[PATCH 3/8] testsuites/libtests/[a-c]*: Change license to BSD-2
Tue Apr 5 18:51:57 UTC 2022
Updates #3053.
 testsuites/libtests/block01/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block02/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block03/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block04/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block05/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block06/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block07/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block09/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block10/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block11/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block12/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block13/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block14/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block15/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block16/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/block17/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/bspcmdline01/init.c | 25 ++++++++++++++++++++++---
 testsuites/libtests/complex/init.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/cpuuse/init.c       | 25 ++++++++++++++++++++++---
 testsuites/libtests/cpuuse/system.h     | 25 ++++++++++++++++++++++---
 testsuites/libtests/cpuuse/task1.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/cpuuse/task2.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/cpuuse/task3.c      | 25 ++++++++++++++++++++++---
 testsuites/libtests/cpuuse/tswitch.c    | 25 ++++++++++++++++++++++---
 24 files changed, 528 insertions(+), 72 deletions(-)
diff --git a/testsuites/libtests/block01/init.c b/testsuites/libtests/block01/init.c
index 418f31e008..6af83f7655 100644
--- a/testsuites/libtests/block01/init.c
+++ b/testsuites/libtests/block01/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2009, 2018 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/libtests/block02/init.c b/testsuites/libtests/block02/init.c
index 4d62ae3fda..3eb399dff4 100644
--- a/testsuites/libtests/block02/init.c
+++ b/testsuites/libtests/block02/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/libtests/block03/init.c b/testsuites/libtests/block03/init.c
index 1fabd2f274..d4014e784d 100644
--- a/testsuites/libtests/block03/init.c
+++ b/testsuites/libtests/block03/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/libtests/block04/init.c b/testsuites/libtests/block04/init.c
index 28892f6cab..92b7d3af7a 100644
--- a/testsuites/libtests/block04/init.c
+++ b/testsuites/libtests/block04/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/libtests/block05/init.c b/testsuites/libtests/block05/init.c
index a2d1d687c5..9845ec6895 100644
--- a/testsuites/libtests/block05/init.c
+++ b/testsuites/libtests/block05/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/libtests/block06/init.c b/testsuites/libtests/block06/init.c
index 3fa70c05b6..c4da28063d 100644
--- a/testsuites/libtests/block06/init.c
+++ b/testsuites/libtests/block06/init.c
@@ -1,9 +1,28 @@
  * Copyright 2008 Chris Johns (chrisj at rtems.org)
+ * are met:
diff --git a/testsuites/libtests/block07/init.c b/testsuites/libtests/block07/init.c
index 21aab0b00a..93685ad3b2 100644
--- a/testsuites/libtests/block07/init.c
+++ b/testsuites/libtests/block07/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/libtests/block09/init.c b/testsuites/libtests/block09/init.c
index fa07d0775c..6c5dfb6ffd 100644
--- a/testsuites/libtests/block09/init.c
+++ b/testsuites/libtests/block09/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/libtests/block10/init.c b/testsuites/libtests/block10/init.c
index d699968975..3ea1022020 100644
--- a/testsuites/libtests/block10/init.c
+++ b/testsuites/libtests/block10/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2010, 2018 embedded brains GmbH.
