[PATCH v6 02/10] bsps/arm: Changed CMSIS files to v5
Duc Doan
dtbpkmte at gmail.com
Sun Aug 7 10:58:14 UTC 2022
The CMSIS files are taken from ST's STM32CubeF4 repository at:
https://github.com/STMicroelectronics/STM32CubeF4, Release
v1.27.1, commit 52757b5e33259a088509a777a9e3a5b971194c7d.
There are license changes with these new CMSIS files, from
BSD to Apache-2.0.
The files are copied from Drivers/CMSIS/Core/Include to
replace old files in bsps/arm/include.
bsps/arm/include/cmsis_compiler.h | 266 +++++++
bsps/arm/include/cmsis_gcc.h | 1152 +++++++++++++++++++++++------
bsps/arm/include/cmsis_version.h | 39 +
bsps/arm/include/core_cm4.h | 524 ++++++++-----
bsps/arm/include/core_cm7.h | 582 +++++++++------
bsps/arm/include/mpu_armv7.h | 270 +++++++
6 files changed, 2233 insertions(+), 600 deletions(-)
create mode 100644 bsps/arm/include/cmsis_compiler.h
create mode 100644 bsps/arm/include/cmsis_version.h
create mode 100644 bsps/arm/include/mpu_armv7.h
diff --git a/bsps/arm/include/cmsis_compiler.h b/bsps/arm/include/cmsis_compiler.h
new file mode 100644
index 0000000000..94212eb87a
--- /dev/null
+++ b/bsps/arm/include/cmsis_compiler.h
@@ -0,0 +1,266 @@
+ * @file cmsis_compiler.h
+ * @brief CMSIS compiler generic header file
+ * @version V5.0.4
+ * @date 10. January 2018
+ * Copyright (c) 2009-2018 Arm Limited. All rights reserved.
+ * SPDX-License-Identifier: Apache-2.0
+ * Licensed under the Apache License, Version 2.0 (the License); you may
+ * not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an AS IS BASIS, WITHOUT
+ * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+#ifndef __CMSIS_COMPILER_H
+#define __CMSIS_COMPILER_H
+#include <stdint.h>
+ * Arm Compiler 4/5
+#if defined ( __CC_ARM )
+ #include "cmsis_armcc.h"
+ * Arm Compiler 6 (armclang)
+#elif defined (__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
+ #include "cmsis_armclang.h"
+ * GNU Compiler
+#elif defined ( __GNUC__ )
+ #include "cmsis_gcc.h"
+ * IAR Compiler
+#elif defined ( __ICCARM__ )
+ #include <cmsis_iccarm.h>
+ * TI Arm Compiler
+#elif defined ( __TI_ARM__ )
+ #include <cmsis_ccs.h>
+ #ifndef __ASM
+ #define __ASM __asm
+ #endif
+ #ifndef __INLINE
+ #define __INLINE inline
+ #endif
+ #ifndef __STATIC_INLINE
+ #define __STATIC_INLINE static inline
+ #endif
+ #ifndef __STATIC_FORCEINLINE
+ #define __STATIC_FORCEINLINE __STATIC_INLINE
+ #endif
+ #ifndef __NO_RETURN
+ #define __NO_RETURN __attribute__((noreturn))
+ #endif
+ #ifndef __USED
+ #define __USED __attribute__((used))
+ #endif
+ #ifndef __WEAK
+ #define __WEAK __attribute__((weak))
+ #endif
+ #ifndef __PACKED
+ #define __PACKED __attribute__((packed))
+ #endif
+ #ifndef __PACKED_STRUCT
+ #define __PACKED_STRUCT struct __attribute__((packed))
+ #endif
+ #ifndef __PACKED_UNION
+ #define __PACKED_UNION union __attribute__((packed))
+ #endif
+ #ifndef __UNALIGNED_UINT32 /* deprecated */
+ struct __attribute__((packed)) T_UINT32 { uint32_t v; };
+ #define __UNALIGNED_UINT32(x) (((struct T_UINT32 *)(x))->v)
+ #endif
+ #ifndef __UNALIGNED_UINT16_WRITE
+ __PACKED_STRUCT T_UINT16_WRITE { uint16_t v; };
+ #define __UNALIGNED_UINT16_WRITE(addr, val) (void)((((struct T_UINT16_WRITE *)(void*)(addr))->v) = (val))
+ #endif
+ #ifndef __UNALIGNED_UINT16_READ
+ __PACKED_STRUCT T_UINT16_READ { uint16_t v; };
+ #define __UNALIGNED_UINT16_READ(addr) (((const struct T_UINT16_READ *)(const void *)(addr))->v)
+ #endif
+ #ifndef __UNALIGNED_UINT32_WRITE
+ __PACKED_STRUCT T_UINT32_WRITE { uint32_t v; };
+ #define __UNALIGNED_UINT32_WRITE(addr, val) (void)((((struct T_UINT32_WRITE *)(void *)(addr))->v) = (val))
+ #endif
+ #ifndef __UNALIGNED_UINT32_READ
+ __PACKED_STRUCT T_UINT32_READ { uint32_t v; };
+ #define __UNALIGNED_UINT32_READ(addr) (((const struct T_UINT32_READ *)(const void *)(addr))->v)
+ #endif
+ #ifndef __ALIGNED
+ #define __ALIGNED(x) __attribute__((aligned(x)))
+ #endif
+ #ifndef __RESTRICT
+ #warning No compiler specific solution for __RESTRICT. __RESTRICT is ignored.
+ #define __RESTRICT
+ #endif
+ * TASKING Compiler
+#elif defined ( __TASKING__ )
+ * The CMSIS functions have been implemented as intrinsics in the compiler.
+ * Please use "carm -?i" to get an up to date list of all intrinsics,
+ * Including the CMSIS ones.
+ #ifndef __ASM
+ #endif
+ #ifndef __INLINE
+ #endif
+ #endif
+ #endif
+ #endif
+ #ifndef __USED
+ #endif
+ #ifndef __WEAK
+ #endif
+ #ifndef __PACKED
+ #define __PACKED __packed__
+ #endif
+ #define __PACKED_STRUCT struct __packed__
+ #endif
+ #define __PACKED_UNION union __packed__
+ #endif
+ struct __packed__ T_UINT32 { uint32_t v; };
+ #endif
+ #define __UNALIGNED_UINT16_WRITE(addr, val) (void)((((struct T_UINT16_WRITE *)(void *)(addr))->v) = (val))
+ #endif
+ #endif
+ #endif
+ #endif
+ #ifndef __ALIGNED
+ #define __ALIGNED(x) __align(x)
+ #endif
+ #endif
+ * COSMIC Compiler
+#elif defined ( __CSMC__ )
+ #include <cmsis_csm.h>
+ #ifndef __ASM
+ #define __ASM _asm
+ #endif
+ #ifndef __INLINE
+ #endif
+ #endif
+ #endif
+ // NO RETURN is automatically detected hence no warning here
+ #endif
+ #ifndef __USED
+ #warning No compiler specific solution for __USED. __USED is ignored.
+ #define __USED
+ #endif
+ #ifndef __WEAK
+ #define __WEAK __weak
+ #endif
+ #ifndef __PACKED
+ #define __PACKED @packed
+ #endif
+ #define __PACKED_STRUCT @packed struct
+ #endif
+ #define __PACKED_UNION @packed union
+ #endif
+ @packed struct T_UINT32 { uint32_t v; };
+ #endif
+ #endif
+ #endif
+ #endif
+ #endif
+ #ifndef __ALIGNED
+ #warning No compiler specific solution for __ALIGNED. __ALIGNED is ignored.
+ #endif
+ #endif
+#else
+ #error Unknown compiler.
+#endif
+#endif /* __CMSIS_COMPILER_H */
diff --git a/bsps/arm/include/cmsis_gcc.h b/bsps/arm/include/cmsis_gcc.h
index cafe58fe5b..2d9db15a5d 100644
--- a/bsps/arm/include/cmsis_gcc.h
+++ b/bsps/arm/include/cmsis_gcc.h
@@ -1,46 +1,117 @@
- * @file
- * @brief CMSIS Cortex-M Core Function/Instruction Header File
- * @version V4.30
- * @date 20. October 2015
+ * @file cmsis_gcc.h
+ * @brief CMSIS compiler GCC header file
+ * @version V5.0.4
+ * @date 09. April 2018
-/* Copyright (c) 2009 - 2015 ARM LIMITED
- All rights reserved.
- Redistribution and use in source and binary forms, with or without
- modification, are permitted provided that the following conditions are met:
- - Redistributions of source code must retain the above copyright
- notice, this list of conditions and the following disclaimer.
- - Redistributions in binary form must reproduce the above copyright
- notice, this list of conditions and the following disclaimer in the
- documentation and/or other materials provided with the distribution.
- - Neither the name of ARM nor the names of its contributors may be used
- to endorse or promote products derived from this software without
- specific prior written permission.
- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- POSSIBILITY OF SUCH DAMAGE.
#ifndef __CMSIS_GCC_H
#define __CMSIS_GCC_H
/* ignore some GCC warnings */
-#if defined ( __GNUC__ )
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored "-Wsign-conversion"
#pragma GCC diagnostic ignored "-Wconversion"
#pragma GCC diagnostic ignored "-Wunused-parameter"
+/* Fallback for __has_builtin */
+#ifndef __has_builtin
+ #define __has_builtin(x) (0)
+#endif
+/* CMSIS compiler specific defines */
+#ifndef __ASM
+#endif
+#ifndef __INLINE
+#endif
+#ifndef __STATIC_INLINE
+#endif
+#ifndef __STATIC_FORCEINLINE
+ #define __STATIC_FORCEINLINE __attribute__((always_inline)) static inline
+#endif
+#ifndef __NO_RETURN
+ #define __NO_RETURN __attribute__((__noreturn__))
+#endif
+#ifndef __USED
+#endif
+#ifndef __WEAK
+#endif
+#ifndef __PACKED
+ #define __PACKED __attribute__((packed, aligned(1)))
+#endif
+#ifndef __PACKED_STRUCT
+ #define __PACKED_STRUCT struct __attribute__((packed, aligned(1)))
+#endif
+#ifndef __PACKED_UNION
+ #define __PACKED_UNION union __attribute__((packed, aligned(1)))
+#endif
+#ifndef __UNALIGNED_UINT32 /* deprecated */
+ #pragma GCC diagnostic push
+ #pragma GCC diagnostic ignored "-Wpacked"
+ #pragma GCC diagnostic ignored "-Wattributes"
+ #pragma GCC diagnostic pop
+#endif
+#ifndef __UNALIGNED_UINT16_WRITE
+#endif
+#ifndef __UNALIGNED_UINT16_READ
+#endif
+#ifndef __UNALIGNED_UINT32_WRITE
+#endif
+#ifndef __UNALIGNED_UINT32_READ
+#endif
+#ifndef __ALIGNED
+#endif
+#ifndef __RESTRICT
+ #define __RESTRICT __restrict
#endif
@@ -55,7 +126,7 @@
\details Enables IRQ interrupts by clearing the I-bit in the CPSR.
Can only be executed in Privileged modes.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __enable_irq(void)
+__STATIC_FORCEINLINE void __enable_irq(void)
__ASM volatile ("cpsie i" : : : "memory");
@@ -64,9 +135,9 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE void __enable_irq(void)
\brief Disable IRQ Interrupts
\details Disables IRQ interrupts by setting the I-bit in the CPSR.
- Can only be executed in Privileged modes.
+ Can only be executed in Privileged modes.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_irq(void)
+__STATIC_FORCEINLINE void __disable_irq(void)
__ASM volatile ("cpsid i" : : : "memory");
@@ -77,7 +148,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_irq(void)
\details Returns the content of the Control Register.
\return Control Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_CONTROL(void)
+__STATIC_FORCEINLINE uint32_t __get_CONTROL(void)
uint32_t result;
@@ -86,23 +157,52 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_CONTROL(void)
+#if (defined (__ARM_FEATURE_CMSE ) && (__ARM_FEATURE_CMSE == 3))
+ \brief Get Control Register (non-secure)
+ \details Returns the content of the non-secure Control Register when in secure mode.
+ \return non-secure Control Register value
+__STATIC_FORCEINLINE uint32_t __TZ_get_CONTROL_NS(void)
+ uint32_t result;
+ __ASM volatile ("MRS %0, control_ns" : "=r" (result) );
+ return(result);
+#endif
\brief Set Control Register
\details Writes the given value to the Control Register.
\param [in] control Control Register value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_CONTROL(uint32_t control)
+__STATIC_FORCEINLINE void __set_CONTROL(uint32_t control)
__ASM volatile ("MSR control, %0" : : "r" (control) : "memory");
+ \brief Set Control Register (non-secure)
+ \details Writes the given value to the non-secure Control Register when in secure state.
+ \param [in] control Control Register value to set
+__STATIC_FORCEINLINE void __TZ_set_CONTROL_NS(uint32_t control)
+ __ASM volatile ("MSR control_ns, %0" : : "r" (control) : "memory");
+#endif
\brief Get IPSR Register
\details Returns the content of the IPSR Register.
\return IPSR Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_IPSR(void)
+__STATIC_FORCEINLINE uint32_t __get_IPSR(void)
uint32_t result;
@@ -116,7 +216,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_IPSR(void)
\details Returns the content of the APSR Register.
\return APSR Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_APSR(void)
+__STATIC_FORCEINLINE uint32_t __get_APSR(void)
uint32_t result;
@@ -128,10 +228,9 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_APSR(void)
\brief Get xPSR Register
\details Returns the content of the xPSR Register.
- \return xPSR Register value
+ \return xPSR Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_xPSR(void)
+__STATIC_FORCEINLINE uint32_t __get_xPSR(void)
uint32_t result;
@@ -145,50 +244,134 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_xPSR(void)
\details Returns the current value of the Process Stack Pointer (PSP).
