[PATCH] rtems: Adjust parameter names
Wed Sep 29 20:30:22 UTC 2021
On Wed, Sep 29, 2021, 3:24 PM Chris Johns <chrisj at rtems.org> wrote:
> Is it worth mentioning in the commit message the reserved nature of time
> is the
> reason for the change?
Do you mean the method time()?
> Otherwise OK.
> On 30/9/21 12:10 am, Sebastian Huber wrote:
> > Adjust parameter names to match with the declaration.
> > Close #4035.
> >  cpukit/rtems/src/clockgettod.c        | 20 ++++++++++----------
> >  cpukit/rtems/src/clockgettodtimeval.c |  6 +++---
> >  2 files changed, 13 insertions(+), 13 deletions(-)
> > diff --git a/cpukit/rtems/src/clockgettod.c
> b/cpukit/rtems/src/clockgettod.c
> > index 01daa3dc15..fed9057f24 100644
> > --- a/cpukit/rtems/src/clockgettod.c
> > +++ b/cpukit/rtems/src/clockgettod.c
> > @@ -81,7 +81,7 @@ static uint32_t _Year_day_as_month(
> >  rtems_status_code rtems_clock_get_tod(
> > -  rtems_time_of_day  *time_buffer
> > +  rtems_time_of_day  *time_of_day
> >    struct timeval now;
> > @@ -91,7 +91,7 @@ rtems_status_code rtems_clock_get_tod(
> >    uint32_t       year_days;
> >    uint32_t       leap_years;
> > -  if ( !time_buffer )
> > +  if ( !time_of_day )
> >      return RTEMS_INVALID_ADDRESS;
> >    if ( !_TOD_Is_set() )
> > @@ -126,14 +126,14 @@ rtems_status_code rtems_clock_get_tod(
> > -  time_buffer->year   = year;
> > -  time_buffer->month  = _Year_day_as_month( year, &year_days ) + 1;
> > -  time_buffer->day    = year_days + 1;
> > -  time_buffer->hour   = day_secs / RTEMS_SECS_PER_HOUR;
> > -  time_buffer->minute = day_secs % RTEMS_SECS_PER_HOUR;
> > -  time_buffer->second = time_buffer->minute % RTEMS_SECS_PER_MINUTE;
> > -  time_buffer->minute = time_buffer->minute / RTEMS_SECS_PER_MINUTE;
> > -  time_buffer->ticks  = now.tv_usec /
> > +  time_of_day->year   = year;
> > +  time_of_day->month  = _Year_day_as_month( year, &year_days ) + 1;
> > +  time_of_day->day    = year_days + 1;
> > +  time_of_day->hour   = day_secs / RTEMS_SECS_PER_HOUR;
> > +  time_of_day->minute = day_secs % RTEMS_SECS_PER_HOUR;
> > +  time_of_day->second = time_of_day->minute % RTEMS_SECS_PER_MINUTE;
> > +  time_of_day->minute = time_of_day->minute / RTEMS_SECS_PER_MINUTE;
> > +  time_of_day->ticks  = now.tv_usec /
> >      rtems_configuration_get_microseconds_per_tick( );
> >    return RTEMS_SUCCESSFUL;
> > diff --git a/cpukit/rtems/src/clockgettodtimeval.c
> b/cpukit/rtems/src/clockgettodtimeval.c
> > index bf3847afec..a8d89c60a6 100644
> > --- a/cpukit/rtems/src/clockgettodtimeval.c
> > +++ b/cpukit/rtems/src/clockgettodtimeval.c
> > @@ -24,16 +24,16 @@
> >  #include <rtems/score/todimpl.h>
> >  rtems_status_code rtems_clock_get_tod_timeval(
> > -  struct timeval  *time
> > +  struct timeval  *time_of_day
> > -  if ( !time )
> >      return RTEMS_NOT_DEFINED;
> > -  _TOD_Get_timeval( time );
> > +  _TOD_Get_timeval( time_of_day );
> devel mailing list
> devel at rtems.org
