RTEMS-specific Newlib patches for aarch64
Fri Apr 22 12:28:10 UTC 2022
On 17/03/2022 13:30, Kinsey Moore wrote:
> On 3/17/2022 05:00, Sebastian Huber wrote:
>> Hello,
>> the current Newlib build fails for aarch64 due to RTEMS-specific patches:
>>   CC       libc/string/libc_a-wcscmp.o
>> ../../../gnu-mirror-gcc-0f001dd/newlib/libc/machine/aarch64/setjmp.S:29:10:
>> fatal error: ../asmdefs.h: No such file or directory
>>    29 | #include <../asmdefs.h>
>> Why are these patches not in upstream Newlib?
> The only patch I'm aware of should be for ILP32 support in the
> hand-coded AArch64 assembly in newlib.
> The short answer as to why the patch isn't upstream is that newlib
> hasn't committed it yet.
> The longer answer is that the hand-coded AArch64 ASM in newlib is
> sourced from ARM's optimized-routines repository. I provided a patch to
> newlib's specifications at which point they suggested I get it committed
> upstream in the optimized-routines repo, first. I did that and then
> requested they pull the changes, but they were in the middle of a
> release cycle. Having the patch locally was the interim solution while
> we waited for that release to finish and for newlib to pull in the
> changes. I'll take a look and see what the current status on that is and
> what changes prompted the patch to break.
I don't see open pull requests in
https://github.com/ARM-software/optimized-routines/pulls
What is the status with respect to a Newlib integration?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
