Building RTEMS 6 toolchain on a Mac
Fri Apr 22 12:06:09 UTC 2022
On 22/04/2022 08:55, Sebastian Huber wrote:
>> Could GCC be upgraded to 11.2 or 12.0 which should be available very
>> soon? are the patches still needed?
> It is still undecided which GCC version will be used for RTEMS 6. GCC 10
> will reach its end of life with the next release this year. GCC 12 would
> be brand new. We didn't use GCC 11 so far. I tend to use GCC 12.
I checked in some updates for the RSB. Could you please check if you can
build the RTEMS 7 tool chain which is based on GCC 12:
../source-builder/sb-set-builder 7/rtems-arm
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
