[PATCH] tester/bsps: add stm32h7-stlink family configuration
Karel Gardas karel at functional.vision
Tue Apr 19 12:31:34 UTC 2022
Sponsored-By:	Precidata
 tester/rtems/testing/bsps/stm32h7-stlink.ini | 43 ++++++++++++++++++++
 1 file changed, 43 insertions(+)
 create mode 100644 tester/rtems/testing/bsps/stm32h7-stlink.ini
diff --git a/tester/rtems/testing/bsps/stm32h7-stlink.ini b/tester/rtems/testing/bsps/stm32h7-stlink.ini
new file mode 100644
index 0000000..042ec7c
--- /dev/null
+++ b/tester/rtems/testing/bsps/stm32h7-stlink.ini
@@ -0,0 +1,43 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2015 On-Line Applications Research Corporation (OAR).
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The stm32h7 BSP family
+[stm32h7-stlink]
+bsp            = stm32h7-stlink
+arch           = arm
+tester         = %{_rtscripts}/gdb.cfg
+jobs           = 1
+gdb_script     = bsp_gdb_script
+requires: bsp_tty_dev, bsp_gdb_script, target_pretest_command, target_posttest_command
+bsp_gdb_script = target extended-remote :61234
+                 load
+                 cont
2.25.1
