[PATCH] imfs: Fix index underrun when extending empty file
Christian MAUDERER
christian.mauderer at embedded-brains.de
Thu Apr 7 08:50:32 UTC 2022
Am 04.04.22 um 16:41 schrieb Christian MAUDERER:
> Am 04.04.22 um 16:40 schrieb Joel Sherrill:
>> On Mon, Apr 4, 2022, 9:28 AM Christian MAUDERER
>> <christian.mauderer at embedded-brains.de
>> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>> Please note: I would like to apply this to the 5 branch too. I
>> created a
>> ticket for 5 here:
>> https://devel.rtems.org/ticket/4638
>> <https://devel.rtems.org/ticket/4638>
>> Note that both tickets (5 and 6) are clones of an old 4.11 ticket:
>> https://devel.rtems.org/ticket/2353
>> <https://devel.rtems.org/ticket/2353>
>> I didn't plan to backport the patch to 4.11. I'll add a comment to
>> the
>> ticket that the problem is fixed in 5 and 6. Should I close the 4.11
>> ticket with a "wontfix" or just let it open?
>> If the ticket applies easily, just apply it after testing on 5 and 6.
>> Please.
> OK. I'll try it.
I applied the patch to all three branches (master, 5, 4.11). I only
skipped adding the test for 4.11 because that part didn't apply without
problems. But the bug is fixed there too.
Best regards
Christian
>> Is there a test case for this?
> The patch adds one.
>> --joel
>> Best regards
>> Christian
>> Am 04.04.22 um 16:23 schrieb Christian Mauderer:
>> > Currently the following sequence causes a endless loop when
>> extending an
>> > IMFS file:
>> > - Create a file with zero length and close it.
>> > - Make sure nearly no allocatable memory is left.
>> > - Open the file and write enough data into it that more than the
>> > remaining memory will be used.
>> > In that case when extending the IMFS file, the file currently
>> need zero
>> > blocks. If allocating enough new blocks fails, the already
>> allocated new
>> > blocks will be freed again.
>> > The comparison of block>=old_blocks that has been used prior to
>> this
>> > patch compared two unsigned numbers. If old_blocks was zero, the
>> > comparison of these two numbers always evaluated to true.
>> > This patch frees the last block in a separate step to avoid this
>> > problem.
>> > Fixes #4639
>> > cpukit/libfs/src/imfs/imfs_memfile.c | 3 ++-
>> > testsuites/psxtests/psximfs02/init.c | 30
>> > 2 files changed, 31 insertions(+), 2 deletions(-)
>> > diff --git a/cpukit/libfs/src/imfs/imfs_memfile.c
>> b/cpukit/libfs/src/imfs/imfs_memfile.c
>> > index 23c7192717..769a570ecf 100644
>> > --- a/cpukit/libfs/src/imfs/imfs_memfile.c
>> > +++ b/cpukit/libfs/src/imfs/imfs_memfile.c
>> > @@ -208,9 +208,10 @@ static int IMFS_memfile_extend(
>> > offset = 0;
>> > } else {
>> > - for ( ; block>=old_blocks ; block-- ) {
>> > + for ( ; block>old_blocks ; block-- ) {
>> > IMFS_memfile_remove_block( memfile, block );
>> > + IMFS_memfile_remove_block( memfile, old_blocks );
>> > rtems_set_errno_and_return_minus_one( ENOSPC );
>> > diff --git a/testsuites/psxtests/psximfs02/init.c
>> b/testsuites/psxtests/psximfs02/init.c
>> > index 15b9137121..04f806f565 100644
>> > --- a/testsuites/psxtests/psximfs02/init.c
>> > +++ b/testsuites/psxtests/psximfs02/init.c
>> > @@ -23,6 +23,8 @@
>> > #include <rtems/malloc.h>
>> > #include <rtems/libcsupport.h>
>> > +#define MEMFILE_BYTES_PER_BLOCK 16
>> > const char rtems_test_name[] = "PSXIMFS 2";
>> > /* forward declarations to avoid warnings */
>> > @@ -43,12 +45,17 @@ rtems_task Init(
>> > static const uintptr_t slink_2_name_size [] = {
>> > sizeof( slink_2_name )
>> > + static const uintptr_t some_blocks [] = {
>> > + MEMFILE_BYTES_PER_BLOCK * 10
>> > + static const char some_data[MEMFILE_BYTES_PER_BLOCK * 11];
>> > int status = 0;
>> > void *opaque;
>> > char linkname_n[32] = {0};
>> > char linkname_p[32] = {0};
>> > int i;
>> > + int fd;
>> > struct stat stat_buf;
>> > TEST_BEGIN();
>> > @@ -102,6 +109,27 @@ rtems_task Init(
>> > rtems_test_assert( status == -1 );
>> > rtems_test_assert( errno == EACCES );
>> > + puts( "Allocate most of heap with a little bit left" );
>> > + opaque = rtems_heap_greedy_allocate( some_blocks, 1 );
>> > + puts( "Create an empty file.");
>> > + status = mknod( "/foo", S_IFREG | S_IRWXU, 0LL );
>> > + rtems_test_assert( status == 0 );
>> > + puts( "Then increase it's size to more than remaining space" );
>> > + fd = open( "/foo", O_WRONLY | O_TRUNC);
>> > + rtems_test_assert( fd >= 0 );
>> > + status = write(fd, some_data, sizeof(some_data));
>> > + rtems_test_assert( status == -1);
>> > + rtems_test_assert( errno == ENOSPC );
>> > + puts( "Clean up again" );
>> > + status = close(fd);
>> > + rtems_test_assert( status == 0);
>> > + status = remove( "/foo" );
>> > + rtems_heap_greedy_free( opaque );
>> > puts( "Allocate most of heap" );
>> mount_table_entry_size, 1 );
>> > @@ -202,7 +230,7 @@ rtems_task Init(
>> > #define CONFIGURE_FILESYSTEM_IMFS
>> > #define CONFIGURE_MAXIMUM_TASKS 1
>> > -#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK 16
>> > +#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
>> > #define CONFIGURE_IMFS_ENABLE_MKFIFO
>> > #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
>> > #define CONFIGURE_INITIAL_EXTENSIONS
>> RTEMS_TEST_INITIAL_EXTENSION
>> embedded brains GmbH
>> Herr Christian MAUDERER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> phone: +49-89-18 94 741 - 18
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
>> Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> <https://embedded-brains.de/datenschutzerklaerung/>
>> devel mailing list
>> devel at rtems.org <mailto:devel at rtems.org>
>> <http://lists.rtems.org/mailman/listinfo/devel>
Dornierstr. 4
82178 Puchheim
Germany
