[PATCH v5 1/4] bsps/stm32f4 Include STM32F4 HAL
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Aug 2 05:26:38 UTC 2022
Hello Duc,
Am 02.08.22 um 05:00 schrieb Duc Doan:
> Hello Christian,
> On Mon, 2022-08-01 at 20:32 +0200, oss at c-mauderer.de wrote:
>> Hello Duc,
>> Am 01.08.22 um 04:13 schrieb Duc Doan:
>>> Hello Christian,
>>> On Sun, 2022-07-31 at 20:01 +0200, oss at c-mauderer.de wrote:
>>>> Hello Duc,
>>>> Am 31.07.22 um 17:07 schrieb Duc Doan:
>>>>> Hello Christian,
>>>>> On Sat, 2022-07-30 at 16:32 +0200, oss at c-mauderer.de wrote:
>>>>>> Hello Duc,
>>>>>> general note for the patch: Please write in the commit
>>>>>> message
>>>>>> where
>>>>>> you
>>>>>> got the sources from. That can be a link to a github repo
>>>>>> including a
>>>>>> commit ID or a link to the zip file from ST (including a
>>>>>> date,
>>>>>> version
>>>>>> or similar information). If you moved some stuff around
>>>>>> compared
>>>>>> to
>>>>>> the
>>>>>> original structure: Please describe about what you did. For
>>>>>> example
>>>>>> in
>>>>>> the imxrt I just added the cp commands that I used:
>>>>>> https://git.rtems.org/rtems/commit/bsps/arm/imxrt?id=48f6a6c302a3e1a3f8915e2503d0fe618d1af285
>>>>>> Not the best solution but at least someone else can find out
>>>>>> roughly
>>>>>> what I did.
>>>>> Ah yes, I will do that. I thought I only needed to put the
>>>>> description
>>>>> in the email before.
>>>>>> Am 24.07.22 um 14:01 schrieb Duc Doan:
>>>>>>> This patch is too large so I cannot send via email. Please
>>>>>>> find
>>>>>>> it
>>>>>>> here:
>>>>>>> https://github.com/dtbpkmte/GSoC-2022-RTEMS/commit/6f1fbc7dd7a5e0877d8bff11e1b21558928dbc16
>>>>>>>      .gitignore                                    |     1 +
>>>>>> You added a "patches" directory to the gitignore. That looks
>>>>>> like
>>>>>> a
>>>>>> change that is specific to your method of working. These kind
>>>>>> of
>>>>>> changes
>>>>>> should normall not be pushed.
>>>>>> If you want to ignore stuff specific to your work
>>>>>> environment, I
>>>>>> recommend to use a global .gitignore file. Git has a
>>>>>> "core.excludesfile"
>>>>>> config for that.
>>>>> Thanks for the suggestion, I will fix that.
>>>>>>>      bsps/arm/include/cmsis_compiler.h             |   266 +
>>>>>>>      bsps/arm/include/cmsis_gcc.h                  |  3460
>>>>>>>      bsps/arm/include/cmsis_version.h              |    39 +
>>>>>>>      bsps/arm/include/core_cm4.h                   |   524
>>>>>>>      bsps/arm/include/core_cm7.h                   |  5186
>>>>>>>      bsps/arm/include/mpu_armv7.h                  |   270 +
>>>>>> Are the cmsis files from the same source or directly from
>>>>>> ARM?
>>>>> They are from the same source (STM HAL v1.27.1).
>>>>>> The cmsis_gcc.h has a lot of changes compared to the earlier
>>>>>> version
>>>>>> that has been present in RTEMS. A lot of the changes seem to
>>>>>> be
>>>>>> whitespace changes. Can these be avoided somehow (for example
>>>>>> by
>>>>>> using
>>>>>> dos2unix before overwriting the file)?
>>>>>   From what I've just read about dos2unix, it converts line
>>>>> breaks
>>>>> from
>>>>> CRLF to LF (please correct me if I'm wrong). How will this
>>>>> command
>>>>> resolve the whitespace changes?
>>>> I haven't looked at the exact type of whitespace changes. I had
>>>> the
>>>> impression that the difference is most likely only the line
>>>> ending.
>>>> It
>>>> didn't look like tab / space issue. Is it a tab / space issue?
>>> I've looked at the some files and noticed that the difference is
>>> mostly
>>> additional code/code change (e.g. adding support for ARMv8), but
>>> not
>>> whitespace changes.
