[PATCH 1/1] libbsd: Add TFTP filesystem to test media01
Frank Kuehndel frank.kuehndel at embedded-brains.de
Fri Apr 8 14:05:23 UTC 2022
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
How test media01 can be executed is described in section
*Qemu and Networking* of the README.md at the top of the
rtems-libbsd GIT repository.
When connected via `telnet` with the RTEMS shell of the
media01.exe test executed by QEMU, one can list the filesystems
available for mounting:
TLNT [/] # mount -L
File systems: / dosfs tftpfs
The list will contain `tftpfs`.  The filesystem can be mounted
as in the following example:
TLNT [/] # mkdir /tftp
TLNT [/] # mount -t tftpfs -o verbose "" /tftp
A TFTP server is needed to use this filesystem.  The simplest way
would be to run such a server on the host machine and open the
firewall for the TFTP protocol (port 69) on the TAP device used.
Files can then be downloaded using the usual shell commands
TLNT [/] # cat /tftp/169.254.1.1:hello.txt
Uploading is also possible provided the TFTP server supports it,
for example:
TLNT [/] # cp /etc/dhcpcd.duid /tftp/169.254.1.1:myfile
 libbsd.py                     | 2 +-
 testsuite/media01/test_main.c | 2 ++
 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/libbsd.py b/libbsd.py
index 32cb741f..974934fb 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5425,7 +5425,7 @@ class tests(builder.Module):
         self.addTest(mm.generator['test']('smp01', ['test_main'], extraLibs = ['rtemstest']))
         self.addTest(mm.generator['test']('media01', ['test_main', 'pattern-test'],
                                           runTest = False,
-                                          extraLibs = ['ftpd', 'telnetd']))
+                                          extraLibs = ['tftpfs', 'ftpd', 'telnetd']))
         self.addTest(mm.generator['test']('mcast01', ['test_main']))
         self.addTest(mm.generator['test']('vlan01', ['test_main'], netTest = True))
         self.addTest(mm.generator['test']('lagg01', ['test_main'], netTest = True))
diff --git a/testsuite/media01/test_main.c b/testsuite/media01/test_main.c
index 2a1c9aae..001c80a8 100644
--- a/testsuite/media01/test_main.c
+++ b/testsuite/media01/test_main.c
@@ -201,6 +201,8 @@ early_initialization(void)
 #define CONFIGURE_FILESYSTEM_DOSFS
+#define CONFIGURE_FILESYSTEM_TFTPFS
 #define CONFIGURE_MAXIMUM_PROCESSORS 32
 #define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS 4096
2.34.1
