[PATCH v1 1/2] wscript: Allow defines to be used for substitution
Sebastian Huber
Wed Apr 13 18:38:02 UTC 2022
On 13/04/2022 20:06, Kinsey Moore wrote:
> On 4/13/2022 00:53, Sebastian Huber wrote:
>> On 12/04/2022 20:55, Kinsey Moore wrote:
>>> This allows options set as defines to the compiler to be used as targets
>>> for substitution using the syntax ${DEFINES:define_target}. These need
>>> special handling since they are not in a form that is trivially consumed
>>> by the mapping code.
>>> wscript | 4 ++++
>>> 1 file changed, 4 insertions(+)
>>> diff --git a/wscript b/wscript
>>> index 4d63dbc66f..9de9d67b91 100755
>>> --- a/wscript
>>> +++ b/wscript
>>> @@ -107,6 +107,10 @@ class EnvWrapper(object):
>>> except IndexError:
>>> fmt = "{}"
>>> if isinstance(v, list):
>>> + if fields[0] == "DEFINES":
>>> + for D in v:
>>> + if D.startswith(fields[1]+'='):
>>> + return "{}".format(D.split("=")[1].strip('"'))
>>> return " ".join([fmt.format(w) for w in v])
>>> return fmt.format(v)
>> Sorry, I don't understand what this is supposed to do. Could you
>> please give me an example use case?
> Currently, this is being used with the other substitution patch to allow
> critical external resources for the Deos BSPs to be placed at
> user-defined locations. In the BSP for RTEMS5, this was being provided
> as a variable to `make` and being substituted into paths in the various
> Makefiles. I had thought to codify this input a little more strictly as
> a BSP configuration option in config.ini to make it more obvious or even
> a required part of the `waf configure` step. The BSP option, when set as
> a compiler define, can be used in substitutions to reference these
> external paths.
Ok, so you want to use this for command line defines using -D option? I
am strongly opposed to the use of command line defines. Why can't you
place the defines in bspopts.h or cpuopts.h?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