>> Hm. Odd. In that case: Why does the diff show a complete removal and
>> complete adding of (for example) cmsis_gcc.h:
>> https://github.com/dtbpkmte/GSoC-2022-RTEMS/commit/6f1fbc7dd7a5e0877d8bff11e1b21558928dbc16#diff-9632086ec773f52fc69a99f2d7fad711c51aad138e6449e01b4737f80201d185
> I'm not sure why that happens. I used this page to compare line-by-
> line: https://www.diffchecker.com/xMCBtxbt This is the diff for
> cmsis_gcc.
That page most likely ignores line endings. Try it with `file` or
`dos2unix -i`:
sh> git co master
sh> file bsps/arm/include/cmsis_gcc.h
bsps/arm/include/cmsis_gcc.h: C source, ASCII text, with CRLF, LF line
terminators
sh> dos2unix -i bsps/arm/include/cmsis_gcc.h
     1374       1       0  no_bom    text    bsps/arm/include/cmsis_gcc.h
sh> git co duc/master
        0    2085       0  no_bom    text    bsps/arm/include/cmsis_gcc.h
sh>
The three numbers of dos2unix output is (in this order): Number of DOS
line endings, number of UNIX line endings, number of MAC line endings.
So line endings changed from CRLF to only LF. Either make that two steps
(first changing the old one to LF in one commit and then updating it in
another) or change the new file to use the CRLF format of the old one.
Best regards
Christian
> Best,
> Duc
>>>>>> In the discord chat there was one suggestion from Ho Kaido to
>>>>>> move
>>>>>> the
>>>>>> files one level down and make them BSP specific. I'm not sure
>>>>>> whether
>>>>>> I'm for or against that idea. Advantage is that it makes BSPs
>>>>>> independant from each other. Disadvantage is that it
>>>>>> duplicates
>>>>>> code.
>>>>>> I think I would try to avoid moving them down due to the code
>>>>>> duplication but it raises the question: Which BSPs use the
>>>>>> files
>>>>>> too
>>>>>> and
>>>>>> did you try whether they still compile after the upgrade?
>>>>> Until now I only know of STM32H7 BSP that is using the CMSIS
>>>>> files.
>>>>> I
>>>>> tried compiling it before and Karel also confirmed that the BSP
>>>>> compiles.
>>>> Just as an example: core_cm4/7.h is included at least in stm32f4,
>>>> stm32h7, atsam and imxrt. So we have to make sure that these
>>>> three
>>>> are
>>>> compile-clean. Please use grep to find out where the headers are
>>>> included and check whether I maybe missed a BSP.
>>> I have checked using grep (grep -rl ~/gsoc2022/src/rtems/bsps/arm -
>>> e
>>> "cmsis\|core_cm" and found that stm32f4, imxrt, stm32h7, and atsam
>>> are
>>> using CMSIS files (you remembered all correctly!). I've checked and
>>> all
>>> 4 of them compile without error.
>> Great. Thanks for checking.
>> Best regards
>> Christian
>>> Best,
>>> Duc
>>>>>>>      .../stm32f4/hal/Legacy/stm32f4xx_hal_can.c    |  1679
>>>>>>>      .../stm32f4/hal/Legacy/stm32f4xx_hal_eth.c    |  2307
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal.c          |   615 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c      |  2110
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c   |  1112 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c      |  2462
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c      |   996 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c   |   502 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c      |   328 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c     |  7132
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c  |   680 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c      |  1341 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c   |   495 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c     |  1161 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c  |   182 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c    |  4423
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c      |  1305 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c    |  2126
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c   |   313 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c      |  2760
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c      |  3220
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c     |   547 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c    |   775 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c |  1347 +
>>>>>>>      .../stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c |   172 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c   |  6864
>>>>>>>      .../arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c |   258 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c |  2749
>>>>>>>      .../stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c   |   145 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c     |   533 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c     |  3514
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c  |  1040 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c      |  1728
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c      |  7524
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c   |   182 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c      |  2094
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c   |  1135 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c     |  2687
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c     |   262 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c    |  2484
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c     |  2215
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c  |   151 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c      |  3201
>>>>>>>      .../stm32f4/hal/stm32f4xx_hal_msp_template.c  |   100 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c     |  2405
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c      |  1543
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c   |   946 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c      |  2387
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c   |   341 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c      |   571 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c   |   600 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c     |  2915
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c      |  1122 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c   |  3784
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c      |   867 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c      |  1896
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c   |  1878
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c      |  2554
