AW: AW: [PATCH 12/12] spec/build/cpukit: Add option for enabling PPS synchronization
Sebastian Huber
Thu Apr 7 13:01:35 UTC 2022
On 07/04/2022 14:51, Gabriel.Moyano at dlr.de wrote:
>>>> In general, the patch set lacks test cases.
>>> I was thinking that the next step could be to add a generic device which is required to use the API (a file descriptor is needed). This is
>> something that wanted to ask in the mailing list first. When this device is added, also the test cases can be. Furthermore I wanted to
>> split the submitted changes in order to make a review easier.
>> A file descriptor should be optional. It should be possible to add a PPS driver just using struct pps_state.
> The struct pps_state type is used only internally. In order to be able to use the API a file descriptor is required (API functions start with time_pps_*()).
> The "generic device" I have in mind will have an object of struct pps_state.
A PPS device driver needs access to the _KERNEL API defined by
<sys/timepps.h>. It should not be required to use a file descriptor.
The user space time_pps_*() API is an optional component.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
