[PATCH v2 07/15] support: Manually adding file headers and licenses
Ryan Long ryan.long at oarcorp.com
Fri Apr 22 19:12:16 UTC 2022
This file had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
 testsuites/support/include/buffer_test_io.h | 36 +++++++++++++++++++++++++++++
 1 file changed, 36 insertions(+)
diff --git a/testsuites/support/include/buffer_test_io.h b/testsuites/support/include/buffer_test_io.h
index f0eae50..840dd51 100644
--- a/testsuites/support/include/buffer_test_io.h
+++ b/testsuites/support/include/buffer_test_io.h
@@ -1,3 +1,39 @@
+ *  @file
+ *  @ingroup support
+ *  @brief This is the buffer_test_io header file.
+ * Copyright (C) 1989-2011 On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2011 Chris Johns <chrisj at rtems.org>. All rights reserved.
+ * are met:
  *  Support for running the test output through a buffer
1.8.3.1
