[PATCH 12/12] spec/build/cpukit: Add option for enabling PPS synchronization
Sebastian Huber
Thu Apr 7 08:48:56 UTC 2022
On 07/04/2022 10:36, Gabriel Moyano wrote:
> spec/build/cpukit/cpuopts.yml | 2 ++
> spec/build/cpukit/optppssync.yml | 16 ++++++++++++++++
> 2 files changed, 18 insertions(+)
> create mode 100644 spec/build/cpukit/optppssync.yml
> diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
> index 301d49ccea..db0e05395f 100644
> --- a/spec/build/cpukit/cpuopts.yml
> +++ b/spec/build/cpukit/cpuopts.yml
> @@ -49,6 +49,8 @@ links:
> uid: optparavirt
> - role: build-dependency
> uid: optposix
> +- role: build-dependency
> + uid: optppssync
> uid: optprofiling
> diff --git a/spec/build/cpukit/optppssync.yml b/spec/build/cpukit/optppssync.yml
> new file mode 100644
> index 0000000000..6766cf0d40
> --- /dev/null
> +++ b/spec/build/cpukit/optppssync.yml
> @@ -0,0 +1,16 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-boolean: null
> +- env-enable: null
> +- define-condition: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2022 German Aerospace Center (DLR)
> +default: false
> +default-by-variant: []
> +description: |
> + Enable time synchronization using a Pulse Per Second signal
> +enabled-by: true
> +links: []
> +name: PPS_SYNC
> +type: build
If this should really be a CPU option, then it needs a proper RTEMS_*
prefix. Why do we need the option. What is the overhead if it is always
enabled.
In general, the patch set lacks test cases.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