\return PSP Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_PSP(void)
+__STATIC_FORCEINLINE uint32_t __get_PSP(void)
- register uint32_t result;
+ uint32_t result;
- __ASM volatile ("MRS %0, psp\n" : "=r" (result) );
+ __ASM volatile ("MRS %0, psp" : "=r" (result) );
return(result);
+ \brief Get Process Stack Pointer (non-secure)
+ \details Returns the current value of the non-secure Process Stack Pointer (PSP) when in secure state.
+ \return PSP Register value
+__STATIC_FORCEINLINE uint32_t __TZ_get_PSP_NS(void)
+ uint32_t result;
+ __ASM volatile ("MRS %0, psp_ns" : "=r" (result) );
+ return(result);
+#endif
\brief Set Process Stack Pointer
\details Assigns the given value to the Process Stack Pointer (PSP).
\param [in] topOfProcStack Process Stack Pointer value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_PSP(uint32_t topOfProcStack)
+__STATIC_FORCEINLINE void __set_PSP(uint32_t topOfProcStack)
- __ASM volatile ("MSR psp, %0\n" : : "r" (topOfProcStack) : "sp");
+ __ASM volatile ("MSR psp, %0" : : "r" (topOfProcStack) : );
+ \brief Set Process Stack Pointer (non-secure)
+ \details Assigns the given value to the non-secure Process Stack Pointer (PSP) when in secure state.
+ \param [in] topOfProcStack Process Stack Pointer value to set
+__STATIC_FORCEINLINE void __TZ_set_PSP_NS(uint32_t topOfProcStack)
+ __ASM volatile ("MSR psp_ns, %0" : : "r" (topOfProcStack) : );
+#endif
\brief Get Main Stack Pointer
\details Returns the current value of the Main Stack Pointer (MSP).
\return MSP Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_MSP(void)
+__STATIC_FORCEINLINE uint32_t __get_MSP(void)
+ uint32_t result;
+ __ASM volatile ("MRS %0, msp" : "=r" (result) );
+ return(result);
+ \brief Get Main Stack Pointer (non-secure)
+ \details Returns the current value of the non-secure Main Stack Pointer (MSP) when in secure state.
+ \return MSP Register value
+__STATIC_FORCEINLINE uint32_t __TZ_get_MSP_NS(void)
+ uint32_t result;
- __ASM volatile ("MRS %0, msp\n" : "=r" (result) );
+ __ASM volatile ("MRS %0, msp_ns" : "=r" (result) );
return(result);
+#endif
\brief Set Main Stack Pointer
\details Assigns the given value to the Main Stack Pointer (MSP).
+ \param [in] topOfMainStack Main Stack Pointer value to set
+__STATIC_FORCEINLINE void __set_MSP(uint32_t topOfMainStack)
+ __ASM volatile ("MSR msp, %0" : : "r" (topOfMainStack) : );
+ \brief Set Main Stack Pointer (non-secure)
+ \details Assigns the given value to the non-secure Main Stack Pointer (MSP) when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_MSP_NS(uint32_t topOfMainStack)
+ __ASM volatile ("MSR msp_ns, %0" : : "r" (topOfMainStack) : );
+#endif
+ \brief Get Stack Pointer (non-secure)
+ \details Returns the current value of the non-secure Stack Pointer (SP) when in secure state.
+ \return SP Register value
+__STATIC_FORCEINLINE uint32_t __TZ_get_SP_NS(void)
+ uint32_t result;
+ __ASM volatile ("MRS %0, sp_ns" : "=r" (result) );
+ return(result);
- \param [in] topOfMainStack Main Stack Pointer value to set
+ \brief Set Stack Pointer (non-secure)
+ \details Assigns the given value to the non-secure Stack Pointer (SP) when in secure state.
+ \param [in] topOfStack Stack Pointer value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_MSP(uint32_t topOfMainStack)
+__STATIC_FORCEINLINE void __TZ_set_SP_NS(uint32_t topOfStack)
- __ASM volatile ("MSR msp, %0\n" : : "r" (topOfMainStack) : "sp");
+ __ASM volatile ("MSR sp_ns, %0" : : "r" (topOfStack) : );
+#endif
@@ -196,34 +379,64 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_MSP(uint32_t topOf
\details Returns the current state of the priority mask bit from the Priority Mask Register.
\return Priority Mask value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_PRIMASK(void)
+__STATIC_FORCEINLINE uint32_t __get_PRIMASK(void)
uint32_t result;
- __ASM volatile ("MRS %0, primask" : "=r" (result) );
+ __ASM volatile ("MRS %0, primask" : "=r" (result) :: "memory");
return(result);
+ \brief Get Priority Mask (non-secure)
+ \details Returns the current state of the non-secure priority mask bit from the Priority Mask Register when in secure state.
+ \return Priority Mask value
+__STATIC_FORCEINLINE uint32_t __TZ_get_PRIMASK_NS(void)
+ uint32_t result;
+ __ASM volatile ("MRS %0, primask_ns" : "=r" (result) :: "memory");
+ return(result);
+#endif
\brief Set Priority Mask
\details Assigns the given value to the Priority Mask Register.
\param [in] priMask Priority Mask
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_PRIMASK(uint32_t priMask)
+__STATIC_FORCEINLINE void __set_PRIMASK(uint32_t priMask)
__ASM volatile ("MSR primask, %0" : : "r" (priMask) : "memory");
-#if (__CORTEX_M >= 0x03U)
+ \brief Set Priority Mask (non-secure)
+ \details Assigns the given value to the non-secure Priority Mask Register when in secure state.
+ \param [in] priMask Priority Mask
+__STATIC_FORCEINLINE void __TZ_set_PRIMASK_NS(uint32_t priMask)
+ __ASM volatile ("MSR primask_ns, %0" : : "r" (priMask) : "memory");
+#endif
+#if ((defined (__ARM_ARCH_7M__ ) && (__ARM_ARCH_7M__ == 1)) || \
+ (defined (__ARM_ARCH_7EM__ ) && (__ARM_ARCH_7EM__ == 1)) || \
+ (defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) )
\brief Enable FIQ
\details Enables FIQ interrupts by clearing the F-bit in the CPSR.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __enable_fault_irq(void)
+__STATIC_FORCEINLINE void __enable_fault_irq(void)
__ASM volatile ("cpsie f" : : : "memory");
@@ -234,7 +447,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE void __enable_fault_irq(void)
\details Disables FIQ interrupts by setting the F-bit in the CPSR.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_fault_irq(void)
+__STATIC_FORCEINLINE void __disable_fault_irq(void)
__ASM volatile ("cpsid f" : : : "memory");
@@ -245,7 +458,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_fault_irq(void
\details Returns the current value of the Base Priority register.
\return Base Priority register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_BASEPRI(void)
+__STATIC_FORCEINLINE uint32_t __get_BASEPRI(void)
uint32_t result;
@@ -254,26 +467,55 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_BASEPRI(void)
+ \brief Get Base Priority (non-secure)
+ \details Returns the current value of the non-secure Base Priority register when in secure state.
+ \return Base Priority register value
+__STATIC_FORCEINLINE uint32_t __TZ_get_BASEPRI_NS(void)
+ uint32_t result;
+ __ASM volatile ("MRS %0, basepri_ns" : "=r" (result) );
+ return(result);
+#endif
\brief Set Base Priority
\details Assigns the given value to the Base Priority register.
\param [in] basePri Base Priority value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_BASEPRI(uint32_t value)
+__STATIC_FORCEINLINE void __set_BASEPRI(uint32_t basePri)
- __ASM volatile ("MSR basepri, %0" : : "r" (value) : "memory");
+ __ASM volatile ("MSR basepri, %0" : : "r" (basePri) : "memory");
+ \brief Set Base Priority (non-secure)
+ \details Assigns the given value to the non-secure Base Priority register when in secure state.
+ \param [in] basePri Base Priority value to set
+__STATIC_FORCEINLINE void __TZ_set_BASEPRI_NS(uint32_t basePri)
+ __ASM volatile ("MSR basepri_ns, %0" : : "r" (basePri) : "memory");
+#endif
\brief Set Base Priority with condition
\details Assigns the given value to the Base Priority register only if BASEPRI masking is disabled,
or the new value increases the BASEPRI priority level.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_BASEPRI_MAX(uint32_t value)
+__STATIC_FORCEINLINE void __set_BASEPRI_MAX(uint32_t basePri)
- __ASM volatile ("MSR basepri_max, %0" : : "r" (value) : "memory");
+ __ASM volatile ("MSR basepri_max, %0" : : "r" (basePri) : "memory");
@@ -282,7 +524,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_BASEPRI_MAX(uint32
\details Returns the current value of the Fault Mask register.
\return Fault Mask register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_FAULTMASK(void)
+__STATIC_FORCEINLINE uint32_t __get_FAULTMASK(void)
uint32_t result;
@@ -291,38 +533,253 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_FAULTMASK(void
+ \brief Get Fault Mask (non-secure)
+ \details Returns the current value of the non-secure Fault Mask register when in secure state.
+ \return Fault Mask register value
+__STATIC_FORCEINLINE uint32_t __TZ_get_FAULTMASK_NS(void)
+ uint32_t result;
+ __ASM volatile ("MRS %0, faultmask_ns" : "=r" (result) );
+ return(result);
+#endif
\brief Set Fault Mask
\details Assigns the given value to the Fault Mask register.
\param [in] faultMask Fault Mask value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_FAULTMASK(uint32_t faultMask)
+__STATIC_FORCEINLINE void __set_FAULTMASK(uint32_t faultMask)
__ASM volatile ("MSR faultmask, %0" : : "r" (faultMask) : "memory");
-#endif /* (__CORTEX_M >= 0x03U) */
+ \brief Set Fault Mask (non-secure)
+ \details Assigns the given value to the non-secure Fault Mask register when in secure state.
+ \param [in] faultMask Fault Mask value to set
+__STATIC_FORCEINLINE void __TZ_set_FAULTMASK_NS(uint32_t faultMask)
+ __ASM volatile ("MSR faultmask_ns, %0" : : "r" (faultMask) : "memory");
+#endif
+#endif /* ((defined (__ARM_ARCH_7M__ ) && (__ARM_ARCH_7M__ == 1)) || \
+ (defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) ) */
+#if ((defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) || \
+ (defined (__ARM_ARCH_8M_BASE__ ) && (__ARM_ARCH_8M_BASE__ == 1)) )
+ \brief Get Process Stack Pointer Limit
+ Devices without ARMv8-M Main Extensions (i.e. Cortex-M23) lack the non-secure
+ Stack Pointer Limit register hence zero is returned always in non-secure
+ mode.
+ \details Returns the current value of the Process Stack Pointer Limit (PSPLIM).
+ \return PSPLIM Register value
+__STATIC_FORCEINLINE uint32_t __get_PSPLIM(void)
+#if (!(defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) && \
+ (!defined (__ARM_FEATURE_CMSE) || (__ARM_FEATURE_CMSE < 3)))
+ // without main extensions, the non-secure PSPLIM is RAZ/WI
+ return 0U;
+#else
+ uint32_t result;
+ __ASM volatile ("MRS %0, psplim" : "=r" (result) );
+ return result;
+#endif
+#if (defined (__ARM_FEATURE_CMSE) && (__ARM_FEATURE_CMSE == 3))
+ \brief Get Process Stack Pointer Limit (non-secure)
+ Stack Pointer Limit register hence zero is returned always.
+ \details Returns the current value of the non-secure Process Stack Pointer Limit (PSPLIM) when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_PSPLIM_NS(void)
+#if (!(defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)))
+ return 0U;
+#else
+ uint32_t result;
+ __ASM volatile ("MRS %0, psplim_ns" : "=r" (result) );
+ return result;
+#endif
+#endif
+ \brief Set Process Stack Pointer Limit
+ Stack Pointer Limit register hence the write is silently ignored in non-secure
+ mode.
+ \details Assigns the given value to the Process Stack Pointer Limit (PSPLIM).
+ \param [in] ProcStackPtrLimit Process Stack Pointer Limit value to set
+__STATIC_FORCEINLINE void __set_PSPLIM(uint32_t ProcStackPtrLimit)
+ (void)ProcStackPtrLimit;
+#else
+ __ASM volatile ("MSR psplim, %0" : : "r" (ProcStackPtrLimit));
+#endif
+ Stack Pointer Limit register hence the write is silently ignored.
+ \details Assigns the given value to the non-secure Process Stack Pointer Limit (PSPLIM) when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_PSPLIM_NS(uint32_t ProcStackPtrLimit)
+#else
+ __ASM volatile ("MSR psplim_ns, %0\n" : : "r" (ProcStackPtrLimit));
+#endif
+#endif
+ \brief Get Main Stack Pointer Limit
+ mode.
+ \details Returns the current value of the Main Stack Pointer Limit (MSPLIM).
+ \return MSPLIM Register value
+__STATIC_FORCEINLINE uint32_t __get_MSPLIM(void)
+ // without main extensions, the non-secure MSPLIM is RAZ/WI
+ return 0U;
+#else
+ uint32_t result;
+ __ASM volatile ("MRS %0, msplim" : "=r" (result) );
+ return result;
+#endif
+ \brief Get Main Stack Pointer Limit (non-secure)
+ \details Returns the current value of the non-secure Main Stack Pointer Limit(MSPLIM) when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_MSPLIM_NS(void)
+ return 0U;
+#else
+ uint32_t result;
+ __ASM volatile ("MRS %0, msplim_ns" : "=r" (result) );
+ return result;
+#endif
+#endif
+ \brief Set Main Stack Pointer Limit
+ mode.
+ \details Assigns the given value to the Main Stack Pointer Limit (MSPLIM).
+ \param [in] MainStackPtrLimit Main Stack Pointer Limit value to set
+__STATIC_FORCEINLINE void __set_MSPLIM(uint32_t MainStackPtrLimit)
+ (void)MainStackPtrLimit;
+#else
+ __ASM volatile ("MSR msplim, %0" : : "r" (MainStackPtrLimit));
+#endif
+ \brief Set Main Stack Pointer Limit (non-secure)
+ \details Assigns the given value to the non-secure Main Stack Pointer Limit (MSPLIM) when in secure state.
