CAN Options and Licensing, Testing, etc
Prashanth S
fishesprashanth at gmail.com
Thu Apr 14 03:49:44 UTC 2022
> And should be able to demonstrate CAN Linux <-> on the same hardware to
> verify your test setup.
Ok, that will be helpful to verify the hardware test setup.
Regards,
Prashanth S
On Thu, 14 Apr 2022 at 00:52, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Apr 12, 2022 at 9:32 PM Prashanth S <fishesprashanth at gmail.com>
> wrote:
>> Hi Joel,
>> Have you determined how you will test CAN on BBB?
>> I planned to test the CAN driver with another BBB running linux. And if
>> CAN analyzer is economical then I would use that.
> OK. I assume you have accounted for all the cables, transceivers, etc.
> I'm deferring to others for the hardware needed. I just know there has to
> be a shopping list.
> --joel
>> Regards
>> Prashanth S
>> On Wed, 13 Apr 2022 at 00:38, Joel Sherrill <joel at rtems.org> wrote:
>>> On Tue, Apr 12, 2022 at 12:39 PM Oliver Hartkopp <socketcan at hartkopp.net>
>>> wrote:
>>>> Hi Joel,
>>>> at least for the SocketCAN network layer part the license is a dual
>>>> license BSD3/GPLv2
>>>> // SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause)
>>>> https://elixir.bootlin.com/linux/v5.17.2/source/net/can/af_can.c#L1
>>>> The reason was that we (at Volkswagen) intended the idea, the API,
>>>> (CAN)
>>>> data structures and code could be easily ported to BSD/MacOS/Windows.
>>>> In fact we created a working Windows PoC but CAN hardware vendors had
>>>> no
>>>> interest to unify a open CAN driver API - to maintain their Lock-In :-/
>>>> Today only a few CAN network drivers in linux/drivers/net/can follow
>>>> this dual license approach. As they are 'Linux-specific' they are
>>>> mostly
>>>> GPLv2.
>>> Thanks for clarifying that.
>>> The PowerPC qoriq network drivers in libbsd are dual licensed and there
>>> is some framework included to support Linux drivers in libbsd. That's the
>>> extent of my knowledge but it at least means this could be possible to
>>> integrate without knowingly diving into a deep pit.
>>> It has the disadvantage that CAN support would be tied to using libbsd.
>>> That's likely too heavy for some environments. But might be a good
>>> solution if portability of applications is a goal.
>>>> Best regards,
>>>> Oliver
>>>> On 12.04.22 19:13, Prashanth S wrote:
>>>> > Hi All,
>>>> > This is to ask for suggestions on implementing the CAN driver for BBB.
>>>> > Can I proceed with defining driver specific structures for the CAN
>>>> > driver or go with adding a generic API layer for ADC and GPIO.
>>> I imagine you can use libdebugger to debug CAN.
>>> A big part of the community part of GSoC is making sure you are
>>> in a good position to succeed. That means knowing how you will
>>> test.
>>> --joel
>>> --joel
>>>> > Regards
>>>> > Prashanth S
>>>> > On Tue, 12 Apr 2022 at 19:14, Joel Sherrill <joel at rtems.org
>>>> > <mailto:joel at rtems.org>> wrote:
>>>> > Hi
>>>> > I didn't want to post this in the other thread and turn it from a
>>>> > technical into licensing discussion but that must be the first
>>>> > filter for a CAN solution for RTEMS if it uses third-party code.
>>>> If
>>>> > I have extracted the options correctly, we have:
>>>> > + LinCAN - GPL
>>>> > + SocketCAN - GPL
>>>> > + NuttX CAN - Apache
>>>> > + CANOpen - Apache
>>>> > The licensing alone eliminates two of the solutions.
>>>> > My other concern was how you were going to test the drivers you
>>>> > wrote. Pavel mentions CAN in qemu. Perhaps the project should drop
>>>> > the ADC and focus on a CAN solution using the BSP supported by
>>>> Qemu
>>>> > along with whatever analysis tools Pavel recommends. I am sure
>>>> Pavel
>>>> > has some driver code for the Qemu path (not sure if it is in RTEMS
>>>> > or not) This would move the project from a single driver to trying
>>>> > to provide a CAN solution. This is much more valuable to the
>>>> project
>>>> > long term.
>>>> > And since CANOpen is an independent and long running project, I'd
>>>> > lean to it as the selection.
>>>> > Just my thoughts
>>>> > --joel
