[PATCH] bsp/arm: allocate .rtemsstack on REGION_STACK instead of on REGION_WORK
Karel Gardas
karel at functional.vision
Thu Apr 7 19:15:06 UTC 2022
REGION_WORK may be backed by external RAM which may not be initialized
in a time we need stack to work well. E.g. code loaded in flash,
stack allocated on in-cpu SRAM and data (REGION_WORK) on external SDRAM.
Sponsored-By: Precidata
bsps/arm/shared/start/linkcmds.base | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsps/arm/shared/start/linkcmds.base b/bsps/arm/shared/start/linkcmds.base
index ec6c4e4557..10d2c54028 100644
--- a/bsps/arm/shared/start/linkcmds.base
+++ b/bsps/arm/shared/start/linkcmds.base
@@ -329,7 +329,7 @@ SECTIONS {
bsp_section_rtemsstack_begin = .;
*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
bsp_section_rtemsstack_end = .;
- } > REGION_WORK AT > REGION_WORK
+ } > REGION_STACK AT > REGION_STACK
bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
.noinit (NOLOAD) : ALIGN_WITH_INPUT {
2.25.1
