[PATCH v1 1/2] wscript: Allow defines to be used for substitution
Sebastian Huber
Wed Apr 13 05:53:58 UTC 2022
On 12/04/2022 20:55, Kinsey Moore wrote:
> This allows options set as defines to the compiler to be used as targets
> for substitution using the syntax ${DEFINES:define_target}. These need
> special handling since they are not in a form that is trivially consumed
> by the mapping code.
> wscript | 4 ++++
> 1 file changed, 4 insertions(+)
> diff --git a/wscript b/wscript
> index 4d63dbc66f..9de9d67b91 100755
> --- a/wscript
> +++ b/wscript
> @@ -107,6 +107,10 @@ class EnvWrapper(object):
> except IndexError:
> fmt = "{}"
> if isinstance(v, list):
> + if fields[0] == "DEFINES":
> + for D in v:
> + if D.startswith(fields[1]+'='):
> + return "{}".format(D.split("=")[1].strip('"'))
> return " ".join([fmt.format(w) for w in v])
> return fmt.format(v)
Sorry, I don't understand what this is supposed to do. Could you please
give me an example use case?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