+ \param [in] MainStackPtrLimit Main Stack Pointer value to set
+__STATIC_FORCEINLINE void __TZ_set_MSPLIM_NS(uint32_t MainStackPtrLimit)
+#else
+ __ASM volatile ("MSR msplim_ns, %0" : : "r" (MainStackPtrLimit));
+#endif
+#endif
+#endif /* ((defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) || \
+ (defined (__ARM_ARCH_8M_BASE__ ) && (__ARM_ARCH_8M_BASE__ == 1)) ) */
-#if (__CORTEX_M == 0x04U) || (__CORTEX_M == 0x07U)
\brief Get FPSCR
\details Returns the current value of the Floating Point Status/Control register.
\return Floating Point Status/Control register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_FPSCR(void)
-#if (__FPU_PRESENT == 1U) && (__FPU_USED == 1U)
+__STATIC_FORCEINLINE uint32_t __get_FPSCR(void)
+#if ((defined (__FPU_PRESENT) && (__FPU_PRESENT == 1U)) && \
+ (defined (__FPU_USED ) && (__FPU_USED == 1U)) )
+#if __has_builtin(__builtin_arm_get_fpscr)
+// Re-enable using built-in when GCC has been fixed
+// || (__GNUC__ > 7) || (__GNUC__ == 7 && __GNUC_MINOR__ >= 2)
+ /* see https://gcc.gnu.org/ml/gcc-patches/2017-04/msg00443.html */
+ return __builtin_arm_get_fpscr();
+#else
uint32_t result;
- /* Empty asm statement works as a scheduling barrier */
- __ASM volatile ("");
__ASM volatile ("VMRS %0, fpscr" : "=r" (result) );
return(result);
+#endif
#else
- return(0);
+ return(0U);
#endif
@@ -332,26 +789,29 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_FPSCR(void)
\details Assigns the given value to the Floating Point Status/Control register.
\param [in] fpscr Floating Point Status/Control value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_FPSCR(uint32_t fpscr)
- __ASM volatile ("VMSR fpscr, %0" : : "r" (fpscr) : "vfpcc");
+__STATIC_FORCEINLINE void __set_FPSCR(uint32_t fpscr)
+#if __has_builtin(__builtin_arm_set_fpscr)
+ __builtin_arm_set_fpscr(fpscr);
+#else
+ __ASM volatile ("VMSR fpscr, %0" : : "r" (fpscr) : "vfpcc", "memory");
+#endif
+#else
+ (void)fpscr;
#endif
-#endif /* (__CORTEX_M == 0x04U) || (__CORTEX_M == 0x07U) */
/*@} end of CMSIS_Core_RegAccFunctions */
/* ########################## Core Instruction Access ######################### */
/** \defgroup CMSIS_Core_InstructionInterface CMSIS Core Instruction Interface
- \ingroup CMSIS
Access to dedicated instructions
@@ -361,9 +821,11 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_FPSCR(uint32_t fps
* Otherwise, use general registers, specified by constraint "r" */
#if defined (__thumb__) && !defined (__thumb2__)
#define __CMSIS_GCC_OUT_REG(r) "=l" (r)
+#define __CMSIS_GCC_RW_REG(r) "+l" (r)
#define __CMSIS_GCC_USE_REG(r) "l" (r)
#else
#define __CMSIS_GCC_OUT_REG(r) "=r" (r)
+#define __CMSIS_GCC_RW_REG(r) "+r" (r)
#define __CMSIS_GCC_USE_REG(r) "r" (r)
#endif
@@ -371,41 +833,28 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE void __set_FPSCR(uint32_t fps
\brief No Operation
\details No Operation does nothing. This instruction can be used for code alignment purposes.
-__attribute__((always_inline)) __STATIC_INLINE void __NOP(void)
- __ASM volatile ("nop");
+#define __NOP() __ASM volatile ("nop")
\brief Wait For Interrupt
\details Wait For Interrupt is a hint instruction that suspends execution until one of a number of events occurs.
-__attribute__((always_inline)) __STATIC_INLINE void __WFI(void)
- __ASM volatile ("wfi");
+#define __WFI() __ASM volatile ("wfi")
\brief Wait For Event
\details Wait For Event is a hint instruction that permits the processor to enter
- a low-power state until one of a number of events occurs.
+ a low-power state until one of a number of events occurs.
-__attribute__((always_inline)) __STATIC_INLINE void __WFE(void)
- __ASM volatile ("wfe");
+#define __WFE() __ASM volatile ("wfe")
\brief Send Event
\details Send Event is a hint instruction. It causes an event to be signaled to the CPU.
-__attribute__((always_inline)) __STATIC_INLINE void __SEV(void)
- __ASM volatile ("sev");
+#define __SEV() __ASM volatile ("sev")
@@ -414,7 +863,7 @@ __attribute__((always_inline)) __STATIC_INLINE void __SEV(void)
so that all instructions following the ISB are fetched from cache or memory,
after the instruction has been completed.
-__attribute__((always_inline)) __STATIC_INLINE void __ISB(void)
+__STATIC_FORCEINLINE void __ISB(void)
__ASM volatile ("isb 0xF":::"memory");
@@ -425,7 +874,7 @@ __attribute__((always_inline)) __STATIC_INLINE void __ISB(void)
\details Acts as a special kind of Data Memory Barrier.
It completes when all explicit memory accesses before this instruction complete.
-__attribute__((always_inline)) __STATIC_INLINE void __DSB(void)
+__STATIC_FORCEINLINE void __DSB(void)
__ASM volatile ("dsb 0xF":::"memory");
@@ -436,7 +885,7 @@ __attribute__((always_inline)) __STATIC_INLINE void __DSB(void)
\details Ensures the apparent order of the explicit memory operations before
and after the instruction, without ensuring their completion.
-__attribute__((always_inline)) __STATIC_INLINE void __DMB(void)
+__STATIC_FORCEINLINE void __DMB(void)
__ASM volatile ("dmb 0xF":::"memory");
@@ -444,11 +893,11 @@ __attribute__((always_inline)) __STATIC_INLINE void __DMB(void)
\brief Reverse byte order (32 bit)
- \details Reverses the byte order in integer value.
+ \details Reverses the byte order in unsigned integer value. For example, 0x12345678 becomes 0x78563412.
\param [in] value Value to reverse
\return Reversed value
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __REV(uint32_t value)
+__STATIC_FORCEINLINE uint32_t __REV(uint32_t value)
#if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 5)
return __builtin_bswap32(value);
@@ -456,41 +905,41 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __REV(uint32_t value)
uint32_t result;
__ASM volatile ("rev %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
- return(result);
+ return result;
#endif
\brief Reverse byte order (16 bit)
- \details Reverses the byte order in two unsigned short values.
+ \details Reverses the byte order within each halfword of a word. For example, 0x12345678 becomes 0x34127856.
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __REV16(uint32_t value)
+__STATIC_FORCEINLINE uint32_t __REV16(uint32_t value)
uint32_t result;
__ASM volatile ("rev16 %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
- return(result);
+ return result;
- \brief Reverse byte order in signed short value
- \details Reverses the byte order in a signed short value with sign extension to integer.
+ \brief Reverse byte order (16 bit)
+ \details Reverses the byte order in a 16-bit value and returns the signed 16-bit result. For example, 0x0080 becomes 0x8000.
-__attribute__((always_inline)) __STATIC_INLINE int32_t __REVSH(int32_t value)
+__STATIC_FORCEINLINE int16_t __REVSH(int16_t value)
#if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)
- return (short)__builtin_bswap16(value);
+ return (int16_t)__builtin_bswap16(value);
#else
- int32_t result;
+ int16_t result;
__ASM volatile ("revsh %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
- return(result);
+ return result;
#endif
@@ -498,12 +947,17 @@ __attribute__((always_inline)) __STATIC_INLINE int32_t __REVSH(int32_t value)
\brief Rotate Right in unsigned value (32 bit)
\details Rotate Right (immediate) provides the value of the contents of a register rotated by a variable number of bits.
- \param [in] value Value to rotate
- \param [in] value Number of Bits to rotate
+ \param [in] op1 Value to rotate
+ \param [in] op2 Number of Bits to rotate
\return Rotated value
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __ROR(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __ROR(uint32_t op1, uint32_t op2)
+ op2 %= 32U;
+ if (op2 == 0U)
+ return op1;
return (op1 >> op2) | (op1 << (32U - op2));
@@ -524,17 +978,19 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __ROR(uint32_t op1, uint
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __RBIT(uint32_t value)
+__STATIC_FORCEINLINE uint32_t __RBIT(uint32_t value)
uint32_t result;
-#if (__CORTEX_M >= 0x03U) || (__CORTEX_SC >= 300U)
__ASM volatile ("rbit %0, %1" : "=r" (result) : "r" (value) );
#else
- int32_t s = 4 /*sizeof(v)*/ * 8 - 1; /* extra shift needed at end */
+ uint32_t s = (4U /*sizeof(v)*/ * 8U) - 1U; /* extra shift needed at end */
result = value; /* r will be reversed bits of v; first get LSB of v */
- for (value >>= 1U; value; value >>= 1U)
+ for (value >>= 1U; value != 0U; value >>= 1U)
result <<= 1U;
result |= value & 1U;
@@ -542,7 +998,7 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __RBIT(uint32_t value)
result <<= s; /* shift when v's highest bits are zero */
#endif
- return(result);
+ return result;
@@ -552,18 +1008,20 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __RBIT(uint32_t value)
\param [in] value Value to count the leading zeros
\return number of leading zeros in value
-#define __CLZ __builtin_clz
+#define __CLZ (uint8_t)__builtin_clz
+ (defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) || \
\brief LDR Exclusive (8 bit)
\details Executes a exclusive LDR instruction for 8 bit value.
\param [in] ptr Pointer to data
\return value of type uint8_t at (*ptr)
-__attribute__((always_inline)) __STATIC_INLINE uint8_t __LDREXB(volatile uint8_t *addr)
+__STATIC_FORCEINLINE uint8_t __LDREXB(volatile uint8_t *addr)
uint32_t result;
@@ -585,7 +1043,7 @@ __attribute__((always_inline)) __STATIC_INLINE uint8_t __LDREXB(volatile uint8_t
\return value of type uint16_t at (*ptr)
-__attribute__((always_inline)) __STATIC_INLINE uint16_t __LDREXH(volatile uint16_t *addr)
+__STATIC_FORCEINLINE uint16_t __LDREXH(volatile uint16_t *addr)
uint32_t result;
@@ -607,7 +1065,7 @@ __attribute__((always_inline)) __STATIC_INLINE uint16_t __LDREXH(volatile uint16
\return value of type uint32_t at (*ptr)
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __LDREXW(volatile uint32_t *addr)
+__STATIC_FORCEINLINE uint32_t __LDREXW(volatile uint32_t *addr)
uint32_t result;
@@ -624,7 +1082,7 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __LDREXW(volatile uint32
\return 0 Function succeeded
\return 1 Function failed
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXB(uint8_t value, volatile uint8_t *addr)
+__STATIC_FORCEINLINE uint32_t __STREXB(uint8_t value, volatile uint8_t *addr)
uint32_t result;
@@ -641,7 +1099,7 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXB(uint8_t value,
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXH(uint16_t value, volatile uint16_t *addr)
+__STATIC_FORCEINLINE uint32_t __STREXH(uint16_t value, volatile uint16_t *addr)
uint32_t result;
@@ -658,7 +1116,7 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXH(uint16_t value,
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXW(uint32_t value, volatile uint32_t *addr)
+__STATIC_FORCEINLINE uint32_t __STREXW(uint32_t value, volatile uint32_t *addr)
uint32_t result;
@@ -671,22 +1129,31 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXW(uint32_t value,
\brief Remove the exclusive lock
\details Removes the exclusive lock which is created by LDREX.
-__attribute__((always_inline)) __STATIC_INLINE void __CLREX(void)
+__STATIC_FORCEINLINE void __CLREX(void)
__ASM volatile ("clrex" ::: "memory");
\brief Signed Saturate
\details Saturates a signed value.
- \param [in] value Value to be saturated
- \param [in] sat Bit position to saturate to (1..32)
+ \param [in] ARG1 Value to be saturated
+ \param [in] ARG2 Bit position to saturate to (1..32)
\return Saturated value
#define __SSAT(ARG1,ARG2) \
+__extension__ \
- uint32_t __RES, __ARG1 = (ARG1); \
+ int32_t __RES, __ARG1 = (ARG1); \
__ASM ("ssat %0, %1, %2" : "=r" (__RES) : "I" (ARG2), "r" (__ARG1) ); \
__RES; \
@@ -695,11 +1162,12 @@ __attribute__((always_inline)) __STATIC_INLINE void __CLREX(void)
\brief Unsigned Saturate
\details Saturates an unsigned value.
- \param [in] sat Bit position to saturate to (0..31)
+ \param [in] ARG2 Bit position to saturate to (0..31)
#define __USAT(ARG1,ARG2) \
+ __extension__ \
__ASM ("usat %0, %1, %2" : "=r" (__RES) : "I" (ARG2), "r" (__ARG1) ); \
@@ -714,7 +1182,7 @@ __attribute__((always_inline)) __STATIC_INLINE void __CLREX(void)
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __RRX(uint32_t value)
+__STATIC_FORCEINLINE uint32_t __RRX(uint32_t value)
uint32_t result;
@@ -729,17 +1197,17 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __RRX(uint32_t value)
-__attribute__((always_inline)) __STATIC_INLINE uint8_t __LDRBT(volatile uint8_t *addr)
+__STATIC_FORCEINLINE uint8_t __LDRBT(volatile uint8_t *ptr)
uint32_t result;
- __ASM volatile ("ldrbt %0, %1" : "=r" (result) : "Q" (*addr) );
+ __ASM volatile ("ldrbt %0, %1" : "=r" (result) : "Q" (*ptr) );
#else
/* Prior to GCC 4.8, "Q" will be expanded to [rx, #0] which is not
accepted by assembler. So has to use following less efficient pattern.
