[PATCH rtems-tools v3 1/7] CoverageRanges.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Mon Sep 27 12:49:42 UTC 2021
tester/covoar/CoverageRanges.cc | 13 +++++--------
tester/covoar/CoverageRanges.h | 13 +++++++------
2 files changed, 12 insertions(+), 14 deletions(-)
diff --git a/tester/covoar/CoverageRanges.cc b/tester/covoar/CoverageRanges.cc
index 159c556..cfd58df 100644
--- a/tester/covoar/CoverageRanges.cc
+++ b/tester/covoar/CoverageRanges.cc
@@ -13,7 +13,7 @@ namespace Coverage {
* This member variable tracks a unique index for the ranges_t block.
- uint32_t id_m = 0;
+ uint32_t id_m = 0;
CoverageRanges::CoverageRanges()
@@ -41,14 +41,12 @@ namespace Coverage {
set.push_back(c);
- uint32_t CoverageRanges::getId( uint32_t lowAddress )
+ uint32_t CoverageRanges::getId( uint32_t lowAddress )
- Coverage::CoverageRanges::ranges_t::iterator ritr;
- uint32_t result = 0;
+ Coverage::CoverageRanges::ranges_t::iterator ritr;
+ uint32_t result = 0;
- for (ritr = set.begin() ;
- ritr != set.end() ;
- ritr++ ) {
+ for ( ritr = set.begin() ; ritr != set.end() ; ritr++ ) {
if ( ritr->lowAddress == lowAddress ) {
result = ritr->id;
break;
@@ -57,5 +55,4 @@ namespace Coverage {
return result;
diff --git a/tester/covoar/CoverageRanges.h b/tester/covoar/CoverageRanges.h
index e3b651d..3d77df2 100644
--- a/tester/covoar/CoverageRanges.h
+++ b/tester/covoar/CoverageRanges.h
@@ -42,35 +42,35 @@ namespace Coverage {
* This member contains an identification number for this
* coverage range.
- uint32_t id;
+ uint32_t id;
* This member contains the low address of this coverage
* range.
- uint32_t lowAddress;
+ uint32_t lowAddress;
* This member contains the source line associated with the
* low address for this coverage range.
- std::string lowSourceLine;
+ std::string lowSourceLine;
* This member contains the high address for this coverage range.
- uint32_t highAddress;
+ uint32_t highAddress;
* This member contains the high source line for this coverage range.
- std::string highSourceLine;
+ std::string highSourceLine;
* This member contains an instruction count for this coverage
* address range.
- uint32_t instructionCount;
+ uint32_t instructionCount;
* This member contains the reason that this area was uncovered.
@@ -104,6 +104,7 @@ namespace Coverage {
* @param[in] lowAddressArg specifies the lowest address of the range
* @param[in] highAddressArg specifies the highest address of the range
* @param[in] why specifies the reason that the range was added
+ * @param[in] numInstructions specifies the number of instructions
void add(
1.8.3.1
