Building RTEMS 6 toolchain on a Mac
Chris Johns
chrisj at rtems.org
Wed Apr 27 05:46:43 UTC 2022
On 27/4/2022 3:18 pm, Sebastian Huber wrote:
> On 27.04.22 06:51, Chris Johns wrote:
>> On 27/4/2022 2:46 pm, Sebastian Huber wrote:
>>> On 26.04.22 22:57, Karel Gardas wrote:
>>>> On 4/25/22 10:10, Sebastian Huber wrote:
>>>>> Hello Heinz,
>>>>> you are probably one of the first persons building GCC 12 on this platform. I
>>>>> checked in a change which could fix the problem.
>>>> Not sure if this is related, but after this hacking I'm no longer able to
>>>> build neither 6/rtems-arm not 6/rtems-x86_64.
>>> I changed the mpfr version from 3.1.4 to 4.1.0. This is the latest mpfr release
>>> and used by the GCC contrib/download_prerequisites script currently. If this
>>> version doesn't build on macOS, then it would be good to submit a bug report to
>>> mpfr.
>> Can we please revert to 3.1.4 while this is resolved?
> Yes, of course,
Thanks
> but I will not work on bug reports or fixes for macOS.
That is fine and understood.