- __ASM volatile ("ldrbt %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
+ __ASM volatile ("ldrbt %0, [%1]" : "=r" (result) : "r" (ptr) : "memory" );
#endif
return ((uint8_t) result); /* Add explicit type cast here */
@@ -751,17 +1219,17 @@ __attribute__((always_inline)) __STATIC_INLINE uint8_t __LDRBT(volatile uint8_t
-__attribute__((always_inline)) __STATIC_INLINE uint16_t __LDRHT(volatile uint16_t *addr)
+__STATIC_FORCEINLINE uint16_t __LDRHT(volatile uint16_t *ptr)
uint32_t result;
- __ASM volatile ("ldrht %0, %1" : "=r" (result) : "Q" (*addr) );
+ __ASM volatile ("ldrht %0, %1" : "=r" (result) : "Q" (*ptr) );
#else
- __ASM volatile ("ldrht %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
+ __ASM volatile ("ldrht %0, [%1]" : "=r" (result) : "r" (ptr) : "memory" );
#endif
return ((uint16_t) result); /* Add explicit type cast here */
@@ -773,11 +1241,11 @@ __attribute__((always_inline)) __STATIC_INLINE uint16_t __LDRHT(volatile uint16_
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __LDRT(volatile uint32_t *addr)
+__STATIC_FORCEINLINE uint32_t __LDRT(volatile uint32_t *ptr)
uint32_t result;
- __ASM volatile ("ldrt %0, %1" : "=r" (result) : "Q" (*addr) );
+ __ASM volatile ("ldrt %0, %1" : "=r" (result) : "Q" (*ptr) );
return(result);
@@ -788,9 +1256,9 @@ __attribute__((always_inline)) __STATIC_INLINE uint32_t __LDRT(volatile uint32_t
\param [in] value Value to store
\param [in] ptr Pointer to location
-__attribute__((always_inline)) __STATIC_INLINE void __STRBT(uint8_t value, volatile uint8_t *addr)
+__STATIC_FORCEINLINE void __STRBT(uint8_t value, volatile uint8_t *ptr)
- __ASM volatile ("strbt %1, %0" : "=Q" (*addr) : "r" ((uint32_t)value) );
+ __ASM volatile ("strbt %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) );
@@ -800,9 +1268,9 @@ __attribute__((always_inline)) __STATIC_INLINE void __STRBT(uint8_t value, volat
-__attribute__((always_inline)) __STATIC_INLINE void __STRHT(uint16_t value, volatile uint16_t *addr)
+__STATIC_FORCEINLINE void __STRHT(uint16_t value, volatile uint16_t *ptr)
- __ASM volatile ("strht %1, %0" : "=Q" (*addr) : "r" ((uint32_t)value) );
+ __ASM volatile ("strht %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) );
@@ -812,26 +1280,262 @@ __attribute__((always_inline)) __STATIC_INLINE void __STRHT(uint16_t value, vola
-__attribute__((always_inline)) __STATIC_INLINE void __STRT(uint32_t value, volatile uint32_t *addr)
+__STATIC_FORCEINLINE void __STRT(uint32_t value, volatile uint32_t *ptr)
+ __ASM volatile ("strt %1, %0" : "=Q" (*ptr) : "r" (value) );
+#else /* ((defined (__ARM_ARCH_7M__ ) && (__ARM_ARCH_7M__ == 1)) || \
+ \brief Signed Saturate
+ \details Saturates a signed value.
+ \param [in] value Value to be saturated
+ \param [in] sat Bit position to saturate to (1..32)
+ \return Saturated value
+__STATIC_FORCEINLINE int32_t __SSAT(int32_t val, uint32_t sat)
+ if ((sat >= 1U) && (sat <= 32U))
+ const int32_t max = (int32_t)((1U << (sat - 1U)) - 1U);
+ const int32_t min = -1 - max ;
+ if (val > max)
+ return max;
+ else if (val < min)
+ return min;
+ return val;
+ \brief Unsigned Saturate
+ \details Saturates an unsigned value.
+ \param [in] sat Bit position to saturate to (0..31)
+__STATIC_FORCEINLINE uint32_t __USAT(int32_t val, uint32_t sat)
+ if (sat <= 31U)
+ const uint32_t max = ((1U << sat) - 1U);
+ if (val > (int32_t)max)
+ return max;
+ else if (val < 0)
+ return 0U;
+ return (uint32_t)val;
+ \brief Load-Acquire (8 bit)
+ \details Executes a LDAB instruction for 8 bit value.
+ \param [in] ptr Pointer to data
+ \return value of type uint8_t at (*ptr)
+__STATIC_FORCEINLINE uint8_t __LDAB(volatile uint8_t *ptr)
+ uint32_t result;
+ __ASM volatile ("ldab %0, %1" : "=r" (result) : "Q" (*ptr) );
+ return ((uint8_t) result);
+ \brief Load-Acquire (16 bit)
+ \details Executes a LDAH instruction for 16 bit values.
+ \return value of type uint16_t at (*ptr)
+__STATIC_FORCEINLINE uint16_t __LDAH(volatile uint16_t *ptr)
- __ASM volatile ("strt %1, %0" : "=Q" (*addr) : "r" (value) );
+ uint32_t result;
+ __ASM volatile ("ldah %0, %1" : "=r" (result) : "Q" (*ptr) );
+ return ((uint16_t) result);
-#endif /* (__CORTEX_M >= 0x03U) || (__CORTEX_SC >= 300U) */
+ \brief Load-Acquire (32 bit)
+ \details Executes a LDA instruction for 32 bit values.
+ \return value of type uint32_t at (*ptr)
+__STATIC_FORCEINLINE uint32_t __LDA(volatile uint32_t *ptr)
+ uint32_t result;
+ __ASM volatile ("lda %0, %1" : "=r" (result) : "Q" (*ptr) );
+ return(result);
+ \brief Store-Release (8 bit)
+ \details Executes a STLB instruction for 8 bit values.
+ \param [in] value Value to store
+ \param [in] ptr Pointer to location
+__STATIC_FORCEINLINE void __STLB(uint8_t value, volatile uint8_t *ptr)
+ __ASM volatile ("stlb %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) );
+ \brief Store-Release (16 bit)
+ \details Executes a STLH instruction for 16 bit values.
+__STATIC_FORCEINLINE void __STLH(uint16_t value, volatile uint16_t *ptr)
+ __ASM volatile ("stlh %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) );
+ \brief Store-Release (32 bit)
+ \details Executes a STL instruction for 32 bit values.
+__STATIC_FORCEINLINE void __STL(uint32_t value, volatile uint32_t *ptr)
+ __ASM volatile ("stl %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) );
+ \brief Load-Acquire Exclusive (8 bit)
+ \details Executes a LDAB exclusive instruction for 8 bit value.
+__STATIC_FORCEINLINE uint8_t __LDAEXB(volatile uint8_t *ptr)
+ uint32_t result;
+ __ASM volatile ("ldaexb %0, %1" : "=r" (result) : "Q" (*ptr) );
+ \brief Load-Acquire Exclusive (16 bit)
+ \details Executes a LDAH exclusive instruction for 16 bit values.
+__STATIC_FORCEINLINE uint16_t __LDAEXH(volatile uint16_t *ptr)
+ uint32_t result;
+ __ASM volatile ("ldaexh %0, %1" : "=r" (result) : "Q" (*ptr) );
+ \brief Load-Acquire Exclusive (32 bit)
+ \details Executes a LDA exclusive instruction for 32 bit values.
+__STATIC_FORCEINLINE uint32_t __LDAEX(volatile uint32_t *ptr)
+ uint32_t result;
+ __ASM volatile ("ldaex %0, %1" : "=r" (result) : "Q" (*ptr) );
+ return(result);
+ \brief Store-Release Exclusive (8 bit)
+ \details Executes a STLB exclusive instruction for 8 bit values.
+ \return 0 Function succeeded
+ \return 1 Function failed
+__STATIC_FORCEINLINE uint32_t __STLEXB(uint8_t value, volatile uint8_t *ptr)
+ uint32_t result;
+ __ASM volatile ("stlexb %0, %2, %1" : "=&r" (result), "=Q" (*ptr) : "r" ((uint32_t)value) );
+ return(result);
+ \brief Store-Release Exclusive (16 bit)
+ \details Executes a STLH exclusive instruction for 16 bit values.
+__STATIC_FORCEINLINE uint32_t __STLEXH(uint16_t value, volatile uint16_t *ptr)
+ uint32_t result;
+ __ASM volatile ("stlexh %0, %2, %1" : "=&r" (result), "=Q" (*ptr) : "r" ((uint32_t)value) );
+ return(result);
+ \brief Store-Release Exclusive (32 bit)
+ \details Executes a STL exclusive instruction for 32 bit values.
+__STATIC_FORCEINLINE uint32_t __STLEX(uint32_t value, volatile uint32_t *ptr)
+ uint32_t result;
+ __ASM volatile ("stlex %0, %2, %1" : "=&r" (result), "=Q" (*ptr) : "r" ((uint32_t)value) );
+ return(result);
/*@}*/ /* end of group CMSIS_Core_InstructionInterface */
/* ################### Compiler specific Intrinsics ########################### */
/** \defgroup CMSIS_SIMD_intrinsics CMSIS SIMD Intrinsics
- \ingroup CMSIS
Access to dedicated SIMD instructions
-#if (__CORTEX_M >= 0x04U) /* only for Cortex-M4 and above */
+#if (defined (__ARM_FEATURE_DSP) && (__ARM_FEATURE_DSP == 1))
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SADD8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SADD8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -839,7 +1543,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SADD8(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QADD8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __QADD8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -847,7 +1551,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QADD8(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHADD8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SHADD8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -855,7 +1559,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHADD8(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UADD8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UADD8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -863,7 +1567,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UADD8(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQADD8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UQADD8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -871,7 +1575,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQADD8(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHADD8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UHADD8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -880,7 +1584,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHADD8(uint32_t op
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSUB8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SSUB8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -888,7 +1592,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSUB8(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSUB8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __QSUB8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -896,7 +1600,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSUB8(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSUB8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SHSUB8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -904,7 +1608,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSUB8(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USUB8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __USUB8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -912,7 +1616,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USUB8(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSUB8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UQSUB8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -920,7 +1624,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSUB8(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSUB8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UHSUB8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -929,7 +1633,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSUB8(uint32_t op
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SADD16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SADD16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -937,7 +1641,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SADD16(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QADD16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __QADD16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -945,7 +1649,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QADD16(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHADD16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SHADD16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -953,7 +1657,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHADD16(uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UADD16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UADD16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -961,7 +1665,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UADD16(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQADD16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UQADD16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -969,7 +1673,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQADD16(uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHADD16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UHADD16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -977,7 +1681,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHADD16(uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSUB16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SSUB16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -985,7 +1689,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSUB16(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSUB16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __QSUB16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -993,7 +1697,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSUB16(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSUB16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SHSUB16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1001,7 +1705,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSUB16(uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USUB16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __USUB16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1009,7 +1713,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USUB16(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSUB16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UQSUB16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1017,7 +1721,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSUB16(uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSUB16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UHSUB16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1025,7 +1729,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSUB16(uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SASX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SASX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1033,7 +1737,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SASX(uint32_t op1,
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QASX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __QASX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1041,7 +1745,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QASX(uint32_t op1,
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHASX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SHASX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1049,7 +1753,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHASX(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UASX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UASX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1057,7 +1761,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UASX(uint32_t op1,
