[PATCH 1/6] shell: Move line editor output check
Chris Johns
chrisj at rtems.org
Wed Apr 6 09:50:37 UTC 2022
On 6/4/22 5:17 pm, Sebastian Huber wrote:
> Move call to isatty() to caller of rtems_shell_line_editor(). This
> avoids a dependency on isatty() in rtems_shell_line_editor().
> cpukit/libmisc/shell/shell.c | 82 +++++++++++++++++-------------------
> 1 file changed, 38 insertions(+), 44 deletions(-)
> diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
> index a2ed909aae..aa1952e883 100644
> --- a/cpukit/libmisc/shell/shell.c
> +++ b/cpukit/libmisc/shell/shell.c
> @@ -313,32 +313,21 @@ static int rtems_shell_line_editor(
> int c;
> int col;
> int last_col;
> - int output;
> char line[size];
> char new_line[size];
> int up;
> int cmd = -1;
> int inserting = 1;
> int in_fileno = fileno(in);
> - int out_fileno;
> - _Assert(out != NULL);
> - out_fileno = fileno(out);
> - * Only this task can use this file descriptor because calling
> - * fileno will block if another thread call made a call on this
> - * descriptor.
Why has the comment been removed?
> - output = (out && isatty(in_fileno));
> col = last_col = 0;
> tcdrain(in_fileno);
> - if (out)
> - tcdrain(out_fileno);
> + if (out) {
out != NULL ? Just being consistent. :)
> + tcdrain(fileno(out));
> - if (output && prompt)
> + if (out != NULL && prompt != NULL)
> fprintf(out, "\r%s", prompt);
> line[0] = 0;
> @@ -346,7 +335,7 @@ static int rtems_shell_line_editor(
> for (;;) {
> - if (output)
> + if (out != NULL)
> fflush(out);
> extended_key = rtems_shell_getchar(in);
> @@ -368,15 +357,14 @@ static int rtems_shell_line_editor(
> switch (c)
> case RTEMS_SHELL_KEYS_END:
> - if (output)
> + if (out != NULL)
> fprintf(out, "%s", line + col);
> col = (int) strlen (line);
> break;
> case RTEMS_SHELL_KEYS_HOME:
> - if (output) {
> - if (prompt)
> - fprintf(out,"\r%s", prompt);
> + if (out != NULL && prompt != NULL) {
> + fprintf(out,"\r%s", prompt);
> col = 0;
> break;
> @@ -407,7 +395,7 @@ static int rtems_shell_line_editor(
> int end;
> int bs;
> rtems_shell_move_left(line + col, 1);
> - if (output) {
> + if (out != NULL) {
> fprintf(out,"\r%s%s ", prompt, line);
> end = (int) strlen (line);
> for (bs = 0; bs < ((end - col) + 1); bs++)
> @@ -426,9 +414,8 @@ static int rtems_shell_line_editor(
> switch (c)
> case 1: /*Control-a*/
> - if (output) {
> - if (prompt)
> col = 0;
> break;
> @@ -437,7 +424,7 @@ static int rtems_shell_line_editor(
> if (col > 0)
> col--;
> - if (output)
> + if (out != NULL)
> fputc('\b', out);
> break;
> @@ -446,7 +433,7 @@ static int rtems_shell_line_editor(
> if (strlen(line)) {
> if (col < strlen(line)) {
> - if (output) {
> int bs;
> fprintf(out,"%s \b", line + col);
> for (bs = 0; bs < ((int) strlen (line) - col); bs++)
> @@ -458,26 +445,26 @@ static int rtems_shell_line_editor(
> /* Fall through */
> case EOF:
> - if (output)
> + if (out != NULL)
> fputc('\n', out);
> return -2;
> case 5: /*Control-e*/
> - if (output)
> + if (out != NULL)
> break;
> case 6: /* Control-F */
> if ((col < size) && (line[col] != '\0')) {
> - if (output)
> + if (out != NULL)
> fputc(line[col], out);
> col++;
> break;
> case 7: /* Control-G */
> - if (output) {
> * The (int) cast is needed because the width specifier (%*)
> * must be an int, but strlen() returns a size_t. Without
> @@ -492,7 +479,7 @@ static int rtems_shell_line_editor(
> case 11: /*Control-k*/
> if (line[col]) {
> - if (output) {
> int end = strlen(line);
> int bs;
> fprintf(out,"%*c", end - col, ' ');
> @@ -504,7 +491,7 @@ static int rtems_shell_line_editor(
> break;
> case '\f':
> - if (output) {
> int end;
> int bs;
> fputc('\f',out);
> @@ -522,7 +509,7 @@ static int rtems_shell_line_editor(
> int bs;
> col--;
> - if (output) {
> fprintf(out,"\b%s \b", line + col);
> fputc('\b', out);
> @@ -536,7 +523,7 @@ static int rtems_shell_line_editor(
> * Process the command.