+ * are met:
diff --git a/testsuites/libtests/block11/init.c b/testsuites/libtests/block11/init.c
index 77676e5a2b..22ae8e1e5a 100644
--- a/testsuites/libtests/block11/init.c
+++ b/testsuites/libtests/block11/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/block12/init.c b/testsuites/libtests/block12/init.c
index 37bfd3fb6d..7d488a9fe9 100644
--- a/testsuites/libtests/block12/init.c
+++ b/testsuites/libtests/block12/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2012, 2018 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/block13/init.c b/testsuites/libtests/block13/init.c
index 69474b0fa9..9b6f3ed09d 100644
--- a/testsuites/libtests/block13/init.c
+++ b/testsuites/libtests/block13/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/block14/init.c b/testsuites/libtests/block14/init.c
index a293adf0d9..e3fe71e5da 100644
--- a/testsuites/libtests/block14/init.c
+++ b/testsuites/libtests/block14/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/block15/init.c b/testsuites/libtests/block15/init.c
index ed9e6ce5f5..4d8b48fc66 100644
--- a/testsuites/libtests/block15/init.c
+++ b/testsuites/libtests/block15/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/block16/init.c b/testsuites/libtests/block16/init.c
index dc589d40b1..883e1b05ea 100644
--- a/testsuites/libtests/block16/init.c
+++ b/testsuites/libtests/block16/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/block17/init.c b/testsuites/libtests/block17/init.c
index 25727e13c8..cedadfced8 100644
--- a/testsuites/libtests/block17/init.c
+++ b/testsuites/libtests/block17/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/bspcmdline01/init.c b/testsuites/libtests/bspcmdline01/init.c
index 243c7aad2a..11f37d369a 100644
--- a/testsuites/libtests/bspcmdline01/init.c
+++ b/testsuites/libtests/bspcmdline01/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2012.
  *  On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/testsuites/libtests/complex/init.c b/testsuites/libtests/complex/init.c
index 185b38f8f3..442238e79e 100644
--- a/testsuites/libtests/complex/init.c
+++ b/testsuites/libtests/complex/init.c
@@ -1,3 +1,5 @@
 /*  Init
  *  This routine is the initialization task for this test program.
@@ -13,9 +15,26 @@
  *  COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/testsuites/libtests/cpuuse/init.c b/testsuites/libtests/cpuuse/init.c
index 42dcaa505e..d8d5a7595a 100644
--- a/testsuites/libtests/cpuuse/init.c
+++ b/testsuites/libtests/cpuuse/init.c
@@ -1,3 +1,5 @@
  *  This is a clone of sp04 which has been modified to use the cpu monitoring
  *  library.
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/libtests/cpuuse/system.h b/testsuites/libtests/cpuuse/system.h
index 28a6e56510..6ee404dd9a 100644
--- a/testsuites/libtests/cpuuse/system.h
+++ b/testsuites/libtests/cpuuse/system.h
@@ -1,3 +1,5 @@
 /*  system.h
  *  This include file contains information that is included in every
@@ -6,9 +8,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/testsuites/libtests/cpuuse/task1.c b/testsuites/libtests/cpuuse/task1.c
index 969d816859..e326e143a7 100644
--- a/testsuites/libtests/cpuuse/task1.c
+++ b/testsuites/libtests/cpuuse/task1.c
@@ -1,3 +1,5 @@
 /*  Task_1
  *  This test serves as a test task.  It verifies timeslicing activities
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/libtests/cpuuse/task2.c b/testsuites/libtests/cpuuse/task2.c
index 166192966f..63046c7775 100644
--- a/testsuites/libtests/cpuuse/task2.c
+++ b/testsuites/libtests/cpuuse/task2.c
@@ -1,3 +1,5 @@
 /*  Task_2
  *  This routine serves as a test task.  It is just a CPU bound task
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/libtests/cpuuse/task3.c b/testsuites/libtests/cpuuse/task3.c
index 77b6206e6b..ae40b14b66 100644
--- a/testsuites/libtests/cpuuse/task3.c
+++ b/testsuites/libtests/cpuuse/task3.c
@@ -1,3 +1,5 @@
 /*  Task_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/libtests/cpuuse/tswitch.c b/testsuites/libtests/cpuuse/tswitch.c
index 09963739fc..502322076e 100644
--- a/testsuites/libtests/cpuuse/tswitch.c
+++ b/testsuites/libtests/cpuuse/tswitch.c
@@ -1,3 +1,5 @@
 /*  Task_switch
  *  This routine is the tswitch user extension.  It determines which
@@ -13,9 +15,26 @@
  *  COPYRIGHT (c) 1989-2009.
+ * are met:
2.24.4