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQASX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UQASX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1065,7 +1769,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQASX(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHASX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UHASX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1073,7 +1777,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHASX(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSAX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SSAX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1081,7 +1785,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSAX(uint32_t op1,
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSAX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __QSAX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1089,7 +1793,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSAX(uint32_t op1,
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSAX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SHSAX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1097,7 +1801,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSAX(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USAX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __USAX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1105,7 +1809,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USAX(uint32_t op1,
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSAX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UQSAX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1113,7 +1817,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSAX(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSAX(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UHSAX(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1121,7 +1825,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSAX(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USAD8(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __USAD8(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1129,7 +1833,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USAD8(uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USADA8(uint32_t op1, uint32_t op2, uint32_t op3)
+__STATIC_FORCEINLINE uint32_t __USADA8(uint32_t op1, uint32_t op2, uint32_t op3)
uint32_t result;
@@ -1151,7 +1855,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USADA8(uint32_t op
__RES; \
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UXTB16(uint32_t op1)
+__STATIC_FORCEINLINE uint32_t __UXTB16(uint32_t op1)
uint32_t result;
@@ -1159,7 +1863,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UXTB16(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UXTAB16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __UXTAB16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1167,7 +1871,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UXTAB16(uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SXTB16(uint32_t op1)
+__STATIC_FORCEINLINE uint32_t __SXTB16(uint32_t op1)
uint32_t result;
@@ -1175,7 +1879,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SXTB16(uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SXTAB16(uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SXTAB16(uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1183,7 +1887,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SXTAB16(uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUAD (uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SMUAD (uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1191,7 +1895,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUAD (uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUADX (uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SMUADX (uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1199,7 +1903,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUADX (uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLAD (uint32_t op1, uint32_t op2, uint32_t op3)
+__STATIC_FORCEINLINE uint32_t __SMLAD (uint32_t op1, uint32_t op2, uint32_t op3)
uint32_t result;
@@ -1207,7 +1911,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLAD (uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLADX (uint32_t op1, uint32_t op2, uint32_t op3)
+__STATIC_FORCEINLINE uint32_t __SMLADX (uint32_t op1, uint32_t op2, uint32_t op3)
uint32_t result;
@@ -1215,7 +1919,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLADX (uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALD (uint32_t op1, uint32_t op2, uint64_t acc)
+__STATIC_FORCEINLINE uint64_t __SMLALD (uint32_t op1, uint32_t op2, uint64_t acc)
union llreg_u{
uint32_t w32[2];
@@ -1232,7 +1936,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALD (uint32_t o
return(llr.w64);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALDX (uint32_t op1, uint32_t op2, uint64_t acc)
+__STATIC_FORCEINLINE uint64_t __SMLALDX (uint32_t op1, uint32_t op2, uint64_t acc)
union llreg_u{
uint32_t w32[2];
@@ -1249,7 +1953,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALDX (uint32_t
return(llr.w64);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUSD (uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SMUSD (uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1257,7 +1961,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUSD (uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUSDX (uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SMUSDX (uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1265,7 +1969,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUSDX (uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLSD (uint32_t op1, uint32_t op2, uint32_t op3)
+__STATIC_FORCEINLINE uint32_t __SMLSD (uint32_t op1, uint32_t op2, uint32_t op3)
uint32_t result;
@@ -1273,7 +1977,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLSD (uint32_t op
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLSDX (uint32_t op1, uint32_t op2, uint32_t op3)
+__STATIC_FORCEINLINE uint32_t __SMLSDX (uint32_t op1, uint32_t op2, uint32_t op3)
uint32_t result;
@@ -1281,7 +1985,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLSDX (uint32_t o
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLSLD (uint32_t op1, uint32_t op2, uint64_t acc)
+__STATIC_FORCEINLINE uint64_t __SMLSLD (uint32_t op1, uint32_t op2, uint64_t acc)
union llreg_u{
uint32_t w32[2];
@@ -1298,7 +2002,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLSLD (uint32_t o
return(llr.w64);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLSLDX (uint32_t op1, uint32_t op2, uint64_t acc)
+__STATIC_FORCEINLINE uint64_t __SMLSLDX (uint32_t op1, uint32_t op2, uint64_t acc)
union llreg_u{
uint32_t w32[2];
@@ -1315,7 +2019,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLSLDX (uint32_t
return(llr.w64);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SEL (uint32_t op1, uint32_t op2)
+__STATIC_FORCEINLINE uint32_t __SEL (uint32_t op1, uint32_t op2)
uint32_t result;
@@ -1323,7 +2027,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SEL (uint32_t op1
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE int32_t __QADD( int32_t op1, int32_t op2)
+__STATIC_FORCEINLINE int32_t __QADD( int32_t op1, int32_t op2)
int32_t result;
@@ -1331,7 +2035,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE int32_t __QADD( int32_t op1,
return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE int32_t __QSUB( int32_t op1, int32_t op2)
+__STATIC_FORCEINLINE int32_t __QSUB( int32_t op1, int32_t op2)
int32_t result;
@@ -1339,6 +2043,7 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE int32_t __QSUB( int32_t op1,
return(result);
+#if 0
#define __PKHBT(ARG1,ARG2,ARG3) \
uint32_t __RES, __ARG1 = (ARG1), __ARG2 = (ARG2); \
@@ -1355,8 +2060,15 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE int32_t __QSUB( int32_t op1,
__ASM ("pkhtb %0, %1, %2, asr %3" : "=r" (__RES) : "r" (__ARG1), "r" (__ARG2), "I" (ARG3) ); \
__RES; \
+#endif
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMMLA (int32_t op1, int32_t op2, int32_t op3)
+#define __PKHBT(ARG1,ARG2,ARG3) ( ((((uint32_t)(ARG1)) ) & 0x0000FFFFUL) | \
+ ((((uint32_t)(ARG2)) << (ARG3)) & 0xFFFF0000UL) )
+#define __PKHTB(ARG1,ARG2,ARG3) ( ((((uint32_t)(ARG1)) ) & 0xFFFF0000UL) | \
+ ((((uint32_t)(ARG2)) >> (ARG3)) & 0x0000FFFFUL) )
+__STATIC_FORCEINLINE int32_t __SMMLA (int32_t op1, int32_t op2, int32_t op3)
int32_t result;
@@ -1364,12 +2076,10 @@ __attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMMLA (int32_t op1
return(result);
-#endif /* (__CORTEX_M >= 0x04) */
+#endif /* (__ARM_FEATURE_DSP == 1) */
/*@} end of group CMSIS_SIMD_intrinsics */
-#endif
#endif /* __CMSIS_GCC_H */
diff --git a/bsps/arm/include/cmsis_version.h b/bsps/arm/include/cmsis_version.h
new file mode 100644
index 0000000000..660f612aa3
--- /dev/null
+++ b/bsps/arm/include/cmsis_version.h
@@ -0,0 +1,39 @@
+ * @file cmsis_version.h
+ * @brief CMSIS Core(M) Version definitions
+ * @version V5.0.2
+ * @date 19. April 2017
+ * Copyright (c) 2009-2017 ARM Limited. All rights reserved.
+ * SPDX-License-Identifier: Apache-2.0
+ * Licensed under the Apache License, Version 2.0 (the License); you may
+ * not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an AS IS BASIS, WITHOUT
+ * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+#if defined ( __ICCARM__ )
+ #pragma system_include /* treat file as system include file for MISRA check */
+#elif defined (__clang__)
+ #pragma clang system_header /* treat file as system include file */
+#endif
+#ifndef __CMSIS_VERSION_H
+#define __CMSIS_VERSION_H
+/* CMSIS Version definitions */
+#define __CM_CMSIS_VERSION_MAIN ( 5U) /*!< [31:16] CMSIS Core(M) main version */
+#define __CM_CMSIS_VERSION_SUB ( 1U) /*!< [15:0] CMSIS Core(M) sub version */
+#define __CM_CMSIS_VERSION ((__CM_CMSIS_VERSION_MAIN << 16U) | \
+ __CM_CMSIS_VERSION_SUB ) /*!< CMSIS Core(M) version number */
+#endif
diff --git a/bsps/arm/include/core_cm4.h b/bsps/arm/include/core_cm4.h
index dc840ebf22..7d56873532 100644
--- a/bsps/arm/include/core_cm4.h
+++ b/bsps/arm/include/core_cm4.h
@@ -1,40 +1,30 @@
* @file core_cm4.h
* @brief CMSIS Cortex-M4 Core Peripheral Access Layer Header File
- * @version V4.30
- * @date 20. October 2015
+ * @version V5.0.8
+ * @date 04. June 2018
-/* Copyright (c) 2009 - 2015 ARM LIMITED
- All rights reserved.
- Redistribution and use in source and binary forms, with or without
- modification, are permitted provided that the following conditions are met:
- - Redistributions of source code must retain the above copyright
- notice, this list of conditions and the following disclaimer.
- - Redistributions in binary form must reproduce the above copyright
- notice, this list of conditions and the following disclaimer in the
- documentation and/or other materials provided with the distribution.
- - Neither the name of ARM nor the names of its contributors may be used
- to endorse or promote products derived from this software without
- specific prior written permission.
- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- POSSIBILITY OF SUCH DAMAGE.
+ * Copyright (c) 2009-2018 Arm Limited. All rights reserved.
- #pragma system_include /* treat file as system include file for MISRA check */
-#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
#endif
@@ -70,60 +60,22 @@
-/* CMSIS CM4 definitions */
-#define __CM4_CMSIS_VERSION_MAIN (0x04U) /*!< [31:16] CMSIS HAL main version */
-#define __CM4_CMSIS_VERSION_SUB (0x1EU) /*!< [15:0] CMSIS HAL sub version */
-#define __CM4_CMSIS_VERSION ((__CM4_CMSIS_VERSION_MAIN << 16U) | \
- __CM4_CMSIS_VERSION_SUB ) /*!< CMSIS HAL version number */
-#define __CORTEX_M (0x04U) /*!< Cortex-M Core */
-#if defined ( __CC_ARM )
- #define __ASM __asm /*!< asm keyword for ARM Compiler */
- #define __INLINE __inline /*!< inline keyword for ARM Compiler */
- #define __STATIC_INLINE static __inline
-#elif defined ( __GNUC__ )
- #define __ASM __asm /*!< asm keyword for GNU Compiler */
- #define __INLINE inline /*!< inline keyword for GNU Compiler */
- #define __STATIC_INLINE static inline
-#elif defined ( __ICCARM__ )
- #define __ASM __asm /*!< asm keyword for IAR Compiler */
- #define __INLINE inline /*!< inline keyword for IAR Compiler. Only available in High optimization mode! */
-#elif defined ( __TMS470__ )
- #define __ASM __asm /*!< asm keyword for TI CCS Compiler */
+#include "cmsis_version.h"
-#elif defined ( __TASKING__ )
- #define __ASM __asm /*!< asm keyword for TASKING Compiler */
- #define __INLINE inline /*!< inline keyword for TASKING Compiler */
-#elif defined ( __CSMC__ )
- #define __packed
- #define __ASM _asm /*!< asm keyword for COSMIC Compiler */
- #define __INLINE inline /*!< inline keyword for COSMIC Compiler. Use -pc99 on compile line */
+/* CMSIS CM4 definitions */
+#define __CM4_CMSIS_VERSION_MAIN (__CM_CMSIS_VERSION_MAIN) /*!< \deprecated [31:16] CMSIS HAL main version */
+#define __CM4_CMSIS_VERSION_SUB (__CM_CMSIS_VERSION_SUB) /*!< \deprecated [15:0] CMSIS HAL sub version */
+#define __CM4_CMSIS_VERSION ((__CM4_CMSIS_VERSION_MAIN << 16U) | \
+ __CM4_CMSIS_VERSION_SUB ) /*!< \deprecated CMSIS HAL version number */
-#else
- #error Unknown compiler
-#endif
+#define __CORTEX_M (4U) /*!< Cortex-M Core */
/** __FPU_USED indicates whether an FPU is used or not.
For this, __FPU_PRESENT has to be checked prior to making use of FPU specific registers and functions.
#if defined __TARGET_FPU_VFP
- #if (__FPU_PRESENT == 1U)
+ #if defined (__FPU_PRESENT) && (__FPU_PRESENT == 1U)
#define __FPU_USED 1U
#else
#error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
@@ -133,9 +85,9 @@
#define __FPU_USED 0U
#endif
+#elif defined (__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
#if defined __ARM_PCS_VFP
- #if (__FPU_PRESENT == 1)
#else
#warning "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
@@ -147,7 +99,7 @@
#if defined (__VFP_FP__) && !defined(__SOFTFP__)
#else
@@ -159,7 +111,7 @@
#if defined __ARMVFP__
#else
@@ -169,9 +121,9 @@
#endif
+#elif defined ( __TI_ARM__ )
#if defined __TI_VFP_SUPPORT__
#else
@@ -183,7 +135,7 @@
#if defined __FPU_VFP__
#else
@@ -195,7 +147,7 @@
#if ( __CSMC__ & 0x400U)
#else
@@ -207,9 +159,8 @@
#endif
-#include "core_cmInstr.h" /* Core Instruction Access */
-#include "core_cmFunc.h" /* Core Function Access */
-#include "core_cmSimd.h" /* Compiler specific SIMD Intrinsics */
+#include "cmsis_compiler.h" /* CMSIS compiler specific defines */
#ifdef __cplusplus
@@ -244,7 +195,7 @@
#endif
#ifndef __NVIC_PRIO_BITS
- #define __NVIC_PRIO_BITS 4U
+ #define __NVIC_PRIO_BITS 3U
#warning "__NVIC_PRIO_BITS not defined in device header file; using default!"
