AW: AW: [PATCH 11/12] kern_ntptime: Add define in order to remove warning
Sebastian Huber
Thu Apr 7 12:55:38 UTC 2022
On 07/04/2022 14:51, Gabriel.Moyano at dlr.de wrote:
>> On 07/04/2022 11:56, Gabriel.Moyano at dlr.de wrote:
>>>> On 07/04/2022 10:36, Gabriel Moyano wrote:
>>>>> cpukit/score/src/kern_ntptime.c | 3 +++
>>>>> 1 file changed, 3 insertions(+)
>>>>> diff --git a/cpukit/score/src/kern_ntptime.c
>>>>> b/cpukit/score/src/kern_ntptime.c index d4a233f67e..d6ea739f5b
>>>>> 100644
>>>>> --- a/cpukit/score/src/kern_ntptime.c
>>>>> +++ b/cpukit/score/src/kern_ntptime.c
>>>>> @@ -58,6 +58,9 @@ __FBSDID("$FreeBSD$");
>>>>> #include <sys/time.h>
>>>>> #include <sys/timex.h>
>>>>> #include <sys/timetc.h>
>>>>> +#ifdef __rtems__
>>>>> +#define _KERNEL
>>>>> +#endif /* __rtems__ */
>>>>> #include <sys/timepps.h>
>>>>> #ifndef __rtems__
>>>>> #include <sys/syscallsubr.h>
>>>> Who is supposed to use the _KERNEL <sys/timepps.h.> API?
>>> hardpps()
>> The pps_*() API should be accessible for RTEMS drivers without having to define _KERNEL.
> The API functions start with time_pps_*().
This is the user space API. It uses a file descriptor.
PPS device drivers should use the kernel space API. Since we don't have
a user and kernel space in RTEMS, the kerne space API should be
available also if __rtems__ is defined.
> hardpps() is declared if _KERNEL is defined. That's why I added it before including timepps.h in kern_ntptime.c
> It was for removing a warning.
>> The hardpps() needs to be added to the _ namespace, for example _NTP_Pulse_per_second_event().
> Here I didn't follow you
The FreeBSD kernel has its own symbol namespace which is separated from
the application. In RTEMS, the kernel and application share a symbol
namespace. Kernel functions should use the _ namespace.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
