[PATCH] cpukit/dev/can: Added CAN support
oss at c-mauderer.de
Tue Aug 2 17:49:23 UTC 2022
Hello Duc,
general note: You add an API to cpukit. Most APIs there should have a
test case in the testsuite. In this case the test case would have to
create some dummy CAN driver and check whether everything works like
expected. As an example take a look at the SPI test:
https://git.rtems.org/rtems/tree/testsuites/libtests/spi01/init.c
It creates a dummy device and checks whether the SPI layer does
everything as expected. Would be great if you could add something like
this. Target of such a test should be more or less that every branch in
your code is triggered at least once (code coverage). It doesn't has to
be every combination but it shows that the code is at least reachable
and works as expected.
Am 31.07.22 um 13:53 schrieb Prashanth S:
> cpukit/dev/can/can.c | 514 +++++++++++++++++++++++++++++
> cpukit/include/dev/can/can-msg.h | 55 +++
> cpukit/include/dev/can/can-queue.h | 127 +++++++
> cpukit/include/dev/can/can.h | 102 ++++++
> spec/build/cpukit/librtemscpu.yml | 6 +
> 5 files changed, 804 insertions(+)
> create mode 100644 cpukit/dev/can/can.c
> create mode 100644 cpukit/include/dev/can/can-msg.h
> create mode 100644 cpukit/include/dev/can/can-queue.h
> create mode 100644 cpukit/include/dev/can/can.h
> diff --git a/cpukit/dev/can/can.c b/cpukit/dev/can/can.c
> new file mode 100644
> index 0000000000..8feec8800b
> --- /dev/null
> +++ b/cpukit/dev/can/can.c
> @@ -0,0 +1,514 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup CANBus
> + * @brief Controller Area Network (CAN) Bus Implementation
> + * Copyright (C) 2022 Prashanth S (fishesprashanth at gmail.com)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <rtems/imfs.h>
> +#include <rtems/thread.h>
> +#include <dev/can/can-queue.h>
> +#include <dev/can/can.h>
> +#include <string.h>
> +#include <stdlib.h>
> +#include <fcntl.h>
> +static ssize_t
> +can_bus_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode);
> +static ssize_t
> +can_bus_read(rtems_libio_t *iop, void *buffer, size_t count);
> +static ssize_t
> +can_bus_write(rtems_libio_t *iop, const void *buffer, size_t count);
> +static ssize_t
> +can_bus_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer);
> +static int can_xmit(struct can_bus *bus);
> +static int can_create_sem(struct can_bus *);
> +static int try_sem(struct can_bus *);
> +static int take_sem(struct can_bus *);
> +static int give_sem(struct can_bus *);
> +/* sem_count this is for debug purpose, for debugging
> +the take_sem and give_sem
> +static int sem_count = 0;
> +static void can_bus_obtain(can_bus *bus)
> + rtems_recursive_mutex_lock(&bus->mutex);
> +static void can_bus_release(can_bus *bus)
> + rtems_recursive_mutex_unlock(&bus->mutex);
> +int can_create_sem(struct can_bus *bus)
> + int ret = 0;
> + ret = rtems_semaphore_create(rtems_build_name('c', 'a', 'n', bus->index),
> + CAN_TX_BUF_COUNT, RTEMS_FIFO | RTEMS_COUNTING_SEMAPHORE | RTEMS_LOCAL,
> + 0, &bus->tx_fifo_sem_id);
> + if (ret != 0) {
> + printf("can_create_sem: rtems_semaphore_create failed %d\n", ret);
> + return ret;
> +static void can_interrupt_lock_acquire(struct can_bus *bus)
> + can_bus_obtain(bus);
> + bus->can_dev_ops->dev_int(bus->priv, false);
> +static void can_interrupt_lock_release(struct can_bus *bus)
> + bus->can_dev_ops->dev_int(bus->priv, true);
> + can_bus_release(bus);
> +static int take_sem(struct can_bus *bus)
> + int ret = rtems_semaphore_obtain(bus->tx_fifo_sem_id, RTEMS_WAIT,
> + RTEMS_NO_TIMEOUT);
> + if (ret == RTEMS_SUCCESSFUL) {
> + CAN_DEBUG_LOCK("take_sem: Counting semaphore count = %d\n", ++sem_count);
Do you really mean "LOCK" or should it be a "LOG"? Both is reasonable
here so I'm not entirely sure. But you use the LOCK macro also in
can_xmit and similar so I'm a bit unsure.
