[PATCH] GDB: fix python config command line arguments based on python version
Frank Kühndel frank.kuehndel at embedded-brains.de
Fri Apr 22 13:18:44 UTC 2022
Hi Chris,
On 4/22/22 03:19, Chris Johns wrote:
> On 21/4/2022 5:45 pm, Karel Gardas wrote:
>> On 4/21/22 02:12, Chris Johns wrote:
>>> On 21/4/2022 4:38 am, Karel Gardas wrote:
>>>> Chris, Frank,
>>>> I don't feel particularly comfortable with this patch. It works here on Ubuntu
>>>> 20.04 with python 3.3 and Ubuntu 22.04 with Python 3.10, but I have to admit
>>>> semantics of this cfg language is beyond my liking and a lot is in complete
>>>> darkness here. E.g. how &&, < operator are working here. Delete both int
>>>> conversions and it'll not work at all. Keep one and it'll work well.
>>>> The problem is probably lack of time to go thorough all the docs on
>>>> docs.rtems.org to find relevant bits while working on the patch.
>>>> Anyway, if you have time, please review and test on your platforms.
>>> I think you are right to be concerned. I cannot find in the parser any support
>>> for `int()` which makes me wonder if `int(3)` is being compared but I am not
>>> sure.
>> Hmm. And I've thought cfg format is just DSL interpreted in python hence
>> translated internally to python hence my int() usage.
>>> Leave this with me and I will take a closer look.
>> Absolutely!
>>> I think we will need to add a
>>> numerical compare. Hmmm.
>> Another solution may be to enhance version string to print every number with two
>> digits and with leading zero if needed and concatenate string together. This may
>> probably work too even with lexi comparison.
>> E.g.
>> 2.7.1  -> "020701"
>> 2.7.17 -> "020717"
>> 3.9.2  -> "030902"
>> 3.10.3 -> "031003"
>> Hard to judge which approach is cleanest one.
> This breaks when we exceed 99 etc. Maybe that will happen, maybe it will not.
> I wonder if hacking the parser to handle this provides a more long term solution
> beyond this use case.
> The problem becomes adding support to the language. I wonder if checking if both
> the left and right hand sides in a compare are numeric, ie 3 or 3.0, and if they
> are make the comparison numeric? To force a lexicographical comparison simply
> have `%if x%{yyy} < 3.8`?
Do not exists simpler solutions than changing the language?
For example, calling `/usr/bin/python3-config --help` first. If the
result string contains `--embed` use it, else don't.
For example on OpenSUSE (Python 3.6.15):
$  /usr/bin/python3-config --help
Usage: /usr/bin/python3-config
--prefix|--exec-prefix|--includes|--libs|--cflags|--ldflags|--extension-suffix|--help|--abiflags|--configdir
On Fedora 35 (Python 3.10.4):
Usage: /usr/bin/python3.10-x86_64-config
--prefix|--exec-prefix|--includes|--libs|--cflags|--ldflags|--extension-suffix|--help|--abiflags|--configdir|--embed
Again OpenSUSE but Python 2.7.18:
$ /usr/bin/python2-config --help
Usage: /usr/bin/python2-config
[--prefix|--exec-prefix|--includes|--libs|--cflags|--ldflags|--help]
For example, the following command will either return "--embed" or empty
(the redirection of strerr is important for Python 2):
$ /usr/bin/python3-config --help 2>1 | grep --fixed-strings
--only-matching -e --embed
Greetings,
fk
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
