[PATCH rtems] bsps/imxrt: Add attribution in file headers
Mon Sep 27 08:24:11 UTC 2021
On 27/9/21 6:17 pm, Christian MAUDERER wrote:
> Hello,
> if I didn't miss a documentation patch regarding this, the topic is still open.
> I delayed it a bit because I didn't had the time back then and I think Chris was
> quite busy too at that time. I hope now is the right time to re-start the
> discussion.
> Am 21.07.21 um 08:58 schrieb Chris Johns:
>> On 21/7/21 3:51 pm, Sebastian Huber wrote:
>>> On 21/07/2021 02:46, Chris Johns wrote:
>>>> I think we need some guidelines. I do not agree with URL links, email
>>>> addresses,
>>>> phone numbers or street addreses appearing in the source. I also think a
>>>> sponsor
>>>> acknowledgement is never updated or changed even if a company changes name.
>>>> What
>>>> I am not sure about is the areas of the source we allow this to happen in, ie
>>>> score ...?
>>> We could add some text here:
>>> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html
>> Yes. I will consider this and post an initial approach we can discuss in detail.
>> Chris
> Chris: I think you already mentioned the most relevant rules in your post above.
> Do you want to create a draft for a documentation patch or should I try to write
> something?
Ah yes please document something. It is on the list but not at the top.
Thanks