> + if (sem_count > CAN_TX_BUF_COUNT) {
If you increment sem_count only in a debug macro, you must not use it
for any other code. The macro is processed by the preprocessor. So if
you define the CAN_DEBUG_LOCK to something empty, the ++sem_count from
above will never happen. If CAN_DEBUG_LOCK interpretes the argument
twice, you will get the wrong value.
Please note: It's in general a good idea not to use anything that
changes a variable or has any side effect in a macro. For example if I
define the following
#define SQUARE(x) ((x) * (x))
And use it like this:
int a = 2;
int b;
b = SQUARE(++a);
The result that I would expect from reading the code would be that b is
9 and a is 3 afterwards. But instead I will get b = 16 and a = 4. The
reason for this is that the preprocessor will replace the code with the
following one:
int a = 2;
int b;
b = ((++a) * (++a));
Therefore: Try to avoid statements with a side effect as a parameter to
something if you are not 100% sure that the something is a function or
is allways executed. You don't have to save lines. We don't have a limit
on the maximum lines in a file. Readability is much more important than
compact code.
PS: Also true for "if". I wouldn't be sure whether the printf in the
following code will be executed:
if (0 || printf("Will someone call me?")) {
In general: Try to avoid anything where you have to think about the
order of execution except if you can't avoid it or if it is really obvious.
> + printf("take_sem error: sem_count is misleading\n");
> + while (1);
> + return ret;
> +static int give_sem(struct can_bus *bus)
> + int ret = rtems_semaphore_release(bus->tx_fifo_sem_id);
> + CAN_DEBUG_LOCK("give_sem: Counting semaphore count = %d\n", --sem_count);
> + if (sem_count < 0) {
> + printf("give_sem error: sem_count is misleading\n");
> + while (1);
> + return ret;
> +static int try_sem(struct can_bus *bus)
> + int ret = rtems_semaphore_obtain(bus->tx_fifo_sem_id, RTEMS_NO_WAIT,
> + while (1);
> + return ret;
> +static ssize_t
> + can_bus *bus = IMFS_generic_get_context_by_iop(iop);
> + if (bus == NULL) {
> + return -RTEMS_NOT_DEFINED;
> + return 0;
> +int can_receive(struct can_bus *bus, struct can_msg *msg)
> + int32_t ret = 0;
> + uint32_t count = 0;
> + ret = rtems_message_queue_broadcast(bus->rx_queue_id, msg, CAN_MSGLEN(msg),
> + &count);
> + if (ret != RTEMS_SUCCESSFUL) {
> + CAN_DEBUG_RX("rtems_message_queue_send failed\n");
> + CAN_DEBUG_RX("rtems_message_queue_broadcast = %u\n", count);
> + return ret;
> +/* count argument is not used here as struct can_msg has the dlc member */
> +static ssize_t can_bus_read(rtems_libio_t *iop, void *buffer, size_t count)
> + int32_t ret = 0;
> + uint32_t flags = 0;
> + if (bus == NULL || bus->can_dev_ops->dev_rx == NULL) {
> + struct can_msg *msg = (struct can_msg *)buffer;
> + if ((iop->flags & O_NONBLOCK) != 0) {
> + flags = RTEMS_NO_WAIT;
> + ret = rtems_message_queue_receive(bus->rx_queue_id, (void *)msg, &count,
> + flags, 0);
> + return ret;
> + return count;
> + int ret = RTEMS_SUCCESSFUL;
> + struct can_msg *msg = NULL;
> + while (1) {
> + CAN_DEBUG_LOCK("can_xmit: acquiring lock\n");
> + can_interrupt_lock_acquire(bus);
> + ret = bus->can_dev_ops->dev_tx_ready(bus->priv);
> + if (ret != true) {
> + goto return_with_lock_release;
> + msg = can_tx_get_data_buf(bus);
> + if (msg == NULL) {
> + ret = bus->can_dev_ops->dev_tx(bus->priv, msg);
> + printf("can_xmit: dev_send failed\n");
> + ret = give_sem(bus);
> + printf("can_tx_done: rtems_semaphore_release failed = %d\n", ret);
> + CAN_DEBUG_LOCK("can_xmit: releasing lock\n");
> + can_interrupt_lock_release(bus);
> + //can_tx_done(bus);
> + return ret;
If I see it correctly, you can never reach this return. You have a
while(1) without any break condition. By the way: Code with goto, loops
and break tends to get sphaghetti code. You should only use these
constructions if it improves readability compared to a solution without
these.
