[PATCH v2] score: Add Doxygen group for <sys/lock.h> mutexes
Sebastian Huber
Fri Sep 24 18:27:42 UTC 2021
v2:
Add group description.
cpukit/score/src/mutex.c | 16 +++++++++++++++-
1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
index f7e35093b2..92bd614967 100644
--- a/cpukit/score/src/mutex.c
+++ b/cpukit/score/src/mutex.c
@@ -1,7 +1,7 @@
* @file
- * @ingroup RTEMSScore
+ * @ingroup RTEMSScoreSysLockMutex
* @brief This source file contains the implementation of
* _Mutex_Acquire(), _Mutex_Acquire_timed(), _Mutex_Acquire_timed_ticks(),
@@ -36,6 +36,20 @@
+ * @defgroup RTEMSScoreSysLockMutex System Lock Mutex Handler
+ * @brief This group contains the System Lock Mutex Handler implementation.
+ * The interfaces are defined by Newlib in <sys/lock.h>. The system lock
+ * mutexes are used for Newlib internal locking, the C++ standard library
+ * provided by GCC, the OpenMP support provided by GCC, the self-contained
+ * objects API provided by RTEMS, and the SuperCore internal mutexes such as
+ * the objects allocator lock (see ::API_Mutex_Control).
#define MUTEX_TQ_OPERATIONS &_Thread_queue_Operations_priority_inherit
RTEMS_STATIC_ASSERT(
2.31.1