> - if (output)
> + if (out != NULL)
> fprintf(out,"\n");
> @@ -564,7 +551,7 @@ static int rtems_shell_line_editor(
> case 16: /* Control-P */
> if ((cmd >= (count - 1)) || (strlen(cmds[cmd + 1]) == 0)) {
> - if (output)
> + if (out != NULL)
> fputc('\x7', out);
> break;
> @@ -584,7 +571,7 @@ static int rtems_shell_line_editor(
> cmd++;
> } else {
> if (cmd < 0) {
> - if (output)
> + if (out != NULL)
> fprintf(out, "\x7");
> break;
> @@ -602,7 +589,7 @@ static int rtems_shell_line_editor(
> col = strlen (line);
> - if (output) {
> fprintf(out,"\r%s%*c", prompt, clen, ' ');
> fprintf(out,"\r%s%s", prompt, line);
> @@ -615,17 +602,17 @@ static int rtems_shell_line_editor(
> char tmp;
> if (col == strlen(line)) {
> col--;
> - if (output)
> + if (out != NULL)
> fprintf(out,"\b");
> tmp = line[col];
> line[col] = line[col - 1];
> line[col - 1] = tmp;
> - if (output)
> + if (out != NULL)
> fprintf(out,"\b%c%c", line[col - 1], line[col]);
> col++;
> } else {
> - if (output)
> + if (out != NULL)
> fputc('\x7', out);
> break;
> @@ -639,7 +626,7 @@ static int rtems_shell_line_editor(
> int bs;
> rtems_shell_move_left(line, col);
> - if (output) {
> @@ -658,7 +645,7 @@ static int rtems_shell_line_editor(
> int ch, bs;
> for (ch = end + 1; ch > col; ch--)
> line[ch] = line[ch - 1];
> - if (output) {
> for (bs = 0; bs < (end - col + 1); bs++)
> fputc('\b', out);
> @@ -667,7 +654,7 @@ static int rtems_shell_line_editor(
> line[col++] = c;
> if (col > end)
> line[col] = '\0';
> - if (output)
> + if (out != NULL)
> fputc(c, out);
> break;
> @@ -869,6 +856,7 @@ bool rtems_shell_main_loop(
> int line = 0;
> FILE *stdinToClose = NULL;
> FILE *stdoutToClose = NULL;
> + FILE *line_editor_output;
lineEditorOutput or line_editor_output?
> rtems_shell_init_environment();
> @@ -974,6 +962,12 @@ bool rtems_shell_main_loop(
> setvbuf(stdin, NULL, _IONBF, 0);
> setvbuf(stdout, NULL, _IONBF, 0);
> + if (isatty(fileno(stdin))) {
> + line_editor_output = stdout;
> + } else {
> + line_editor_output = NULL;
> * Allocate the command line buffers.
> @@ -1044,7 +1038,7 @@ bool rtems_shell_main_loop(
> /* getcmd section */
> cmd = rtems_shell_line_editor(cmds, cmd_count,
> RTEMS_SHELL_CMD_SIZE, prompt,
> - stdin, stdout);
> + stdin, line_editor_output);
> if (cmd == -1)
> continue; /* empty line */