> +return_with_lock_release:
> + return ret;
> +void can_print_msg(struct can_msg const *msg)
> + printf("\n----------------------------------------------------------------\n");
> + printf("id = %d len = %d flags = 0x%08X\n", msg->id, msg->len, msg->flags);
> + for (int i = 0; i < msg->len; i++) {
> + printf("%02x ", msg->data[i]);
> + printf("\n-----------------------------------------------------------------\n");
> +/* can_tx_done should be called only with interrupts disabled */
> +int can_tx_done(struct can_bus *bus)
> + int ret = 0;
> + if (bus->can_dev_ops->dev_tx_ready(bus->priv) == true) {
> + can_xmit(bus);
> + return ret;
> +static ssize_t
> + if (bus == NULL || bus->can_dev_ops->dev_tx == NULL) {
> + int32_t ret = 0;
> + struct can_msg const *msg = buffer;
> + struct can_msg *fifo_buf = NULL;
> + CAN_DEBUG_LOCK("can_bus_write: acquiring lock tx_fifo.empty_count\n");
> + CAN_DEBUG_TX("can_bus_write: empty_count = %u\n", bus->tx_fifo.empty_count);
> + CAN_DEBUG_LOCK("can_bus_write: release lock tx_fifo.empty_count\n");
> + ret = try_sem(bus);
> + return -RTEMS_NO_MEMORY;
> + } else {
> + CAN_DEBUG_LOCK("can_bus_write: acquiring lock can_tx_buf_waiters++\n");
You use the macros a lot. You are aware that you could do something like
that:
- Declare the original can_interrupt_lock_acquire() as something with a
prefix or postifix for example as real_can_interrupt_lock_acquire.
- Then add a define that wrapps it with:
#define can_interrupt_lock_acquire(...) do { \
CAN_DEBUG_LOCK("%s:%d\n", __FILE__, __LINE__); \
real_can_interrupt_lock_acquire(__VA_ARGS__);
} while(0)
Then you can just write it as normal can_interrupt_lock_acquire but get
a debug print with file and line on every call.
> + bus->can_tx_buf_waiters++;
> + CAN_DEBUG_LOCK("can_bus_write: release lock can_tx_buf_waiters++\n");
> + ret = take_sem(bus);
> + CAN_DEBUG_LOCK("can_bus_write: acquiring lock can_tx_buf_waiters--\n");
> + bus->can_tx_buf_waiters--;
> + CAN_DEBUG_LOCK("can_bus_write: release lock can_tx_buf_waiters--\n");
> + printf("can_bus_write: cannot take semaphore\n");
> + ret = -RTEMS_INTERNAL_ERROR;
> + goto return_from_func;
Why not just use a return here instead of the goto? The label isn't used
anywhere else.
> + /* sleep is for debug purpose to test concurrency issues */
> + printf("can_bus_write: calling sleep\n");
> + sleep(1);
> + printf("can_bus_write: coming out sleep\n");
Obviously this shouldn't be there in the later merge-ready patch.
