Building RTEMS 6 toolchain on a Mac
Wed Apr 27 06:48:18 UTC 2022
On 27.04.22 08:45, Karel Gardas wrote:
> On 4/27/22 06:46, Sebastian Huber wrote:
>> On 26.04.22 22:57, Karel Gardas wrote:
>>> On 4/25/22 10:10, Sebastian Huber wrote:
>>>> Hello Heinz,
>>>> you are probably one of the first persons building GCC 12 on this
>>>> platform. I checked in a change which could fix the problem.
>>> Not sure if this is related, but after this hacking I'm no longer
>>> able to build neither 6/rtems-arm not 6/rtems-x86_64.
>> I changed the mpfr version from 3.1.4 to 4.1.0. This is the latest
>> mpfr release and used by the GCC contrib/download_prerequisites script
>> currently. If this version doesn't build on macOS, then it would be
>> good to submit a bug report to mpfr.
> The problem is that I'm perfectly able to build 4.1.0 including
> testsuite including its run on catalina. So the problem is somewhere
> else and rsb logging was just misleading...
The RTEMS 7 RSB configuration still uses mpfr-4.1.0 (and GCC 12), maybe
you can check it here.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