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c   |   310 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c       |  3277
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c    |  1308 +
>>>>>>>      .../arm/stm32f4/hal/stm32f4xx_hal_smartcard.c |  2364
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c    |  2784
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c  |  1627
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c      |  3915
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c     |  1110 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c      |  7621
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c   |  2428
>>>>>>>      ...tm32f4xx_hal_timebase_rtc_alarm_template.c |   318 +
>>>>>>>      ...m32f4xx_hal_timebase_rtc_wakeup_template.c |   293 +
>>>>>>>      .../hal/stm32f4xx_hal_timebase_tim_template.c |   177 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c     |  3751
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c    |  2838
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c     |   420 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c       |   922 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c       |   103 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c       |   280 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c       |   423 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c     |   594 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c      |   212 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c       |  1498
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c    |   217 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c      |  1062 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c      |   303 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c       |   251 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c     |   301 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c       |    81 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c       |  1660
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c       |   111 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c       |   838 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c     |  1578
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c       |   624 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c       |  1189 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c     |   500 +
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c       |  2224
>>>>>>>      bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c     |   749 +
>>>>>>>      bsps/arm/stm32f4/hal/system_stm32f4xx.c       |   747 +
>>>>>>>      .../stm32f4/include/Legacy/stm32_hal_legacy.h |  4014
>>>>>>>      .../include/Legacy/stm32f4xx_hal_can_legacy.h |   765 +
>>>>>>>      .../include/Legacy/stm32f4xx_hal_eth_legacy.h |  2209
>>>>>>>      bsps/arm/stm32f4/include/bsp.h                |     4 +
>>>>>>>      bsps/arm/stm32f4/include/bsp/io.h             |     4 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f401xc.h        |  8641
>>>>>>>      bsps/arm/stm32f4/include/stm32f401xe.h        |  8641
>>>>>>>      bsps/arm/stm32f4/include/stm32f405xx.h        | 14310
>>>>>>>      bsps/arm/stm32f4/include/stm32f407xx.h        | 15607
>>>>>>>      bsps/arm/stm32f4/include/stm32f410cx.h        |  7357
>>>>>>>      bsps/arm/stm32f4/include/stm32f410rx.h        |  7361
>>>>>>>      bsps/arm/stm32f4/include/stm32f410tx.h        |  7306
>>>>>>>      bsps/arm/stm32f4/include/stm32f411xe.h        |  8680
>>>>>>>      bsps/arm/stm32f4/include/stm32f412cx.h        | 13507
>>>>>>>      bsps/arm/stm32f4/include/stm32f412rx.h        | 14500
>>>>>>>      bsps/arm/stm32f4/include/stm32f412vx.h        | 14512
>>>>>>>      bsps/arm/stm32f4/include/stm32f412zx.h        | 14537
>>>>>>>      bsps/arm/stm32f4/include/stm32f413xx.h        | 15462
>>>>>>>      bsps/arm/stm32f4/include/stm32f415xx.h        | 14595
>>>>>>>      bsps/arm/stm32f4/include/stm32f417xx.h        | 15887
>>>>>>>      bsps/arm/stm32f4/include/stm32f423xx.h        | 15615
>>>>>>>      bsps/arm/stm32f4/include/stm32f427xx.h        | 16827
>>>>>>>      bsps/arm/stm32f4/include/stm32f429xx.h        | 17185
>>>>>>>      bsps/arm/stm32f4/include/stm32f437xx.h        | 17129
>>>>>>>      bsps/arm/stm32f4/include/stm32f439xx.h        | 17479
>>>>>>>      bsps/arm/stm32f4/include/stm32f446xx.h        | 15981
>>>>>>>      bsps/arm/stm32f4/include/stm32f469xx.h        | 20278
>>>>>>>      bsps/arm/stm32f4/include/stm32f479xx.h        | 20575
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx.h          |   305 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal.h      |   297 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h  |   898 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_adc_ex.h    |   407 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_can.h  |   844 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h  |   792 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h |   506 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_cortex.h    |   407 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h  |   181 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h |   683 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_cryp_ex.h   |   142 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h  |   480 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_dac_ex.h    |   205 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h |   563 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_dcmi_ex.h   |   208 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_def.h  |   210 +
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_hal_dfsdm.h |  1141 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h  |   802 +
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_hal_dma2d.h |   638 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_dma_ex.h    |   102 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h  |  1377
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h  |  2144
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h |   366 +
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_hal_flash.h |   425 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_flash_ex.h  |  1063 +
>>>>>>>      .../include/stm32f4xx_hal_flash_ramfunc.h     |    76 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_fmpi2c.h    |   837 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h |   150 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_fmpsmbus.h  |   790 +
