[PATCH v2 11/15] ada/samples: Manually adding file headers and licenses
Ryan Long
ryan.long at oarcorp.com
Fri Apr 22 19:12:20 UTC 2022
These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
testsuites/ada/samples/base_mp/node1/init.c | 33 +++++++++++++++++++++++++++++
testsuites/ada/samples/base_mp/node2/init.c | 33 +++++++++++++++++++++++++++++
2 files changed, 66 insertions(+)
diff --git a/testsuites/ada/samples/base_mp/node1/init.c b/testsuites/ada/samples/base_mp/node1/init.c
index 073c033..21dd58a 100644
--- a/testsuites/ada/samples/base_mp/node1/init.c
+++ b/testsuites/ada/samples/base_mp/node1/init.c
@@ -1,2 +1,35 @@
+ * @file
+ * @brief This is init for node1.
+ * Copyright (C) 1989-1999 On-Line Applications Research Corporation (OAR).
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#define CONFIGURE_MP_NODE_NUMBER 1
#include "../../../support/init.c"
diff --git a/testsuites/ada/samples/base_mp/node2/init.c b/testsuites/ada/samples/base_mp/node2/init.c
index ea6db06..d5a8b78 100644
--- a/testsuites/ada/samples/base_mp/node2/init.c
+++ b/testsuites/ada/samples/base_mp/node2/init.c
@@ -1,2 +1,35 @@
+ * @file
+ * @brief This is init for node2.
+ * are met:
#define CONFIGURE_MP_NODE_NUMBER 2
1.8.3.1
