[PATCH v2] wscript: Allow substitution outside values
Kinsey Moore kinsey.moore at oarcorp.com
Wed Apr 13 21:47:47 UTC 2022
This expands the ability to substitute variables outside the current
limitation of values in options to asflags, cflags, cppflags, cxxflags,
ldflags, and includes. It is possible for all of these flags to utilize
user-defined information in config.ini, especially for paths to external
resources.
 wscript | 54 ++++++++++++++++++++++++++++--------------------------
 1 file changed, 28 insertions(+), 26 deletions(-)
diff --git a/wscript b/wscript
index 4d63dbc66f..eb5761c53d 100755
--- a/wscript
+++ b/wscript
@@ -239,6 +239,8 @@ class Item(object):
         return
     def substitute(self, ctx, value):
+        if isinstance(value, list):
+            return [self.substitute(ctx, subvalue) for subvalue in value]
         if isinstance(value, str):
             try:
                 return Template(value).substitute(EnvWrapper(ctx.env))
@@ -272,10 +274,10 @@ class Item(object):
         if target is None:
             target = os.path.splitext(source)[0] + ".o"
         bld(
-            asflags=self.data["asflags"],
-            cppflags=self.data["cppflags"],
+            asflags=self.substitute(bld, self.data["asflags"]),
+            cppflags=self.substitute(bld, self.data["cppflags"]),
             features="asm_explicit_target asm c",
-            includes=bic.includes + self.data["includes"],
+            includes=bic.includes + self.substitute(bld, self.data["includes"]),
             source=[source],
             target=target,
@@ -285,10 +287,10 @@ class Item(object):
         if target is None:
         bld(
-            cflags=self.data["cflags"],
-            cppflags=cppflags + self.data["cppflags"],
+            cflags=self.substitute(bld, self.data["cflags"]),
+            cppflags=cppflags + self.substitute(bld, self.data["cppflags"]),
             features="c",
             rule="${CC} ${CFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES} ${CPPPATH_ST:INCPATHS} -c ${SRC[0]} -o ${TGT}",
             source=[source] + deps,
             target=target,
@@ -299,10 +301,10 @@ class Item(object):
         if target is None:
         bld(
-            cxxflags=self.data["cxxflags"],
+            cxxflags=self.substitute(bld, self.data["cxxflags"]),
             features="cxx",
             rule="${CXX} ${CXXFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES} ${CPPPATH_ST:INCPATHS} -c ${SRC[0]} -o ${TGT}",
             target=target,
@@ -574,11 +576,11 @@ class ObjectsItem(Item):
     def do_build(self, bld, bic):
         bld.objects(
-            asflags=self.data["cppflags"],
+            asflags=self.substitute(bld, self.data["cppflags"]),
             source=self.data["source"],
             target=self.uid,
@@ -599,10 +601,10 @@ class BSPItem(Item):
         bld(
             features="c cstlib",
             install_path="${BSP_LIBDIR}",
             target="rtemsbsp",
@@ -620,11 +622,11 @@ class LibraryItem(Item):
         bld(
             features="c cxx cstlib",
             install_path=self.data["install-path"],
             target=self.get(bld, "target"),
@@ -648,13 +650,13 @@ class TestProgramItem(Item):
         bld(
-            cppflags=bld.env[self.cppflags] + self.data["cppflags"],
+            cppflags=bld.env[self.cppflags] + self.substitute(bld, self.data["cppflags"]),
             features=self.data["features"],
             install_path=None,
-            ldflags=bic.ldflags + self.data["ldflags"],
+            ldflags=bic.ldflags + self.substitute(bld, self.data["ldflags"]),
             start_files=True,
             stlib=self.data["stlib"],
2.30.2
