[PATCH 04/15] libtests: Adding file headers and licenses
Ryan Long ryan.long at oarcorp.com
Thu Apr 21 14:06:04 UTC 2022
These files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
 testsuites/libtests/mouse01/serial_mouse_config.c  | 35 ++++++++++++++++++++++
 .../libtests/termios04/termios_testdriver_intr.c   | 35 ++++++++++++++++++++++
 .../libtests/termios05/termios_testdriver_task.c   | 35 ++++++++++++++++++++++
 testsuites/libtests/termios10/init.c               | 35 ++++++++++++++++++++++
 testsuites/libtests/termios11/init.c               | 35 ++++++++++++++++++++++
 5 files changed, 175 insertions(+)
diff --git a/testsuites/libtests/mouse01/serial_mouse_config.c b/testsuites/libtests/mouse01/serial_mouse_config.c
index 798cbf3..b3782a7 100644
--- a/testsuites/libtests/mouse01/serial_mouse_config.c
+++ b/testsuites/libtests/mouse01/serial_mouse_config.c
@@ -1,3 +1,38 @@
+ *  @file
+ *  @ingroup libtests
+ *  @brief This is serial_mouse_config for mouse01.
+ * COPYRIGHT (C) 1989-2011 On-Line Applications Research Corporation (OAR).
+ * are met:
  * MODULE DESCRIPTION:
diff --git a/testsuites/libtests/termios04/termios_testdriver_intr.c b/testsuites/libtests/termios04/termios_testdriver_intr.c
index 5946c29..f13c7c4 100644
--- a/testsuites/libtests/termios04/termios_testdriver_intr.c
+++ b/testsuites/libtests/termios04/termios_testdriver_intr.c
@@ -1 +1,36 @@
+ *  @file
+ *  @brief This is termios_testdriver_intr for termios04.
+ * COPYRIGHT (C) 1989-2012 On-Line Applications Research Corporation (OAR).
+ * are met:
 #include "termios_testdriver_impl.h"
diff --git a/testsuites/libtests/termios05/termios_testdriver_task.c b/testsuites/libtests/termios05/termios_testdriver_task.c
index e1b3181..5fa7005 100644
--- a/testsuites/libtests/termios05/termios_testdriver_task.c
+++ b/testsuites/libtests/termios05/termios_testdriver_task.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is termios_testdriver_task for termios05.
+ * COPYRIGHT (C) 1989-2010 On-Line Applications Research Corporation (OAR).
+ * are met:
 #define TASK_DRIVEN
 #include "../termios04/termios_testdriver_impl.h"
diff --git a/testsuites/libtests/termios10/init.c b/testsuites/libtests/termios10/init.c
index 8655879..1028171 100644
--- a/testsuites/libtests/termios10/init.c
+++ b/testsuites/libtests/termios10/init.c
@@ -1 +1,36 @@
+ *  @file
+ *  @brief This is init for termios10.
+ * COPYRIGHT (C) 2019 On-Line Applications Research Corporation (OAR).
+ * are met:
 #include "termios10impl.h"
diff --git a/testsuites/libtests/termios11/init.c b/testsuites/libtests/termios11/init.c
index 3492a62..cc39c49 100644
--- a/testsuites/libtests/termios11/init.c
+++ b/testsuites/libtests/termios11/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is init for termios11.
+ * COPYRIGHT (C) 1989-2019 On-Line Applications Research Corporation (OAR).
+ * are met:
 #define INTERRUPT_DRIVEN
 #include "../termios10/termios10impl.h"
1.8.3.1