> + CAN_DEBUG_LOCK("can_bus_write: acquiring lock can_tx_get_empty_buf\n");
> + fifo_buf = can_tx_get_empty_buf(bus);
> + CAN_DEBUG_LOCK("can_bus_write: releasing lock can_tx_get_empty_buf\n");
> + if (fifo_buf == NULL) {
> + printf("can_bus_write: Buffer counts are not synchronized with semaphore count\n");
> + return -RTEMS_INTERNAL_ERROR;
> + sleep(1);
> + uint32_t msg_size = (char *)&msg->data[msg->len] - (char *)msg;
> + CAN_DEBUG_TX("can_bus_write: can_msg_size = %u\n", msg_size);
> + if (msg_size > sizeof(struct can_msg)) {
> + printf("can_bus_write:"
> + "can message len error msg_size = %u struct can_msg = %u\n",
> + msg_size, sizeof(struct can_msg));
> + return -RTEMS_INVALID_SIZE;
> + CAN_DEBUG_TX("can_bus_write: copying msg from application to driver buffer\n");
> + memcpy(fifo_buf, msg, msg_size);
> + ret = msg_size;
> + sleep(1);
> + can_xmit(bus);
> +return_from_func:
> + return ret;
> +static ssize_t
> + if (bus == NULL || bus->can_dev_ops->dev_ioctl == NULL) {
> + bus->can_dev_ops->dev_ioctl(bus->priv, NULL, 0);
> + return RTEMS_SUCCESSFUL;
> +static const rtems_filesystem_file_handlers_r can_bus_handler = {
> + .open_h = can_bus_open,
> + .close_h = rtems_filesystem_default_close,
> + .read_h = can_bus_read,
> + .write_h = can_bus_write,
> + .ioctl_h = can_bus_ioctl,
> + .lseek_h = rtems_filesystem_default_lseek,
> + .fstat_h = IMFS_stat,
> + .ftruncate_h = rtems_filesystem_default_ftruncate,
> + .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
> + .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
> + .fcntl_h = rtems_filesystem_default_fcntl,
> + .kqfilter_h = rtems_filesystem_default_kqfilter,
> + .mmap_h = rtems_filesystem_default_mmap,
> + .poll_h = rtems_filesystem_default_poll,
> + .readv_h = rtems_filesystem_default_readv,
> + .writev_h = rtems_filesystem_default_writev
> +static void can_bus_node_destroy(IMFS_jnode_t *node)
> + can_bus *bus;
> + bus = IMFS_generic_get_context_by_node(node);
> + (*bus->destroy)(bus);
> + IMFS_node_destroy_default(node);
> +static const
> +IMFS_node_control can_bus_node_control = IMFS_GENERIC_INITIALIZER(&can_bus_handler,
> + IMFS_node_initialize_generic, can_bus_node_destroy);
> +rtems_status_code can_bus_register(can_bus *bus, const char *bus_path)
> + static uint8_t index = 0;
> + if (index == 255) {
> + printf("can_bus_register: can bus registration limit reached\n");
> + return RTEMS_TOO_MANY;
> + bus->index = index++;
> + CAN_DEBUG("Registering CAN bus index = %u\n", bus->index);
> + ret = IMFS_make_generic_node(bus_path, S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
> + &can_bus_node_control, bus);
> + printf("can_bus_register: Creating node failed = %d\n", ret);
> + goto fail;
> + if ((ret = can_create_sem(bus)) != RTEMS_SUCCESSFUL) {
> + printf("can_bus_register: can_create_sem failed = %d\n", ret);
> + goto fail;
> + if ((ret = can_create_tx_buffers(bus)) != RTEMS_SUCCESSFUL) {
> + printf("can_bus_register: can_create_tx_buffers failed = %d\n", ret);
> + goto fail;
> + if ((ret = can_create_rx_buffers(bus)) != RTEMS_SUCCESSFUL) {
> + printf("can_bus_register: can_create_rx_buffers failed = %d\n", ret);
> + goto free_tx_buffers_return;
> + return ret;
> +free_tx_buffers_return:
> + free(bus->tx_fifo.pbuf);
> +fail:
> + return ret;
> +static void can_bus_destroy(can_bus *bus)
> + rtems_recursive_mutex_destroy(&bus->mutex);
> +static int can_bus_do_init(can_bus *bus, void (*destroy)(can_bus *bus))
> + rtems_recursive_mutex_init(&bus->mutex, "CAN Bus");
> + bus->destroy = can_bus_destroy;
> +static void can_bus_destroy_and_free(can_bus *bus)
> + can_bus_destroy(bus);
> + free(bus);
> +int can_bus_init(can_bus *bus)
> + memset(bus, 0, sizeof(*bus));
> + return can_bus_do_init(bus, can_bus_destroy);
> +can_bus *can_bus_alloc_and_init(size_t size)
> + can_bus *bus = NULL;
> + if (size >= sizeof(*bus)) {
> + bus = calloc(1, size);
> + printf("can_bus_alloc_and_init: calloc failed\b");
> + return NULL;
> + int rv = can_bus_do_init(bus, can_bus_destroy_and_free);
> + if (rv != 0) {
> + printf("can_bus_alloc_and_init: can_bus_do_init failed\n");
> + return NULL;
> + return bus;
> diff --git a/cpukit/include/dev/can/can-msg.h b/cpukit/include/dev/can/can-msg.h
> index 0000000000..5c79b91600
> --- /dev/null
> +++ b/cpukit/include/dev/can/can-msg.h
> @@ -0,0 +1,55 @@
> + * @file
> + * @ingroup CANBus
> + * Copyright (C) 2022 Prashanth S <fishesprashanth at gmail.com>
> + * are met:
> +#ifndef _DEV_CAN_CAN_MSG_H
> +#define _DEV_CAN_CAN_MSG_H
> +#define CAN_MSG_MAX_SIZE (8u)
> +#define CAN_TX_BUF_COUNT (2u)
> +#define CAN_RX_BUF_COUNT (2u)
> +#define CAN_MSGLEN(msg) (sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len))
> +struct can_msg {
> + uint32_t id; // 32 bits to support extended id (29 bits).
