[PATCH] GDB: fix python config command line arguments based on python version
Frank Kühndel frank.kuehndel at embedded-brains.de
Thu Apr 21 10:53:03 UTC 2022
Hi Karel,
On 4/20/22 20:38, Karel Gardas wrote:
> Chris, Frank,
> I don't feel particularly comfortable with this patch. It works here on
> Ubuntu 20.04 with python 3.3 and Ubuntu 22.04 with Python 3.10, but I
> have to admit semantics of this cfg language is beyond my liking and a
> lot is in complete darkness here. E.g. how &&, < operator are working
> here. Delete both int conversions and it'll not work at all. Keep one
> and it'll work well.
> The problem is probably lack of time to go thorough all the docs on
> docs.rtems.org to find relevant bits while working on the patch.
> Anyway, if you have time, please review and test on your platforms.
I am rather sorry to write this but your patch does not work for me. The
before failing build on "Fedora Linux 35 (Container Image)" with Python
3.10.4 works fine with your patch. Yet, the "openSUSE Leap 15.3"
container with Python 3.6.15 (which was building OK without this patch)
fails now:
11:32:00  config: tools/rtems-gdb-11.2.cfg
11:32:00  error: shell macro failed:
/home/minna/src/rtems-source-builder/source-builder/sb/rtems-build-dep
-c gcc  -l : 2: error: no library (-l) provided
11:32:00  Build FAILED
11:32:00  Build Set: Time 0:00:37.716473
Some notes: The "RTEMS User Manual" Section "14.5.8.21. %if"
  https://docs.rtems.org/branches/master/user/rsb/configuration.html#if
states:
  "< The left hand side is numerically less than the
     right hand side."
  "<= The left hand side is numerically less than or
      equal to the right hand side."
According to this, it is never a lexicographical comparison. 3.10 is 3.1
as floating number and thus 3.1 < 3.8 holds true. What I do not know is
whether the tool uses integers or real numbers nor whether the
documentation is up to date. The `&&` and the `int()` are _not_
documented there. The `&&` is actually used in .cfg-files but
surprisingly seldom. Moreover, this command may help debugging:
   `%{echo message}`  Print the following string as a message.
Greetings,
fk
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
