[PATCH] posix: Fix relative CLOCK_REALTIME sleep
Chris Johns
chrisj at rtems.org
Mon Aug 1 08:48:04 UTC 2022
On 1/8/2022 6:20 pm, Sebastian Huber wrote:
> On 01/08/2022 10:16, Chris Johns wrote:
>> On 1/8/2022 5:22 pm, Sebastian Huber wrote:
>>> A relative CLOCK_REALTIME time out shall not be affected by CLOCK_REALTIME
>>> changes through clock_settime(). Since our CLOCK_REALTIME is basically just
>>> CLOCK_MONOTONIC plus an offset, we can simply use the CLOCK_MONOTONIC watchdog
>>> for relative CLOCK_REALTIME time outs.
>> Thank for this. I can confirm it works with the modified test code I attached to
>> the ticket. I am ts-validation-no-clock-0.exe now failing on xilinx_zynq_a9_qemu
>> but I am not sure?
> I have to adjust the ts-validation-no-clock-0.exe if we want to fix the issue
> like this.
>> There is one issue my test changes have exposed and that is the ticks a thread
>> sleeps for is 1 more than the requested number.
> I think this is the expected behaviour. You should sleep at least the requested
> amount of time.
I am using 500msec so I would expect the result to be exact? If it was 501msec
then I would agree.
