlock_status
Sebastian Huber
Fri Sep 24 18:21:48 UTC 2021
Replace the boolen return value with the new enum
Thread_queue_Deadlock_status. This improves the code readability.
Improve documentation. Shorten function names.
cpukit/include/rtems/score/threadqimpl.h | 50 ++++++++++++++-----
cpukit/score/src/threadchangepriority.c | 4 +-
cpukit/score/src/threadqenqueue.c | 63 ++++++++++++++----------
cpukit/score/src/threadqops.c | 4 +-
4 files changed, 80 insertions(+), 41 deletions(-)
diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
index 22e0c7f069..d4fa8b8316 100644
--- a/cpukit/include/rtems/score/threadqimpl.h
+++ b/cpukit/include/rtems/score/threadqimpl.h
@@ -1339,28 +1339,56 @@ void _Thread_queue_Unblock_proxy(
#endif
- * @brief Acquires the thread queue path in a critical section.
+ * @brief This is a status code to indicate if a deadlock was detected or not.
+typedef enum {
+ * @brief The operation detected a deadlock.
+ THREAD_QUEUE_DEADLOCK_DETECTED,
+ * @brief The operation did not detect a deadlock.
+ THREAD_QUEUE_NO_DEADLOCK
+} Thread_queue_Deadlock_status;
+#if defined(RTEMS_SMP)
+ * @brief Acquires the thread queue path.
- * @param queue The thread queue queue.
- * @param the_thread The thread for the operation.
- * @param queue_context The thread queue context.
+ * The caller must own the thread queue lock.
+ * A acquired thread queue path must be released by calling
+ * _Thread_queue_Path_release() with the same thread queue context.
+ * @param queue is the thread queue queue.
+ * @param the_thread is the thread for the operation.
+ * @param queue_context is the thread queue context.
- * @retval true The operation was successful.
- * @retval false The operation failed.
+ * @retval THREAD_QUEUE_NO_DEADLOCK No deadlock was detected.
+ * @retval THREAD_QUEUE_DEADLOCK_DETECTED A deadlock was detected while
+ * acquiring the thread queue path. The thread queue path must still be
+ * released by _Thread_queue_Path_release() in this case.
-#if defined(RTEMS_SMP)
-bool _Thread_queue_Path_acquire_critical(
+Thread_queue_Deadlock_status _Thread_queue_Path_acquire(
Thread_queue_Queue *queue,
Thread_Control *the_thread,
Thread_queue_Context *queue_context
- * @brief Releases the thread queue path in a critical section.
+ * @brief Releases the thread queue path.
+ * The caller must have acquired the thread queue path with a corresponding
+ * _Thread_queue_Path_acquire().
-void _Thread_queue_Path_release_critical(
+void _Thread_queue_Path_release(
#endif
diff --git a/cpukit/score/src/threadchangepriority.c b/cpukit/score/src/threadchangepriority.c
index 613d0cd7af..bd4fef279b 100644
--- a/cpukit/score/src/threadchangepriority.c
+++ b/cpukit/score/src/threadchangepriority.c
@@ -278,11 +278,11 @@ static void _Thread_Priority_apply(
if ( !_Priority_Actions_is_empty( &queue_context->Priority.Actions ) ) {
- _Thread_queue_Path_acquire_critical( queue, the_thread, queue_context );
+ (void) _Thread_queue_Path_acquire( queue, the_thread, queue_context );
#endif
_Thread_Priority_perform_actions( queue->owner, queue_context );
- _Thread_queue_Path_release_critical( queue_context );
+ _Thread_queue_Path_release( queue_context );
#endif
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 1b8b82eab9..ee5c6fff5e 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -8,10 +8,9 @@
* _Thread_queue_Do_dequeue(), _Thread_queue_Enqueue(),
* _Thread_queue_Enqueue_do_nothing_extra(), _Thread_queue_Enqueue_sticky(),
* _Thread_queue_Extract(), _Thread_queue_Extract_locked(),
- * _Thread_queue_Path_acquire_critical(),
- * _Thread_queue_Path_release_critical(),
+ * _Thread_queue_Path_acquire(), _Thread_queue_Path_release(),
* _Thread_queue_Resume(),_Thread_queue_Surrender(),
- * _Thread_queue_Surrender_sticky().
+ * _Thread_queue_Surrender_no_priority(), _Thread_queue_Surrender_sticky().
