AW: [PATCH 06/12] kern_tc.c: Replace FREEBSD event mechanism by adding pointers to function
Thu Apr 7 11:35:52 UTC 2022
On 07/04/2022 11:56, Gabriel.Moyano at dlr.de wrote:
>> On 07/04/2022 10:36, Gabriel Moyano wrote:
>>> diff --git a/cpukit/include/sys/timepps.h
>>> b/cpukit/include/sys/timepps.h index 5703381ffa..a72579d5d7 100644
>>> --- a/cpukit/include/sys/timepps.h
>>> +++ b/cpukit/include/sys/timepps.h
>>> @@ -149,6 +149,12 @@ struct mtx;
>>>    #define	PPSFLAG_MTX_SPIN	0x01	/* Driver mtx is MTX_SPIN type. */
>>> +#ifdef __rtems__
>>> +struct pps_state;
>>> +typedef int (*wait_event_func)(struct pps_state *pps, struct timespec
>>> +timeout); typedef void (*wakeup_func)(struct pps_state *pps); #endif
>>> +/* __rtems__ */
>>>    struct pps_state {
>>>    	/* Capture information. */
>>>    	struct timehands *capth;
>>> @@ -164,6 +170,11 @@ struct pps_state {
>>>    	int		ppscap;
>>>    	struct timecounter *ppstc;
>>>    	unsigned	ppscount[3];
>>> +#ifdef __rtems__
>>> +    wait_event_func wait_event;
>>> +    wakeup_func wakeup;
>>> +#endif /* __rtems__ */
>>>    	 * The following fields are valid if the driver calls pps_init_abi().
>> Why do we need the typedefs?
> Just for clarity
At the moment, they just pollute the namespace. I would remove them
until you have to store the callbacks in a variable.
>> Please don't change the formatting.
> Do you mean that wait_event should be waitevent?
No, please use the FreeBSD coding style.
I would use "wait" and "wakeup", or "wait_for_event" and "send_event".
Please add comments how the callbacks are used and that they shall not
be NULL.
>> No changes outside the #ifdef __rtems__ markers please.
> Sorry, could you point to the changes?
You add blank lines after the #endif.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
