[PATCH] libmisc/untar: Use a larger block size to read and write files
Chris Johns
chrisj at rtems.org
Fri Apr 1 03:16:45 UTC 2022
On 1/4/2022 11:14 am, Joel Sherrill wrote:
> This looks ok. Does it impact any array declaration that I missed? I'm just
> worrying about changes in stack consumption.
Not that I could see. A buffer allocated on the heap is now bigger to hold the
larger data block and that has been adjusted.
I have an application where the JFFS slowed down from 4.11 to 6 and the only
difference I could see was 6 had a lot more, I would say 50%, small blocks being
written to the flash device over 4.11. This change makes using untar on JFFS
much more efficient.
> On Thu, Mar 31, 2022, 6:26 PM <chrisj at rtems.org <mailto:chrisj at rtems.org>> wrote:
> From: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> - A larger block size lets files systems work better. On JFFS
> a 512 byte compressed block means lots of small flash updates
> Closes #4635
> cpukit/libmisc/untar/untar.c | 53 ++++++++++++++++++++++--------------
> 1 file changed, 33 insertions(+), 20 deletions(-)
> diff --git a/cpukit/libmisc/untar/untar.c b/cpukit/libmisc/untar/untar.c
> index 7bc1fff02a..fff737db68 100644
> --- a/cpukit/libmisc/untar/untar.c
> +++ b/cpukit/libmisc/untar/untar.c
> @@ -84,6 +84,14 @@
> #define MAX_NAME_FIELD_SIZE 99
> +#define TAR_BLOCK_SIZE 512
> +#define TAR_BLOCK_SIZE_MASK (TAR_BLOCK_SIZE - 1)
> + * Number of blocks read or written
> +#define TAR_WORK_BLOCKS 16
> static int _rtems_tar_header_checksum(const char *bufr);
> @@ -240,7 +248,8 @@ Untar_ProcessHeader(
> } else if (ctx->linkflag == REGTYPE) {
> rtems_printf(ctx->printer, "untar: file: %s (s:%lu,m:%04lo)\n",
> ctx->file_path, ctx->file_size, ctx->mode);
> - ctx->nblocks = (((ctx->file_size) + 511) & ~511) / 512;
> + ctx->nblocks =
> + (((ctx->file_size) + TAR_BLOCK_SIZE_MASK) & ~TAR_BLOCK_SIZE_MASK) /
> TAR_BLOCK_SIZE;
> } else if (ctx->linkflag == DIRTYPE) {
> rtems_printf(ctx->printer, "untar: dir: %s\n", ctx->file_path);
> r = mkdir(ctx->file_path, ctx->mode);
> @@ -311,14 +320,14 @@ Untar_FromMemory_Print(
> ptr = 0;
> while (true) {
> - if (ptr + 512 > size) {
> + if (ptr + TAR_BLOCK_SIZE > size) {
> retval = UNTAR_SUCCESSFUL;
> break;
> /* Read the header */
> bufr = &tar_ptr[ptr];
> - ptr += 512;
> + ptr += TAR_BLOCK_SIZE;
> retval = Untar_ProcessHeader(&ctx, bufr);
> @@ -329,27 +338,26 @@ Untar_FromMemory_Print(
> if ((fd = open(ctx.file_path,
> O_TRUNC | O_CREAT | O_WRONLY, ctx.mode)) == -1) {
> Print_Error(printer, "open", ctx.file_path);
> - ptr += 512 * ctx.nblocks;
> + ptr += TAR_BLOCK_SIZE * ctx.nblocks;
> } else {
> - unsigned long sizeToGo = ctx.file_size;
> - ssize_t len;
> - ssize_t i;
> - ssize_t n;
> * Read out the data. There are nblocks of data where nblocks is the
> * file_size rounded to the nearest 512-byte boundary.
> - for (i = 0; i < ctx.nblocks; i++) {
> - len = ((sizeToGo < 512L) ? (sizeToGo) : (512L));
> - n = write(fd, &tar_ptr[ptr], len);
> + ssize_t file_size = ctx.file_size;
> + size_t blocks = ctx.nblocks;
> + while (blocks > 0) {
> + size_t blks = blocks > TAR_WORK_BLOCKS ? TAR_WORK_BLOCKS : blocks;
> + ssize_t len = MIN(blks * TAR_BLOCK_SIZE, file_size);
> + ssize_t n = write(fd, &tar_ptr[ptr], len);
> if (n != len) {
> Print_Error(printer, "write", ctx.file_path);
> retval = UNTAR_FAIL;
> break;
> - ptr += 512;
> - sizeToGo -= n;
> + ptr += blks * TAR_BLOCK_SIZE;
> + file_size -= n;
> + blocks -= blks;
> close(fd);
> @@ -419,7 +427,6 @@ Untar_FromFile_Print(
> char *bufr;
> ssize_t n;
> int retval;
> - unsigned long i;
> char buf[UNTAR_FILE_NAME_SIZE];
> Untar_HeaderContext ctx;
> @@ -429,7 +436,7 @@ Untar_FromFile_Print(
> return UNTAR_FAIL;
> - bufr = (char *)malloc(512);
> + bufr = (char *)malloc(TAR_WORK_BLOCKS * TAR_BLOCK_SIZE);
> if (bufr == NULL) {
> close(fd);
> return(UNTAR_FAIL);
> @@ -442,7 +449,7 @@ Untar_FromFile_Print(
> while (1) {
> /* If the header read fails, we just consider it the end of the tarfile. */
> - if ((n = read(fd, bufr, 512)) != 512) {
> + if ((n = read(fd, bufr, TAR_BLOCK_SIZE)) != TAR_BLOCK_SIZE) {
> break;
> @@ -464,10 +471,16 @@ Untar_FromFile_Print(
> break;
> } else {
> - n = read(fd, bufr, 512);
> - n = MIN(n, ctx.file_size - (i * 512UL));
> + size_t bytes = blks * TAR_BLOCK_SIZE;
> + n = read(fd, bufr, bytes);
> + n = MIN(n, file_size);
> (void) write(out_fd, bufr, n);
> + file_size -= n;
> + blocks -= blks;
> close(out_fd);
> 2.24.1
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