>>>>>>>      .../include/stm32f4xx_hal_fmpsmbus_ex.h       |   136 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h |   325 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_gpio_ex.h   |  1590
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h |   634 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_hash_ex.h   |   175 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h  |   316 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h  |   741 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_i2c_ex.h    |   115 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h  |   618 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_i2s_ex.h    |   183 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h |   682 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h |   220 +
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_hal_lptim.h |   857 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h |   719 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_ltdc_ex.h   |    83 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h  |   747 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h |   388 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h  |   330 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_pccard.h    |   285 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h  |   459 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_pcd_ex.h    |    88 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h  |   427 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_pwr_ex.h    |   340 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h |   750 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h  |  1459
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_rcc_ex.h    |  7111
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h  |   361 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h  |   915 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_rtc_ex.h    |  1079 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h  |   895 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_sai_ex.h    |   114 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h   |   758 +
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_hal_sdram.h |   238 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_smartcard.h |   755 +
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_hal_smbus.h |   731 +
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_spdifrx.h   |   604 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h  |   729 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h |   236 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h  |  2146
>>>>>>>      .../stm32f4/include/stm32f4xx_hal_tim_ex.h    |   354 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h |   884 +
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_hal_usart.h |   648 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h |   298 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h   |  4779
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h   |  2105
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_ll_cortex.h |   637 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h   |   201 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h   |  1455
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h   |  2868
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h |  1901
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h  |   954 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h   |  1416
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h |  2234
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h  |  1086 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h  |   981 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h   |  1890
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h  |   302 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h |  1378
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h   |   985 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h   |  7096
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h   |   335 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h   |  3663
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h |  1141 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h   |  2027
>>>>>>>      .../arm/stm32f4/include/stm32f4xx_ll_system.h |  1711
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h   |  4093
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h |  2521
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h   |   536 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h |   307 +
>>>>>>>      bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h  |   316 +
>>>>>>>      bsps/arm/stm32f4/include/system_stm32f4xx.h   |   104 +
>>>>>> You most likely noted the long discussion on Discord between
>>>>>> Andrei
>>>>>> of
>>>>>> the North and me regarding how the hal could be made more
>>>>>> application-friendly. @Andrei: Do you think the headers
>>>>>> should be
>>>>>> moved
>>>>>> into a subdirectory to make them simpler to avoid in the
>>>>>> application?
>>>>>>>      bsps/arm/stm32f4/start/bspstart.c             |   202
>>>>>>>      bsps/arm/stm32f4/start/bspstart_old.c         |   297 +
>>>>>>>      spec/build/bsps/arm/grp.yml                   |     5
>>>>>>>      spec/build/bsps/arm/stm32f4/grp.yml           |    12
>>>>>>>      spec/build/bsps/arm/stm32f4/obj.yml           |   220 +
>>>>>>>      spec/build/bsps/arm/stm32f4/optenhal.yml      |    16 +
>>>>>>>      spec/build/bsps/arm/stm32f4/opthse.yml        |    17 +
>>>>>>>      spec/build/bsps/arm/stm32f4/optusehse.yml     |    16 +
>>>>>>>      spec/build/bsps/arm/stm32f4/optvariant.yml    |    24 +
>>>>>>>      spec/build/bsps/obj.yml                       |     1 +
>>>>>> Did the HAL files compile completely without change? If yes,
>>>>>> it
>>>>>> is OK
>>>>>> if
>>>>>> you add them to the yml file right here. Otherwise I would
>>>>>> suggest to
>>>>>> make two to three smaller steps:
>>>>>> - Add the unchanged files. Don't add them to the build yet so
>>>>>> that
>>>>>> the
>>>>>> commit would still compile without problems.
>>>>>> - Add necessary changes.
>>>>>> - Add the files to the build.
>>>>>> That makes it simpler to find out what you might had to
>>>>>> change to
>>>>>> make
>>>>>> the files compile and port the changes to a newer version.
>>>>> The HAL files compile completely without changes. However, in
>>>>> one
>>>>> file
>>>>> (stm32f4xx.h), I included bspopts.h. I can split it into 2
>>>>> commits.
>>>> Would be great if you could split that.
>>>> Best regards
>>>> Christian
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