#endif
@@ -367,11 +318,12 @@ typedef union
struct
uint32_t ISR:9; /*!< bit: 0.. 8 Exception number */
- uint32_t _reserved0:7; /*!< bit: 9..15 Reserved */
+ uint32_t _reserved0:1; /*!< bit: 9 Reserved */
+ uint32_t ICI_IT_1:6; /*!< bit: 10..15 ICI/IT part 1 */
uint32_t GE:4; /*!< bit: 16..19 Greater than or Equal flags */
uint32_t _reserved1:4; /*!< bit: 20..23 Reserved */
- uint32_t T:1; /*!< bit: 24 Thumb bit (read 0) */
- uint32_t IT:2; /*!< bit: 25..26 saved IT state (read 0) */
+ uint32_t T:1; /*!< bit: 24 Thumb bit */
+ uint32_t ICI_IT_2:2; /*!< bit: 25..26 ICI/IT part 2 */
uint32_t Q:1; /*!< bit: 27 Saturation condition flag */
uint32_t V:1; /*!< bit: 28 Overflow condition code flag */
uint32_t C:1; /*!< bit: 29 Carry condition code flag */
@@ -397,8 +349,8 @@ typedef union
#define xPSR_Q_Pos 27U /*!< xPSR: Q Position */
#define xPSR_Q_Msk (1UL << xPSR_Q_Pos) /*!< xPSR: Q Mask */
-#define xPSR_IT_Pos 25U /*!< xPSR: IT Position */
-#define xPSR_IT_Msk (3UL << xPSR_IT_Pos) /*!< xPSR: IT Mask */
+#define xPSR_ICI_IT_2_Pos 25U /*!< xPSR: ICI/IT part 2 Position */
+#define xPSR_ICI_IT_2_Msk (3UL << xPSR_ICI_IT_2_Pos) /*!< xPSR: ICI/IT part 2 Mask */
#define xPSR_T_Pos 24U /*!< xPSR: T Position */
#define xPSR_T_Msk (1UL << xPSR_T_Pos) /*!< xPSR: T Mask */
@@ -406,6 +358,9 @@ typedef union
#define xPSR_GE_Pos 16U /*!< xPSR: GE Position */
#define xPSR_GE_Msk (0xFUL << xPSR_GE_Pos) /*!< xPSR: GE Mask */
+#define xPSR_ICI_IT_1_Pos 10U /*!< xPSR: ICI/IT part 1 Position */
+#define xPSR_ICI_IT_1_Msk (0x3FUL << xPSR_ICI_IT_1_Pos) /*!< xPSR: ICI/IT part 1 Mask */
#define xPSR_ISR_Pos 0U /*!< xPSR: ISR Position */
#define xPSR_ISR_Msk (0x1FFUL /*<< xPSR_ISR_Pos*/) /*!< xPSR: ISR Mask */
@@ -662,6 +617,66 @@ typedef struct
#define SCB_CFSR_MEMFAULTSR_Pos 0U /*!< SCB CFSR: Memory Manage Fault Status Register Position */
#define SCB_CFSR_MEMFAULTSR_Msk (0xFFUL /*<< SCB_CFSR_MEMFAULTSR_Pos*/) /*!< SCB CFSR: Memory Manage Fault Status Register Mask */
+/* MemManage Fault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_MMARVALID_Pos (SCB_SHCSR_MEMFAULTACT_Pos + 7U) /*!< SCB CFSR (MMFSR): MMARVALID Position */
+#define SCB_CFSR_MMARVALID_Msk (1UL << SCB_CFSR_MMARVALID_Pos) /*!< SCB CFSR (MMFSR): MMARVALID Mask */
+#define SCB_CFSR_MLSPERR_Pos (SCB_SHCSR_MEMFAULTACT_Pos + 5U) /*!< SCB CFSR (MMFSR): MLSPERR Position */
+#define SCB_CFSR_MLSPERR_Msk (1UL << SCB_CFSR_MLSPERR_Pos) /*!< SCB CFSR (MMFSR): MLSPERR Mask */
+#define SCB_CFSR_MSTKERR_Pos (SCB_SHCSR_MEMFAULTACT_Pos + 4U) /*!< SCB CFSR (MMFSR): MSTKERR Position */
+#define SCB_CFSR_MSTKERR_Msk (1UL << SCB_CFSR_MSTKERR_Pos) /*!< SCB CFSR (MMFSR): MSTKERR Mask */
+#define SCB_CFSR_MUNSTKERR_Pos (SCB_SHCSR_MEMFAULTACT_Pos + 3U) /*!< SCB CFSR (MMFSR): MUNSTKERR Position */
+#define SCB_CFSR_MUNSTKERR_Msk (1UL << SCB_CFSR_MUNSTKERR_Pos) /*!< SCB CFSR (MMFSR): MUNSTKERR Mask */
+#define SCB_CFSR_DACCVIOL_Pos (SCB_SHCSR_MEMFAULTACT_Pos + 1U) /*!< SCB CFSR (MMFSR): DACCVIOL Position */
+#define SCB_CFSR_DACCVIOL_Msk (1UL << SCB_CFSR_DACCVIOL_Pos) /*!< SCB CFSR (MMFSR): DACCVIOL Mask */
+#define SCB_CFSR_IACCVIOL_Pos (SCB_SHCSR_MEMFAULTACT_Pos + 0U) /*!< SCB CFSR (MMFSR): IACCVIOL Position */
+#define SCB_CFSR_IACCVIOL_Msk (1UL /*<< SCB_CFSR_IACCVIOL_Pos*/) /*!< SCB CFSR (MMFSR): IACCVIOL Mask */
+/* BusFault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_BFARVALID_Pos (SCB_CFSR_BUSFAULTSR_Pos + 7U) /*!< SCB CFSR (BFSR): BFARVALID Position */
+#define SCB_CFSR_BFARVALID_Msk (1UL << SCB_CFSR_BFARVALID_Pos) /*!< SCB CFSR (BFSR): BFARVALID Mask */
+#define SCB_CFSR_LSPERR_Pos (SCB_CFSR_BUSFAULTSR_Pos + 5U) /*!< SCB CFSR (BFSR): LSPERR Position */
+#define SCB_CFSR_LSPERR_Msk (1UL << SCB_CFSR_LSPERR_Pos) /*!< SCB CFSR (BFSR): LSPERR Mask */
+#define SCB_CFSR_STKERR_Pos (SCB_CFSR_BUSFAULTSR_Pos + 4U) /*!< SCB CFSR (BFSR): STKERR Position */
+#define SCB_CFSR_STKERR_Msk (1UL << SCB_CFSR_STKERR_Pos) /*!< SCB CFSR (BFSR): STKERR Mask */
+#define SCB_CFSR_UNSTKERR_Pos (SCB_CFSR_BUSFAULTSR_Pos + 3U) /*!< SCB CFSR (BFSR): UNSTKERR Position */
+#define SCB_CFSR_UNSTKERR_Msk (1UL << SCB_CFSR_UNSTKERR_Pos) /*!< SCB CFSR (BFSR): UNSTKERR Mask */
+#define SCB_CFSR_IMPRECISERR_Pos (SCB_CFSR_BUSFAULTSR_Pos + 2U) /*!< SCB CFSR (BFSR): IMPRECISERR Position */
+#define SCB_CFSR_IMPRECISERR_Msk (1UL << SCB_CFSR_IMPRECISERR_Pos) /*!< SCB CFSR (BFSR): IMPRECISERR Mask */
+#define SCB_CFSR_PRECISERR_Pos (SCB_CFSR_BUSFAULTSR_Pos + 1U) /*!< SCB CFSR (BFSR): PRECISERR Position */
+#define SCB_CFSR_PRECISERR_Msk (1UL << SCB_CFSR_PRECISERR_Pos) /*!< SCB CFSR (BFSR): PRECISERR Mask */
+#define SCB_CFSR_IBUSERR_Pos (SCB_CFSR_BUSFAULTSR_Pos + 0U) /*!< SCB CFSR (BFSR): IBUSERR Position */
+#define SCB_CFSR_IBUSERR_Msk (1UL << SCB_CFSR_IBUSERR_Pos) /*!< SCB CFSR (BFSR): IBUSERR Mask */
+/* UsageFault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_DIVBYZERO_Pos (SCB_CFSR_USGFAULTSR_Pos + 9U) /*!< SCB CFSR (UFSR): DIVBYZERO Position */
+#define SCB_CFSR_DIVBYZERO_Msk (1UL << SCB_CFSR_DIVBYZERO_Pos) /*!< SCB CFSR (UFSR): DIVBYZERO Mask */
+#define SCB_CFSR_UNALIGNED_Pos (SCB_CFSR_USGFAULTSR_Pos + 8U) /*!< SCB CFSR (UFSR): UNALIGNED Position */
+#define SCB_CFSR_UNALIGNED_Msk (1UL << SCB_CFSR_UNALIGNED_Pos) /*!< SCB CFSR (UFSR): UNALIGNED Mask */
+#define SCB_CFSR_NOCP_Pos (SCB_CFSR_USGFAULTSR_Pos + 3U) /*!< SCB CFSR (UFSR): NOCP Position */
+#define SCB_CFSR_NOCP_Msk (1UL << SCB_CFSR_NOCP_Pos) /*!< SCB CFSR (UFSR): NOCP Mask */
+#define SCB_CFSR_INVPC_Pos (SCB_CFSR_USGFAULTSR_Pos + 2U) /*!< SCB CFSR (UFSR): INVPC Position */
+#define SCB_CFSR_INVPC_Msk (1UL << SCB_CFSR_INVPC_Pos) /*!< SCB CFSR (UFSR): INVPC Mask */
+#define SCB_CFSR_INVSTATE_Pos (SCB_CFSR_USGFAULTSR_Pos + 1U) /*!< SCB CFSR (UFSR): INVSTATE Position */
+#define SCB_CFSR_INVSTATE_Msk (1UL << SCB_CFSR_INVSTATE_Pos) /*!< SCB CFSR (UFSR): INVSTATE Mask */
+#define SCB_CFSR_UNDEFINSTR_Pos (SCB_CFSR_USGFAULTSR_Pos + 0U) /*!< SCB CFSR (UFSR): UNDEFINSTR Position */
+#define SCB_CFSR_UNDEFINSTR_Msk (1UL << SCB_CFSR_UNDEFINSTR_Pos) /*!< SCB CFSR (UFSR): UNDEFINSTR Mask */
/* SCB Hard Fault Status Register Definitions */
#define SCB_HFSR_DEBUGEVT_Pos 31U /*!< SCB HFSR: DEBUGEVT Position */
#define SCB_HFSR_DEBUGEVT_Msk (1UL << SCB_HFSR_DEBUGEVT_Pos) /*!< SCB HFSR: DEBUGEVT Mask */
@@ -831,7 +846,7 @@ typedef struct
/* ITM Trace Privilege Register Definitions */
#define ITM_TPR_PRIVMASK_Pos 0U /*!< ITM TPR: PRIVMASK Position */
-#define ITM_TPR_PRIVMASK_Msk (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/) /*!< ITM TPR: PRIVMASK Mask */
+#define ITM_TPR_PRIVMASK_Msk (0xFFFFFFFFUL /*<< ITM_TPR_PRIVMASK_Pos*/) /*!< ITM TPR: PRIVMASK Mask */
/* ITM Trace Control Register Definitions */
#define ITM_TCR_BUSY_Pos 23U /*!< ITM TCR: BUSY Position */
@@ -1045,7 +1060,7 @@ typedef struct
typedef struct
- __IOM uint32_t SSPSR; /*!< Offset: 0x000 (R/ ) Supported Parallel Port Size Register */
+ __IM uint32_t SSPSR; /*!< Offset: 0x000 (R/ ) Supported Parallel Port Size Register */
__IOM uint32_t CSPSR; /*!< Offset: 0x004 (R/W) Current Parallel Port Size Register */
uint32_t RESERVED0[2U];
__IOM uint32_t ACPR; /*!< Offset: 0x010 (R/W) Asynchronous Clock Prescaler Register */
@@ -1056,7 +1071,7 @@ typedef struct
__IOM uint32_t FFCR; /*!< Offset: 0x304 (R/W) Formatter and Flush Control Register */
__IM uint32_t FSCR; /*!< Offset: 0x308 (R/ ) Formatter Synchronization Counter Register */
uint32_t RESERVED3[759U];
- __IM uint32_t TRIGGER; /*!< Offset: 0xEE8 (R/ ) TRIGGER */
+ __IM uint32_t TRIGGER; /*!< Offset: 0xEE8 (R/ ) TRIGGER Register */
__IM uint32_t FIFO0; /*!< Offset: 0xEEC (R/ ) Integration ETM Data */
__IM uint32_t ITATBCTR2; /*!< Offset: 0xEF0 (R/ ) ITATBCTR2 */
uint32_t RESERVED4[1U];
@@ -1126,8 +1141,11 @@ typedef struct
#define TPI_FIFO0_ETM0_Msk (0xFFUL /*<< TPI_FIFO0_ETM0_Pos*/) /*!< TPI FIFO0: ETM0 Mask */
/* TPI ITATBCTR2 Register Definitions */
-#define TPI_ITATBCTR2_ATREADY_Pos 0U /*!< TPI ITATBCTR2: ATREADY Position */
-#define TPI_ITATBCTR2_ATREADY_Msk (0x1UL /*<< TPI_ITATBCTR2_ATREADY_Pos*/) /*!< TPI ITATBCTR2: ATREADY Mask */
+#define TPI_ITATBCTR2_ATREADY2_Pos 0U /*!< TPI ITATBCTR2: ATREADY2 Position */
+#define TPI_ITATBCTR2_ATREADY2_Msk (0x1UL /*<< TPI_ITATBCTR2_ATREADY2_Pos*/) /*!< TPI ITATBCTR2: ATREADY2 Mask */
+#define TPI_ITATBCTR2_ATREADY1_Pos 0U /*!< TPI ITATBCTR2: ATREADY1 Position */
+#define TPI_ITATBCTR2_ATREADY1_Msk (0x1UL /*<< TPI_ITATBCTR2_ATREADY1_Pos*/) /*!< TPI ITATBCTR2: ATREADY1 Mask */
/* TPI Integration ITM Data Register Definitions (FIFO1) */
#define TPI_FIFO1_ITM_ATVALID_Pos 29U /*!< TPI FIFO1: ITM_ATVALID Position */
@@ -1152,12 +1170,15 @@ typedef struct
#define TPI_FIFO1_ITM0_Msk (0xFFUL /*<< TPI_FIFO1_ITM0_Pos*/) /*!< TPI FIFO1: ITM0 Mask */
/* TPI ITATBCTR0 Register Definitions */
-#define TPI_ITATBCTR0_ATREADY_Pos 0U /*!< TPI ITATBCTR0: ATREADY Position */
-#define TPI_ITATBCTR0_ATREADY_Msk (0x1UL /*<< TPI_ITATBCTR0_ATREADY_Pos*/) /*!< TPI ITATBCTR0: ATREADY Mask */
+#define TPI_ITATBCTR0_ATREADY2_Pos 0U /*!< TPI ITATBCTR0: ATREADY2 Position */
+#define TPI_ITATBCTR0_ATREADY2_Msk (0x1UL /*<< TPI_ITATBCTR0_ATREADY2_Pos*/) /*!< TPI ITATBCTR0: ATREADY2 Mask */
+#define TPI_ITATBCTR0_ATREADY1_Pos 0U /*!< TPI ITATBCTR0: ATREADY1 Position */
+#define TPI_ITATBCTR0_ATREADY1_Msk (0x1UL /*<< TPI_ITATBCTR0_ATREADY1_Pos*/) /*!< TPI ITATBCTR0: ATREADY1 Mask */
/* TPI Integration Mode Control Register Definitions */
#define TPI_ITCTRL_Mode_Pos 0U /*!< TPI ITCTRL: Mode Position */
-#define TPI_ITCTRL_Mode_Msk (0x1UL /*<< TPI_ITCTRL_Mode_Pos*/) /*!< TPI ITCTRL: Mode Mask */
+#define TPI_ITCTRL_Mode_Msk (0x3UL /*<< TPI_ITCTRL_Mode_Pos*/) /*!< TPI ITCTRL: Mode Mask */
/* TPI DEVID Register Definitions */
#define TPI_DEVID_NRZVALID_Pos 11U /*!< TPI DEVID: NRZVALID Position */
@@ -1179,16 +1200,16 @@ typedef struct
#define TPI_DEVID_NrTraceInput_Msk (0x1FUL /*<< TPI_DEVID_NrTraceInput_Pos*/) /*!< TPI DEVID: NrTraceInput Mask */
/* TPI DEVTYPE Register Definitions */
-#define TPI_DEVTYPE_MajorType_Pos 4U /*!< TPI DEVTYPE: MajorType Position */
-#define TPI_DEVTYPE_MajorType_Msk (0xFUL << TPI_DEVTYPE_MajorType_Pos) /*!< TPI DEVTYPE: MajorType Mask */
-#define TPI_DEVTYPE_SubType_Pos 0U /*!< TPI DEVTYPE: SubType Position */
+#define TPI_DEVTYPE_SubType_Pos 4U /*!< TPI DEVTYPE: SubType Position */
#define TPI_DEVTYPE_SubType_Msk (0xFUL /*<< TPI_DEVTYPE_SubType_Pos*/) /*!< TPI DEVTYPE: SubType Mask */
+#define TPI_DEVTYPE_MajorType_Pos 0U /*!< TPI DEVTYPE: MajorType Position */
+#define TPI_DEVTYPE_MajorType_Msk (0xFUL << TPI_DEVTYPE_MajorType_Pos) /*!< TPI DEVTYPE: MajorType Mask */
/*@}*/ /* end of group CMSIS_TPI */
-#if (__MPU_PRESENT == 1U)
+#if defined (__MPU_PRESENT) && (__MPU_PRESENT == 1U)
\ingroup CMSIS_core_register
\defgroup CMSIS_MPU Memory Protection Unit (MPU)
@@ -1214,6 +1235,8 @@ typedef struct
__IOM uint32_t RASR_A3; /*!< Offset: 0x028 (R/W) MPU Alias 3 Region Attribute and Size Register */
} MPU_Type;
+#define MPU_TYPE_RALIASES 4U
/* MPU Type Register Definitions */
#define MPU_TYPE_IREGION_Pos 16U /*!< MPU TYPE: IREGION Position */
#define MPU_TYPE_IREGION_Msk (0xFFUL << MPU_TYPE_IREGION_Pos) /*!< MPU TYPE: IREGION Mask */
@@ -1280,10 +1303,9 @@ typedef struct
#define MPU_RASR_ENABLE_Msk (1UL /*<< MPU_RASR_ENABLE_Pos*/) /*!< MPU RASR: Region enable bit Disable Mask */
/*@} end of group CMSIS_MPU */
-#endif
+#endif /* defined (__MPU_PRESENT) && (__MPU_PRESENT == 1U) */
\defgroup CMSIS_FPU Floating Point Unit (FPU)
@@ -1388,7 +1410,6 @@ typedef struct
#define FPU_MVFR1_FtZ_mode_Msk (0xFUL /*<< FPU_MVFR1_FtZ_mode_Pos*/) /*!< MVFR1: FtZ mode bits Mask */
/*@} end of group CMSIS_FPU */
-#endif
@@ -1506,18 +1527,18 @@ typedef struct
\brief Mask and shift a bit field value for use in a register bit range.