> + uint32_t timestamp;
> + uint16_t flags; // RTR | BRS | EXT ...
> + uint16_t len;
> + uint8_t data[CAN_MSG_MAX_SIZE]; // For supporting data transfer up to 64 bytes.
> +#endif /* _DEV_CAN_CAN_MSG_H */
> diff --git a/cpukit/include/dev/can/can-queue.h b/cpukit/include/dev/can/can-queue.h
> index 0000000000..c018441320
> --- /dev/null
> +++ b/cpukit/include/dev/can/can-queue.h
> @@ -0,0 +1,127 @@
> + * @file
> + * @ingroup CANBus
> + * are met:
> +#ifndef _DEV_CAN_CAN_QUEUE_H
> +#define _DEV_CAN_CAN_QUEUE_H
> +#include <stdio.h>
> +#include <dev/can/can-msg.h>
> +static rtems_status_code can_create_tx_buffers(struct can_bus *bus);
> +static rtems_status_code can_create_rx_buffers(struct can_bus *bus);
> +static bool can_tx_buf_isempty(struct can_bus *bus);
> +static struct can_msg *can_tx_get_data_buf(struct can_bus *bus);
> +static struct can_msg *can_tx_get_empty_buf(struct can_bus *bus);
> + return rtems_message_queue_create(rtems_build_name('c', 'a', 'n', bus->index),
> + CAN_RX_BUF_COUNT, sizeof(struct can_msg),
> + RTEMS_FIFO | RTEMS_LOCAL, &bus->rx_queue_id);
> + bus->tx_fifo.pbuf = (struct can_msg *)malloc(CAN_TX_BUF_COUNT *
> + sizeof(struct can_msg));
> + if (bus->tx_fifo.pbuf == NULL) {
> + printf("can_create_tx_buffers: malloc failed\n");
> + return RTEMS_NO_MEMORY;
> + bus->tx_fifo.empty_count = CAN_TX_BUF_COUNT;
> + if (bus->tx_fifo.empty_count == 0) {
> + return false;
> + return true;
> +// TODO: free the given data buf is done in the same function
> +// SO the returned buffer should be consumed before releasing the
> +// lock acquired while calling this function.
