[PATCH 11/15] ada/samples: Manually adding file headers and licenses
Ryan Long ryan.long at oarcorp.com
Thu Apr 21 14:06:11 UTC 2022
These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
 testsuites/ada/samples/base_mp/node1/init.c | 33 +++++++++++++++++++++++++++++
 testsuites/ada/samples/base_mp/node2/init.c | 33 +++++++++++++++++++++++++++++
 2 files changed, 66 insertions(+)
diff --git a/testsuites/ada/samples/base_mp/node1/init.c b/testsuites/ada/samples/base_mp/node1/init.c
index 073c033..578abff 100644
--- a/testsuites/ada/samples/base_mp/node1/init.c
+++ b/testsuites/ada/samples/base_mp/node1/init.c
@@ -1,2 +1,35 @@
+ *  @file
+ *  @brief This is init for node1.
+ * COPYRIGHT (C) 1989-1999 On-Line Applications Research Corporation (OAR).
+ * are met:
 #define CONFIGURE_MP_NODE_NUMBER 1
 #include "../../../support/init.c"
diff --git a/testsuites/ada/samples/base_mp/node2/init.c b/testsuites/ada/samples/base_mp/node2/init.c
index ea6db06..3cad39c 100644
--- a/testsuites/ada/samples/base_mp/node2/init.c
+++ b/testsuites/ada/samples/base_mp/node2/init.c
@@ -1,2 +1,35 @@
+ *  @file
+ *  @brief This is init for node2.
+ * are met:
 #define CONFIGURE_MP_NODE_NUMBER 2
1.8.3.1
