[PATCH v2 05/15] psxtests: Adding file headers and licenses
Ryan Long
ryan.long at oarcorp.com
Fri Apr 22 19:12:14 UTC 2022
These files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
testsuites/psxtests/psxchroot01/main.c | 35 ++++++++++++++++++++++++++++++++++
testsuites/psxtests/psxfatal01/init.c | 35 ++++++++++++++++++++++++++++++++++
testsuites/psxtests/psxfatal02/init.c | 35 ++++++++++++++++++++++++++++++++++
testsuites/psxtests/psxmount/main.c | 35 ++++++++++++++++++++++++++++++++++
testsuites/psxtests/psxreaddir/main.c | 35 ++++++++++++++++++++++++++++++++++
testsuites/psxtests/psxsignal03/init.c | 35 ++++++++++++++++++++++++++++++++++
testsuites/psxtests/psxsignal04/init.c | 35 ++++++++++++++++++++++++++++++++++
7 files changed, 245 insertions(+)
diff --git a/testsuites/psxtests/psxchroot01/main.c b/testsuites/psxtests/psxchroot01/main.c
index 2c1c489..ccb5609 100644
--- a/testsuites/psxtests/psxchroot01/main.c
+++ b/testsuites/psxtests/psxchroot01/main.c
@@ -1,3 +1,38 @@
+ * @file
+ * @ingroup psxtests
+ * @brief This is main for psxchroot01.
+ * Copyright (C) 1989-2012 On-Line Applications Research Corporation (OAR).
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
* Simple test program -- simplified version of sample test hello.
diff --git a/testsuites/psxtests/psxfatal01/init.c b/testsuites/psxtests/psxfatal01/init.c
index ffc5b35..8162b0e 100644
--- a/testsuites/psxtests/psxfatal01/init.c
+++ b/testsuites/psxtests/psxfatal01/init.c
@@ -1,3 +1,38 @@
+ * @file
+ * @brief This is init for psxfatal01.
+ * are met:
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
diff --git a/testsuites/psxtests/psxfatal02/init.c b/testsuites/psxtests/psxfatal02/init.c
index eaf9330..50dbd43 100644
--- a/testsuites/psxtests/psxfatal02/init.c
+++ b/testsuites/psxtests/psxfatal02/init.c
@@ -1,3 +1,38 @@
+ * @file
+ * @brief This is init for psxfatal02.
+ * are met:
#include "config.h"
#endif
diff --git a/testsuites/psxtests/psxmount/main.c b/testsuites/psxtests/psxmount/main.c
index cbac28d..7949ee0 100644
--- a/testsuites/psxtests/psxmount/main.c
+++ b/testsuites/psxtests/psxmount/main.c
@@ -1,3 +1,38 @@
+ * @file
+ * @brief This is main for psxmount.
+ * are met:
* Simple test program -- check out of the basic file system mounting
* capabilities
diff --git a/testsuites/psxtests/psxreaddir/main.c b/testsuites/psxtests/psxreaddir/main.c
index 238d8e9..50b2903 100644
--- a/testsuites/psxtests/psxreaddir/main.c
+++ b/testsuites/psxtests/psxreaddir/main.c
@@ -1,3 +1,38 @@
+ * @file
+ * @brief This is main for psxreaddir.
+ * are met:
diff --git a/testsuites/psxtests/psxsignal03/init.c b/testsuites/psxtests/psxsignal03/init.c
index bc9daf8..bf59ba0 100644
--- a/testsuites/psxtests/psxsignal03/init.c
+++ b/testsuites/psxtests/psxsignal03/init.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is init for psxsignal03.
+ * are met:
#define USE_USER_SIGNALS_PROCESS
#include "psxsignal0ximpl.h"
diff --git a/testsuites/psxtests/psxsignal04/init.c b/testsuites/psxtests/psxsignal04/init.c
index 4496341..80db780 100644
--- a/testsuites/psxtests/psxsignal04/init.c
+++ b/testsuites/psxtests/psxsignal04/init.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is init for psxsignal04.
+ * Copyright (C) 1989-2009 On-Line Applications Research Corporation (OAR).
+ * are met:
#define USE_REAL_TIME_SIGNALS_PROCESS
#include "../psxsignal03/psxsignal0ximpl.h"
1.8.3.1