> + if (bus->tx_fifo.empty_count == CAN_TX_BUF_COUNT) {
> + CAN_DEBUG_BUF("can_tx_get_data_buf: All buffers are empty\n");
> + return NULL;
> + msg = &bus->tx_fifo.pbuf[bus->tx_fifo.tail];
> + bus->tx_fifo.empty_count++;
> + bus->tx_fifo.tail = (bus->tx_fifo.tail + 1) % CAN_TX_BUF_COUNT;
> + return msg;
> +// TODO: marking the given buf as produced is done in the same function
> +// So the returned buffer should be produced before releasing the
> + /* Check whether there is a empty CAN msg buffer */
> + if (can_tx_buf_isempty(bus) == false) {
> + CAN_DEBUG_BUF("can_tx_get_empty_buf: No empty buffer\n");
> + return NULL;
> + bus->tx_fifo.empty_count--;
> + /* tx_fifo.head always points to a empty buffer if there is atleast one */
> + msg = &bus->tx_fifo.pbuf[bus->tx_fifo.head];
> + bus->tx_fifo.head = (bus->tx_fifo.head + 1) % CAN_TX_BUF_COUNT;
> + return msg;
> +#endif /*_DEV_CAN_CAN_QUEUE_H */
> diff --git a/cpukit/include/dev/can/can.h b/cpukit/include/dev/can/can.h
> index 0000000000..eeb2eb2c0b
> --- /dev/null
> +++ b/cpukit/include/dev/can/can.h
> @@ -0,0 +1,102 @@
> + * @file
> + * @ingroup CANBus
> + * are met:
> +#ifndef _DEV_CAN_CAN_H
> +#define _DEV_CAN_CAN_H
> +#include <semaphore.h>
> +#include <stdio.h>
> +#define CAN_DEBUG(str, ...) printf(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_BUF(str, ...) printf(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_ISR(str, ...) printf(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_LOCK(str, ...) printf(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_RX(str, ...) printf(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_TX(str, ...) printf(str, ##__VA_ARGS__)
Do these really have to be in a header that you (most likely) will later
install? With that they are public visible API.
Best regards
Christian
> +struct ring_buf {
> + struct can_msg *pbuf;
> + uint32_t head;
> + uint32_t tail;
> + uint32_t empty_count;
> +typedef struct can_dev_ops {
> + int32_t (*dev_rx)(void *priv, void *buffer);
> + int32_t (*dev_tx)(void *priv, void *buffer);
> + bool (*dev_tx_ready)(void *priv);
> + void (*dev_int)(void *priv, bool);
> + int32_t (*dev_ioctl)(void *priv, void *buffer, size_t cmd);
> +} can_dev_ops;
> +typedef struct can_bus {
> + void *priv; // CAN controller specific struct.
> + uint8_t index;
> + struct can_dev_ops *can_dev_ops; // CAN controller operations.
> + struct ring_buf tx_fifo; // TX fifo
> + rtems_id tx_fifo_sem_id; // TX fifo counting semaphore id
> + uint32_t can_tx_buf_waiters;
> + rtems_id rx_queue_id;
> + uint32_t rx_queue_name;
> + rtems_recursive_mutex mutex; // For handling driver concurrency.
> + RTEMS_INTERRUPT_LOCK_MEMBER(can_bus_lock);
> + void (*destroy)(struct can_bus *bus); // Clean the CAN controller specific resources.
> +} can_bus;
> +extern rtems_status_code can_bus_register(can_bus *bus, const char *bus_path);
> +extern can_bus *can_bus_alloc_and_init(size_t size);
> +extern int can_bus_init(can_bus *bus);
> +extern int can_tx_done(struct can_bus *);
> +extern int can_receive(struct can_bus *, struct can_msg *);
> +extern uint16_t can_len_to_dlc(uint16_t len);
> +extern uint16_t can_dlc_to_len(uint16_t dlc);
> +extern void can_print_msg(struct can_msg const *);
> +#endif /* _DEV_CAN_CAN_H */
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index 31a68cf85a..b7f6c0457c 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -50,6 +50,11 @@ install:
> - destination: ${BSP_INCLUDEDIR}/dev/spi
> source:
> - cpukit/include/dev/spi/spi.h
> +- destination: ${BSP_INCLUDEDIR}/dev/can
> + source:
> + - cpukit/include/dev/can/can.h
> + - cpukit/include/dev/can/can-msg.h
> + - cpukit/include/dev/can/can-queue.h
> - destination: ${BSP_INCLUDEDIR}/linux
> source:
> - cpukit/include/linux/i2c-dev.h
> @@ -530,6 +535,7 @@ source:
> - cpukit/dev/serial/sc16is752-spi.c
> - cpukit/dev/serial/sc16is752.c
> - cpukit/dev/spi/spi-bus.c
> +- cpukit/dev/can/can.c
> - cpukit/dtc/libfdt/fdt.c
> - cpukit/dtc/libfdt/fdt_addresses.c
> - cpukit/dtc/libfdt/fdt_empty_tree.c
