[PATCH rtems-tools v3 4/7] TraceReaderLogQEMU.cc: Fix formatting
Ryan Long ryan.long at oarcorp.com
Mon Sep 27 12:49:45 UTC 2021
 tester/covoar/TraceReaderLogQEMU.cc | 15 +++++++--------
 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/tester/covoar/TraceReaderLogQEMU.cc b/tester/covoar/TraceReaderLogQEMU.cc
index d02b555..771f808 100644
--- a/tester/covoar/TraceReaderLogQEMU.cc
+++ b/tester/covoar/TraceReaderLogQEMU.cc
@@ -127,7 +127,7 @@ namespace Trace {
     //  Discard Header section
-    if (! ReadUntilFound( logFile, QEMU_LOG_SECTION_END ) ) {
+    if ( !ReadUntilFound( logFile, QEMU_LOG_SECTION_END ) ) {
       std::cerr << "Unable to locate end of log file header" << std::endl;
       return false;
@@ -135,7 +135,7 @@ namespace Trace {
     //  Find first IN block
-    if (! ReadUntilFound( logFile, QEMU_LOG_IN_KEY )){
+    if ( !ReadUntilFound( logFile, QEMU_LOG_IN_KEY ) ) {
       std::cerr << "Error: Unable to locate first IN: Block in Log file"
                 << std::endl;
       return false;
@@ -150,12 +150,11 @@ namespace Trace {
             >> first.data;
     if ( logFile.fail() ) {
-      std::cerr << "Error Unable to Read Initial First Block"
-                << std::endl;
+      std::cerr << "Error Unable to Read Initial First Block" << std::endl;
       done = true;
-    while (!done) {
+    while ( !done ) {
       last = first;
@@ -167,9 +166,9 @@ namespace Trace {
                 >> last.data;
       } while( !logFile.fail() );
-      nextlogical = objdumpProcessor.getAddressAfter(last.address);
+      nextlogical = objdumpProcessor.getAddressAfter( last.address );
-      if (! ReadUntilFound( logFile, QEMU_LOG_IN_KEY )) {
         done = true;
         nextExecuted = last;
       } else {
@@ -185,7 +184,7 @@ namespace Trace {
       // If the nextlogical was not found we are throwing away
       // the block; otherwise add the block to the trace list.
-      if (nextlogical != 0) {
+      if ( nextlogical != 0 ) {
         TraceList::exitReason_t reason = TraceList::EXIT_REASON_OTHER;
         if ( objdumpProcessor.IsBranch( last.instruction ) ) {
1.8.3.1