\param[in] field Name of the register bit field.
- \param[in] value Value of the bit field.
+ \param[in] value Value of the bit field. This parameter is interpreted as an uint32_t type.
\return Masked and shifted value.
-#define _VAL2FLD(field, value) ((value << field ## _Pos) & field ## _Msk)
+#define _VAL2FLD(field, value) (((uint32_t)(value) << field ## _Pos) & field ## _Msk)
\brief Mask and shift a register value to extract a bit filed value.
- \param[in] value Value of register.
+ \param[in] value Value of register. This parameter is interpreted as an uint32_t type.
\return Masked and shifted bit field value.
-#define _FLD2VAL(field, value) ((value & field ## _Msk) >> field ## _Pos)
+#define _FLD2VAL(field, value) (((uint32_t)(value) & field ## _Msk) >> field ## _Pos)
/*@} end of group CMSIS_core_bitfield */
@@ -1529,7 +1550,7 @@ typedef struct
-/* Memory mapping of Cortex-M4 Hardware */
+/* Memory mapping of Core Hardware */
#define SCS_BASE (0xE000E000UL) /*!< System Control Space Base Address */
#define ITM_BASE (0xE0000000UL) /*!< ITM Base Address */
#define DWT_BASE (0xE0001000UL) /*!< DWT Base Address */
@@ -1548,15 +1569,13 @@ typedef struct
#define TPI ((TPI_Type *) TPI_BASE ) /*!< TPI configuration struct */
#define CoreDebug ((CoreDebug_Type *) CoreDebug_BASE) /*!< Core Debug configuration struct */
#define MPU_BASE (SCS_BASE + 0x0D90UL) /*!< Memory Protection Unit */
#define MPU ((MPU_Type *) MPU_BASE ) /*!< Memory Protection Unit */
#endif
- #define FPU_BASE (SCS_BASE + 0x0F30UL) /*!< Floating Point Unit */
- #define FPU ((FPU_Type *) FPU_BASE ) /*!< Floating Point Unit */
-#endif
+#define FPU_BASE (SCS_BASE + 0x0F30UL) /*!< Floating Point Unit */
+#define FPU ((FPU_Type *) FPU_BASE ) /*!< Floating Point Unit */
@@ -1584,6 +1603,48 @@ typedef struct
+#ifdef CMSIS_NVIC_VIRTUAL
+ #ifndef CMSIS_NVIC_VIRTUAL_HEADER_FILE
+ #define CMSIS_NVIC_VIRTUAL_HEADER_FILE "cmsis_nvic_virtual.h"
+ #endif
+ #include CMSIS_NVIC_VIRTUAL_HEADER_FILE
+#else
+ #define NVIC_SetPriorityGrouping __NVIC_SetPriorityGrouping
+ #define NVIC_GetPriorityGrouping __NVIC_GetPriorityGrouping
+ #define NVIC_EnableIRQ __NVIC_EnableIRQ
+ #define NVIC_GetEnableIRQ __NVIC_GetEnableIRQ
+ #define NVIC_DisableIRQ __NVIC_DisableIRQ
+ #define NVIC_GetPendingIRQ __NVIC_GetPendingIRQ
+ #define NVIC_SetPendingIRQ __NVIC_SetPendingIRQ
+ #define NVIC_ClearPendingIRQ __NVIC_ClearPendingIRQ
+ #define NVIC_GetActive __NVIC_GetActive
+ #define NVIC_SetPriority __NVIC_SetPriority
+ #define NVIC_GetPriority __NVIC_GetPriority
+ #define NVIC_SystemReset __NVIC_SystemReset
+#endif /* CMSIS_NVIC_VIRTUAL */
+#ifdef CMSIS_VECTAB_VIRTUAL
+ #ifndef CMSIS_VECTAB_VIRTUAL_HEADER_FILE
+ #define CMSIS_VECTAB_VIRTUAL_HEADER_FILE "cmsis_vectab_virtual.h"
+ #endif
+ #include CMSIS_VECTAB_VIRTUAL_HEADER_FILE
+#else
+ #define NVIC_SetVector __NVIC_SetVector
+ #define NVIC_GetVector __NVIC_GetVector
+#endif /* (CMSIS_VECTAB_VIRTUAL) */
+#define NVIC_USER_IRQ_OFFSET 16
+/* The following EXC_RETURN values are saved the LR on exception entry */
+#define EXC_RETURN_HANDLER (0xFFFFFFF1UL) /* return to Handler mode, uses MSP after return */
+#define EXC_RETURN_THREAD_MSP (0xFFFFFFF9UL) /* return to Thread mode, uses MSP after return */
+#define EXC_RETURN_THREAD_PSP (0xFFFFFFFDUL) /* return to Thread mode, uses PSP after return */
+#define EXC_RETURN_HANDLER_FPU (0xFFFFFFE1UL) /* return to Handler mode, uses MSP after return, restore floating-point state */
+#define EXC_RETURN_THREAD_MSP_FPU (0xFFFFFFE9UL) /* return to Thread mode, uses MSP after return, restore floating-point state */
+#define EXC_RETURN_THREAD_PSP_FPU (0xFFFFFFEDUL) /* return to Thread mode, uses PSP after return, restore floating-point state */
\brief Set Priority Grouping
\details Sets the priority grouping field using the required unlock sequence.
@@ -1593,7 +1654,7 @@ typedef struct
priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
\param [in] PriorityGroup Priority grouping field.
-__STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
+__STATIC_INLINE void __NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
uint32_t reg_value;
uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL); /* only values 0..7 are used */
@@ -1602,7 +1663,7 @@ __STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
reg_value &= ~((uint32_t)(SCB_AIRCR_VECTKEY_Msk | SCB_AIRCR_PRIGROUP_Msk)); /* clear bits to change */
reg_value = (reg_value |
((uint32_t)0x5FAUL << SCB_AIRCR_VECTKEY_Pos) |
- (PriorityGroupTmp << 8U) ); /* Insert write key and priorty group */
+ (PriorityGroupTmp << SCB_AIRCR_PRIGROUP_Pos) ); /* Insert write key and priority group */
SCB->AIRCR = reg_value;
@@ -1612,121 +1673,178 @@ __STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
\details Reads the priority grouping field from the NVIC Interrupt Controller.
\return Priority grouping field (SCB->AIRCR [10:8] PRIGROUP field).
-__STATIC_INLINE uint32_t NVIC_GetPriorityGrouping(void)
+__STATIC_INLINE uint32_t __NVIC_GetPriorityGrouping(void)
return ((uint32_t)((SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) >> SCB_AIRCR_PRIGROUP_Pos));
- \brief Enable External Interrupt
- \details Enables a device-specific interrupt in the NVIC interrupt controller.
- \param [in] IRQn External interrupt number. Value cannot be negative.
+ \brief Enable Interrupt
+ \details Enables a device specific interrupt in the NVIC interrupt controller.
+ \param [in] IRQn Device specific interrupt number.
+ \note IRQn must not be negative.
-__STATIC_INLINE void NVIC_EnableIRQ(IRQn_Type IRQn)
+__STATIC_INLINE void __NVIC_EnableIRQ(IRQn_Type IRQn)
- NVIC->ISER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+ if ((int32_t)(IRQn) >= 0)
+ NVIC->ISER[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
- \brief Disable External Interrupt
- \details Disables a device-specific interrupt in the NVIC interrupt controller.
+ \brief Get Interrupt Enable status
+ \details Returns a device specific interrupt enable status from the NVIC interrupt controller.
+ \return 0 Interrupt is not enabled.
+ \return 1 Interrupt is enabled.
-__STATIC_INLINE void NVIC_DisableIRQ(IRQn_Type IRQn)
+__STATIC_INLINE uint32_t __NVIC_GetEnableIRQ(IRQn_Type IRQn)
- NVIC->ICER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+ return((uint32_t)(((NVIC->ISER[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+ else
+ return(0U);
+ \brief Disable Interrupt
+ \details Disables a device specific interrupt in the NVIC interrupt controller.
+__STATIC_INLINE void __NVIC_DisableIRQ(IRQn_Type IRQn)
+ NVIC->ICER[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
+ __DSB();
+ __ISB();
\brief Get Pending Interrupt
- \details Reads the pending register in the NVIC and returns the pending bit for the specified interrupt.
- \param [in] IRQn Interrupt number.
+ \details Reads the NVIC pending register and returns the pending bit for the specified device specific interrupt.
\return 0 Interrupt status is not pending.
\return 1 Interrupt status is pending.
-__STATIC_INLINE uint32_t NVIC_GetPendingIRQ(IRQn_Type IRQn)
+__STATIC_INLINE uint32_t __NVIC_GetPendingIRQ(IRQn_Type IRQn)
- return((uint32_t)(((NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+ return((uint32_t)(((NVIC->ISPR[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+ else
+ return(0U);
\brief Set Pending Interrupt
- \details Sets the pending bit of an external interrupt.
- \param [in] IRQn Interrupt number. Value cannot be negative.
+ \details Sets the pending bit of a device specific interrupt in the NVIC pending register.
-__STATIC_INLINE void NVIC_SetPendingIRQ(IRQn_Type IRQn)
+__STATIC_INLINE void __NVIC_SetPendingIRQ(IRQn_Type IRQn)
- NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+ NVIC->ISPR[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
\brief Clear Pending Interrupt
- \details Clears the pending bit of an external interrupt.
+ \details Clears the pending bit of a device specific interrupt in the NVIC pending register.
-__STATIC_INLINE void NVIC_ClearPendingIRQ(IRQn_Type IRQn)
+__STATIC_INLINE void __NVIC_ClearPendingIRQ(IRQn_Type IRQn)
- NVIC->ICPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+ NVIC->ICPR[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
\brief Get Active Interrupt
- \details Reads the active register in NVIC and returns the active bit.
+ \details Reads the active register in the NVIC and returns the active bit for the device specific interrupt.
\return 0 Interrupt status is not active.
\return 1 Interrupt status is active.
-__STATIC_INLINE uint32_t NVIC_GetActive(IRQn_Type IRQn)
+__STATIC_INLINE uint32_t __NVIC_GetActive(IRQn_Type IRQn)
- return((uint32_t)(((NVIC->IABR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+ return((uint32_t)(((NVIC->IABR[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+ else
+ return(0U);
\brief Set Interrupt Priority
- \details Sets the priority of an interrupt.
- \note The priority cannot be set for every core interrupt.
+ \details Sets the priority of a device specific interrupt or a processor exception.
+ The interrupt number can be positive to specify a device specific interrupt,
+ or negative to specify a processor exception.
\param [in] priority Priority to set.
+ \note The priority cannot be set for every processor exception.
