[PATCH v2 12/12] testsuites/sptests: Add sppps01 test
Gabriel Moyano gabriel.moyano at dlr.de
Fri Apr 29 07:20:51 UTC 2022
 spec/build/testsuites/sptests/grp.yml     |   2 +
 spec/build/testsuites/sptests/sppps01.yml |  19 +++
 testsuites/sptests/sppps01/init.c         | 160 ++++++++++++++++++++++
 3 files changed, 181 insertions(+)
 create mode 100644 spec/build/testsuites/sptests/sppps01.yml
 create mode 100644 testsuites/sptests/sppps01/init.c
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index a69a4d20f7..3264ba5450 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -349,6 +349,8 @@ links:
   uid: sppercpudata01
 - role: build-dependency
   uid: spporterr01
+- role: build-dependency
+  uid: sppps01
   uid: spprintk
diff --git a/spec/build/testsuites/sptests/sppps01.yml b/spec/build/testsuites/sptests/sppps01.yml
new file mode 100644
index 0000000000..55770eceb9
--- /dev/null
+++ b/spec/build/testsuites/sptests/sppps01.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 German Aerospace Center (DLR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sppps01/init.c
+stlib: []
+target: testsuites/sptests/sppps01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/sptests/sppps01/init.c b/testsuites/sptests/sppps01/init.c
index 0000000000..b36c25ae65
--- /dev/null
+++ b/testsuites/sptests/sppps01/init.c
@@ -0,0 +1,160 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 German Aerospace Center (DLR)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test.h>
+#include <rtems/test-info.h>
+#include <rtems/timespec.h>
+#include <rtems/rtems/event.h>
+#define _KERNEL
+#include <sys/timepps.h>
+const char rtems_test_name[] = "SPPPS 1";
+#define PPS_EVENT RTEMS_EVENT_0
+#define TASK_WAITING RTEMS_EVENT_1
+#define PPS_EVENT_RECEIVED RTEMS_EVENT_2
+typedef struct {
+  rtems_id main_task;
+  struct pps_state *pps;
+} test_context;
+static void wakeup(struct pps_state *pps)
+  if (pps->task_waiting != RTEMS_INVALID_ID)
+    rtems_event_send( pps->task_waiting, PPS_EVENT );
+static int wait(struct pps_state *pps, struct timespec timeout)
+  rtems_status_code sc;
+  rtems_event_set out;
+  pps->task_waiting = rtems_task_self();
+  uint32_t timeoutticks = rtems_timespec_to_ticks(&timeout);
+  sc = rtems_event_receive( PPS_EVENT, RTEMS_DEFAULT_OPTIONS, timeoutticks, &out );
+  return rtems_status_code_to_errno(sc);
+static void pps_task(rtems_task_argument arg)
+  int status;
+  test_context *ctx;
+  ctx = (test_context *) arg;
+  struct pps_fetch_args fetch;
+  fetch.tsformat = PPS_TSFMT_TSPEC;
+  fetch.timeout.tv_sec = 1;
+  fetch.timeout.tv_nsec = 0;
+  sc = rtems_event_send( ctx->main_task, TASK_WAITING );
+  T_rsc_success( sc );
+  status = pps_ioctl( PPS_IOC_FETCH, (caddr_t)&fetch, ctx->pps );
+  T_eq_int( status, 0 );
+  sc = rtems_event_send( ctx->main_task, PPS_EVENT_RECEIVED );
+  rtems_task_delete(rtems_task_self());
+T_TEST_CASE( PPS )
+  int status;
+  struct pps_state pps;
+  memset( &pps, 0, sizeof( pps ) );
+  pps.ppscap = PPS_CAPTUREBOTH;
+  pps.wait = wait;
+  pps.wakeup = wakeup;
+  pps_init_abi( &pps );
+  pps.ppsparam.mode = PPS_CAPTUREASSERT;
+  struct pps_kcbind_args kcbind;
+  kcbind.kernel_consumer = PPS_KC_HARDPPS;
+  kcbind.edge = PPS_CAPTUREASSERT;
+  kcbind.tsformat = PPS_TSFMT_TSPEC;
+  status = pps_ioctl( PPS_IOC_KCBIND, (caddr_t)&kcbind, &pps );
+  /* Save current timecounter in pps_state object */
+  pps_capture( &pps );
+  pps_event( &pps, PPS_CAPTUREASSERT );
+  test_context ctx;
+  ctx.pps = &pps;
+  ctx.main_task = rtems_task_self();
+  rtems_id pps_task_id;
+  rtems_task_priority pps_task_prio = 1;
+  sc = rtems_task_create(
+    rtems_build_name('P', 'P', 'S', 'E'),
+    pps_task_prio,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &pps_task_id
+  sc = rtems_task_start( pps_task_id, pps_task, (rtems_task_argument) &ctx );
+  sc = rtems_event_receive( TASK_WAITING, RTEMS_DEFAULT_OPTIONS, RTEMS_MILLISECONDS_TO_TICKS(100), &out );
+  /* Capture event and send wake-up */
+  sc = rtems_event_receive( PPS_EVENT_RECEIVED, RTEMS_DEFAULT_OPTIONS, RTEMS_MILLISECONDS_TO_TICKS(100), &out );
+static rtems_task Init( rtems_task_argument argument )
+  rtems_test_run( argument, TEST_STATE );
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
2.25.1