@@ -113,7 +112,7 @@ static Thread_queue_Link *_Thread_queue_Link_find(
-static bool _Thread_queue_Link_add(
+static Thread_queue_Deadlock_status _Thread_queue_Link_add(
Thread_queue_Link *link,
Thread_queue_Queue *source,
Thread_queue_Queue *target
@@ -144,7 +143,7 @@ static bool _Thread_queue_Link_add(
if ( recursive_target == source ) {
_ISR_lock_Release( &links->Lock, &lock_context );
- return false;
+ return THREAD_QUEUE_DEADLOCK_DETECTED;
@@ -156,7 +155,7 @@ static bool _Thread_queue_Link_add(
- return true;
+ return THREAD_QUEUE_NO_DEADLOCK;
static void _Thread_queue_Link_remove( Thread_queue_Link *link )
@@ -175,7 +174,7 @@ static void _Thread_queue_Link_remove( Thread_queue_Link *link )
#if !defined(RTEMS_SMP)
static
#endif
@@ -260,7 +259,7 @@ static void _Thread_queue_Path_append_deadlock_thread(
static
#endif
@@ -284,11 +283,11 @@ bool _Thread_queue_Path_acquire_critical(
owner = queue->owner;
if ( owner == NULL ) {
- return true;
if ( owner == the_thread ) {
- return false;
_Chain_Initialize_node(
@@ -311,7 +310,11 @@ bool _Thread_queue_Path_acquire_critical(
link->Lock_context.Wait.queue = target;
if ( target != NULL ) {
- if ( _Thread_queue_Link_add( link, queue, target ) ) {
+ Thread_queue_Deadlock_status deadlock_status;
+ deadlock_status = _Thread_queue_Link_add( link, queue, target );
+ if ( deadlock_status == THREAD_QUEUE_NO_DEADLOCK ) {
_Thread_queue_Gate_add(
&owner->Wait.Lock.Pending_requests,
&link->Lock_context.Wait.Gate
@@ -331,15 +334,15 @@ bool _Thread_queue_Path_acquire_critical(
_Thread_Wait_remove_request_locked( owner, &link->Lock_context );
_Assert( owner->Wait.queue == NULL );
- return true;
} else {
link->Lock_context.Wait.queue = NULL;
_Thread_queue_Path_append_deadlock_thread( owner, queue_context );
- return false;
} else {
- return true;
link = &owner->Wait.Link;
@@ -351,18 +354,18 @@ bool _Thread_queue_Path_acquire_critical(
- return true;
- return false;
queue = owner->Wait.queue;
} while ( queue != NULL );
#endif
- return true;
void _Thread_queue_Enqueue_do_nothing_extra(
@@ -392,8 +395,9 @@ void _Thread_queue_Enqueue(
- Per_CPU_Control *cpu_self;
- bool success;
+ Per_CPU_Control *cpu_self;
+ bool success;
_Assert( queue_context->enqueue_callout != NULL );
@@ -405,8 +409,11 @@ void _Thread_queue_Enqueue(
_Thread_Wait_claim( the_thread, queue );
- if ( !_Thread_queue_Path_acquire_critical( queue, the_thread, queue_context ) ) {
+ deadlock_status =
+ _Thread_queue_Path_acquire( queue, the_thread, queue_context );
+ if ( deadlock_status == THREAD_QUEUE_DEADLOCK_DETECTED ) {
_Thread_Wait_restore_default( the_thread );
_Thread_queue_Queue_release( queue, &queue_context->Lock_context.Lock_context );
_Thread_Wait_tranquilize( the_thread );
@@ -419,7 +426,7 @@ void _Thread_queue_Enqueue(
_Thread_Wait_claim_finalize( the_thread, operations );
( *operations->enqueue )( queue, the_thread, queue_context );
the_thread->Wait.return_code = STATUS_SUCCESSFUL;
_Thread_Wait_flags_set( the_thread, THREAD_QUEUE_INTEND_TO_BLOCK );
@@ -468,14 +475,18 @@ Status_Control _Thread_queue_Enqueue_sticky(
+ deadlock_status =
@@ -487,7 +498,7 @@ Status_Control _Thread_queue_Enqueue_sticky(
diff --git a/cpukit/score/src/threadqops.c b/cpukit/score/src/threadqops.c
index a42876cf09..f09cf77df1 100644
--- a/cpukit/score/src/threadqops.c
+++ b/cpukit/score/src/threadqops.c
@@ -1197,7 +1197,7 @@ static void _Thread_queue_Priority_inherit_extract(
* resolves the deadlock. Thread T1 and T2 can the complete their
* operations.
#endif
_Thread_queue_Queue_extract(
@@ -1210,7 +1210,7 @@ static void _Thread_queue_Priority_inherit_extract(
#endif
2.31.1
