Building RTEMS 6 toolchain on a Mac
Wed Apr 27 04:51:08 UTC 2022
On 27/4/2022 2:46 pm, Sebastian Huber wrote:
> On 26.04.22 22:57, Karel Gardas wrote:
>> On 4/25/22 10:10, Sebastian Huber wrote:
>>> Hello Heinz,
>>> you are probably one of the first persons building GCC 12 on this platform. I
>>> checked in a change which could fix the problem.
>> Not sure if this is related, but after this hacking I'm no longer able to
>> build neither 6/rtems-arm not 6/rtems-x86_64.
> I changed the mpfr version from 3.1.4 to 4.1.0. This is the latest mpfr release
> and used by the GCC contrib/download_prerequisites script currently. If this
> version doesn't build on macOS, then it would be good to submit a bug report to
> mpfr.
Can we please revert to 3.1.4 while this is resolved?
Thanks
