[PATCH 6/6] shell: Add rtems_shell_run_main_loop()
Wed Apr 6 09:55:16 UTC 2022
On 6/4/22 5:17 pm, Sebastian Huber wrote:
> In contrast to rtems_shell_main_loop(), this new function does not
> perform all sorts of initialization based on environment settings.  For
> example, due to the use of isatty() in rtems_shell_main_loop() it is
> impossible to run an interactive shell through a socket connection.
We have been using the shell with telnet for years so I do not understand what
is being said here?