-__STATIC_INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
+__STATIC_INLINE void __NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
- if ((int32_t)(IRQn) < 0)
- SCB->SHP[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
+ NVIC->IP[((uint32_t)IRQn)] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
else
- NVIC->IP[((uint32_t)(int32_t)IRQn)] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
+ SCB->SHP[(((uint32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
\brief Get Interrupt Priority
- \details Reads the priority of an interrupt.
- The interrupt number can be positive to specify an external (device specific) interrupt,
- or negative to specify an internal (core) interrupt.
+ \details Reads the priority of a device specific interrupt or a processor exception.
\return Interrupt Priority.
Value is aligned automatically to the implemented priority bits of the microcontroller.
-__STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn)
+__STATIC_INLINE uint32_t __NVIC_GetPriority(IRQn_Type IRQn)
- return(((uint32_t)SCB->SHP[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
+ return(((uint32_t)NVIC->IP[((uint32_t)IRQn)] >> (8U - __NVIC_PRIO_BITS)));
else
- return(((uint32_t)NVIC->IP[((uint32_t)(int32_t)IRQn)] >> (8U - __NVIC_PRIO_BITS)));
+ return(((uint32_t)SCB->SHP[(((uint32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
@@ -1783,11 +1901,42 @@ __STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGr
+ \brief Set Interrupt Vector
+ \details Sets an interrupt vector in SRAM based interrupt vector table.
+ VTOR must been relocated to SRAM before.
+ \param [in] IRQn Interrupt number
+ \param [in] vector Address of interrupt handler function
+__STATIC_INLINE void __NVIC_SetVector(IRQn_Type IRQn, uint32_t vector)
+ uint32_t *vectors = (uint32_t *)SCB->VTOR;
+ vectors[(int32_t)IRQn + NVIC_USER_IRQ_OFFSET] = vector;
+ \brief Get Interrupt Vector
+ \details Reads an interrupt vector from interrupt vector table.
+ \param [in] IRQn Interrupt number.
+ \return Address of interrupt handler function
+__STATIC_INLINE uint32_t __NVIC_GetVector(IRQn_Type IRQn)
+ return vectors[(int32_t)IRQn + NVIC_USER_IRQ_OFFSET];
\brief System Reset
\details Initiates a system reset request to reset the MCU.
-__STATIC_INLINE void NVIC_SystemReset(void)
+__NO_RETURN __STATIC_INLINE void __NVIC_SystemReset(void)
__DSB(); /* Ensure all outstanding memory accesses included
buffered write are completed before reset */
@@ -1804,6 +1953,49 @@ __STATIC_INLINE void NVIC_SystemReset(void)
/*@} end of CMSIS_Core_NVICFunctions */
+/* ########################## MPU functions #################################### */
+#include "mpu_armv7.h"
+#endif
+/* ########################## FPU functions #################################### */
+ \ingroup CMSIS_Core_FunctionInterface
+ \defgroup CMSIS_Core_FpuFunctions FPU Functions
+ \brief Function that provides FPU type.
+ \brief get FPU type
+ \details returns the FPU type
+ \returns
+ - \b 0: No FPU
+ - \b 1: Single precision FPU
+ - \b 2: Double + Single precision FPU
+__STATIC_INLINE uint32_t SCB_GetFPUType(void)
+ uint32_t mvfr0;
+ mvfr0 = FPU->MVFR0;
+ if ((mvfr0 & (FPU_MVFR0_Single_precision_Msk | FPU_MVFR0_Double_precision_Msk)) == 0x020U)
+ return 1U; /* Single precision FPU */
+ else
+ return 0U; /* No FPU */
+/*@} end of CMSIS_Core_FpuFunctions */
/* ################################## SysTick function ############################################ */
@@ -1814,7 +2006,7 @@ __STATIC_INLINE void NVIC_SystemReset(void)
-#if (__Vendor_SysTickConfig == 0U)
+#if defined (__Vendor_SysTickConfig) && (__Vendor_SysTickConfig == 0U)
\brief System Tick Configuration
@@ -1857,8 +2049,8 @@ __STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
-extern volatile int32_t ITM_RxBuffer; /*!< External variable to receive characters. */
-#define ITM_RXBUFFER_EMPTY 0x5AA55AA5U /*!< Value identifying \ref ITM_RxBuffer is ready for next character. */
+extern volatile int32_t ITM_RxBuffer; /*!< External variable to receive characters. */
+#define ITM_RXBUFFER_EMPTY ((int32_t)0x5AA55AA5U) /*!< Value identifying \ref ITM_RxBuffer is ready for next character. */
diff --git a/bsps/arm/include/core_cm7.h b/bsps/arm/include/core_cm7.h
index 2ff340bab9..a14dc623b7 100644
--- a/bsps/arm/include/core_cm7.h
+++ b/bsps/arm/include/core_cm7.h
@@ -1,40 +1,30 @@
- * @file
+ * @file core_cm7.h
* @brief CMSIS Cortex-M7 Core Peripheral Access Layer Header File
- * @version V4.30
+ * @version V5.0.8
#endif
@@ -70,60 +60,22 @@
-/* CMSIS CM7 definitions */
-#define __CM7_CMSIS_VERSION_MAIN (0x04U) /*!< [31:16] CMSIS HAL main version */
-#define __CM7_CMSIS_VERSION_SUB (0x1EU) /*!< [15:0] CMSIS HAL sub version */
-#define __CM7_CMSIS_VERSION ((__CM7_CMSIS_VERSION_MAIN << 16U) | \
- __CM7_CMSIS_VERSION_SUB ) /*!< CMSIS HAL version number */
-#define __CORTEX_M (0x07U) /*!< Cortex-M Core */
+/* CMSIS CM7 definitions */
+#define __CM7_CMSIS_VERSION_MAIN (__CM_CMSIS_VERSION_MAIN) /*!< \deprecated [31:16] CMSIS HAL main version */
+#define __CM7_CMSIS_VERSION_SUB ( __CM_CMSIS_VERSION_SUB) /*!< \deprecated [15:0] CMSIS HAL sub version */
+#define __CM7_CMSIS_VERSION ((__CM7_CMSIS_VERSION_MAIN << 16U) | \
+ __CM7_CMSIS_VERSION_SUB ) /*!< \deprecated CMSIS HAL version number */
- #define __packed
-#else
-#endif
+#define __CORTEX_M (7U) /*!< Cortex-M Core */
#else
@@ -133,9 +85,9 @@
#endif
#else
@@ -147,7 +99,7 @@
#else
@@ -159,7 +111,7 @@
#else
@@ -169,9 +121,9 @@
#endif
#else
@@ -183,7 +135,7 @@
#else
@@ -195,7 +147,7 @@
#else
@@ -207,9 +159,8 @@
#endif
#ifdef __cplusplus
@@ -272,7 +223,6 @@
/* IO definitions (access restrictions to peripheral registers) */
\defgroup CMSIS_glob_defs CMSIS Global Defines
- \ingroup CMSIS
<strong>IO Type Qualifiers</strong> are used
\li to specify the access to peripheral variables.
@@ -308,7 +258,6 @@
\defgroup CMSIS_core_register Defines and Type Definitions
- \ingroup CMSIS
\brief Type definitions and defines for Cortex-M processor based devices.
@@ -384,11 +333,12 @@ typedef union
struct
@@ -414,8 +364,8 @@ typedef union
@@ -423,6 +373,9 @@ typedef union
@@ -531,7 +484,7 @@ typedef struct
uint32_t RESERVED4[15U];
__IM uint32_t MVFR0; /*!< Offset: 0x240 (R/ ) Media and VFP Feature Register 0 */
__IM uint32_t MVFR1; /*!< Offset: 0x244 (R/ ) Media and VFP Feature Register 1 */
- __IM uint32_t MVFR2; /*!< Offset: 0x248 (R/ ) Media and VFP Feature Register 1 */
+ __IM uint32_t MVFR2; /*!< Offset: 0x248 (R/ ) Media and VFP Feature Register 2 */
uint32_t RESERVED5[1U];
__OM uint32_t ICIALLU; /*!< Offset: 0x250 ( /W) I-Cache Invalidate All to PoU */
uint32_t RESERVED6[1U];
@@ -717,6 +670,66 @@ typedef struct
@@ -1035,7 +1048,7 @@ typedef struct
@@ -1252,7 +1265,7 @@ typedef struct
typedef struct
@@ -1263,7 +1276,7 @@ typedef struct
@@ -1333,8 +1346,11 @@ typedef struct
@@ -1359,12 +1375,15 @@ typedef struct
@@ -1386,16 +1405,16 @@ typedef struct
@@ -1421,6 +1440,8 @@ typedef struct
} MPU_Type;
@@ -1487,10 +1508,9 @@ typedef struct
-#endif
-#if (__FPU_PRESENT == 1U)
@@ -1598,7 +1618,6 @@ typedef struct
/* Media and FP Feature Register 2 Definitions */
-#endif
@@ -1716,18 +1735,18 @@ typedef struct
@@ -1739,7 +1758,7 @@ typedef struct
@@ -1758,15 +1777,13 @@ typedef struct
#endif
-#endif
@@ -1782,7 +1799,6 @@ typedef struct
\defgroup CMSIS_Core_FunctionInterface Functions and Instructions Reference
- \ingroup CMSIS
@@ -1795,6 +1811,48 @@ typedef struct
+ #endif
+#else
+ #endif
+#else
@@ -1804,7 +1862,7 @@ typedef struct
uint32_t reg_value;
@@ -1813,7 +1871,7 @@ __STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
@@ -1823,121 +1881,178 @@ __STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
+ else
+ return(0U);
+ __DSB();
+ __ISB();
+ else
+ return(0U);
+ else
+ return(0U);
- SCB->SHPR[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
else
+ SCB->SHPR[(((uint32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
- return(((uint32_t)SCB->SHPR[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
else
+ return(((uint32_t)SCB->SHPR[(((uint32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
@@ -1994,11 +2109,42 @@ __STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGr
\brief System Reset
@@ -2015,6 +2161,13 @@ __STATIC_INLINE void NVIC_SystemReset(void)
+#endif
@@ -2037,17 +2190,17 @@ __STATIC_INLINE uint32_t SCB_GetFPUType(void)
uint32_t mvfr0;
mvfr0 = SCB->MVFR0;
- if ((mvfr0 & 0x00000FF0UL) == 0x220UL)
+ if ((mvfr0 & (FPU_MVFR0_Single_precision_Msk | FPU_MVFR0_Double_precision_Msk)) == 0x220U)
- return 2UL; /* Double + Single precision FPU */
+ return 2U; /* Double + Single precision FPU */
- else if ((mvfr0 & 0x00000FF0UL) == 0x020UL)
+ else if ((mvfr0 & (FPU_MVFR0_Single_precision_Msk | FPU_MVFR0_Double_precision_Msk)) == 0x020U)
- return 1UL; /* Single precision FPU */
else
- return 0UL; /* No FPU */
@@ -2075,10 +2228,12 @@ __STATIC_INLINE uint32_t SCB_GetFPUType(void)
__STATIC_INLINE void SCB_EnableICache (void)
- #if (__ICACHE_PRESENT == 1U)
+ #if defined (__ICACHE_PRESENT) && (__ICACHE_PRESENT == 1U)
__DSB();
__ISB();
SCB->ICIALLU = 0UL; /* invalidate I-Cache */
+ __DSB();
+ __ISB();
SCB->CCR |= (uint32_t)SCB_CCR_IC_Msk; /* enable I-Cache */
__DSB();
__ISB();
@@ -2092,7 +2247,7 @@ __STATIC_INLINE void SCB_EnableICache (void)
__STATIC_INLINE void SCB_DisableICache (void)
__DSB();
__ISB();
SCB->CCR &= ~(uint32_t)SCB_CCR_IC_Msk; /* disable I-Cache */
@@ -2109,7 +2264,7 @@ __STATIC_INLINE void SCB_DisableICache (void)
__STATIC_INLINE void SCB_InvalidateICache (void)
__DSB();
__ISB();
SCB->ICIALLU = 0UL;
@@ -2125,12 +2280,12 @@ __STATIC_INLINE void SCB_InvalidateICache (void)
__STATIC_INLINE void SCB_EnableDCache (void)
- #if (__DCACHE_PRESENT == 1U)
+ #if defined (__DCACHE_PRESENT) && (__DCACHE_PRESENT == 1U)
uint32_t ccsidr;
uint32_t sets;
uint32_t ways;
- SCB->CSSELR = (0U << 1U) | 0U; /* Level 1 data cache */
+ SCB->CSSELR = 0U; /*(0U << 1U) | 0U;*/ /* Level 1 data cache */
__DSB();
ccsidr = SCB->CCSIDR;
@@ -2145,8 +2300,8 @@ __STATIC_INLINE void SCB_EnableDCache (void)
__schedule_barrier();
#endif
- } while (ways--);
- } while(sets--);
+ } while (ways-- != 0U);
+ } while(sets-- != 0U);
__DSB();
SCB->CCR |= (uint32_t)SCB_CCR_DC_Msk; /* enable D-Cache */
@@ -2163,17 +2318,18 @@ __STATIC_INLINE void SCB_EnableDCache (void)
__STATIC_INLINE void SCB_DisableDCache (void)
uint32_t ccsidr;
uint32_t sets;
uint32_t ways;
__DSB();
- ccsidr = SCB->CCSIDR;
SCB->CCR &= ~(uint32_t)SCB_CCR_DC_Msk; /* disable D-Cache */
+ __DSB();
+ ccsidr = SCB->CCSIDR;
/* clean & invalidate D-Cache */
sets = (uint32_t)(CCSIDR_SETS(ccsidr));
@@ -2185,8 +2341,8 @@ __STATIC_INLINE void SCB_DisableDCache (void)
#endif
- } while (ways--);
- } while(sets--);
__DSB();
__ISB();
@@ -2200,12 +2356,12 @@ __STATIC_INLINE void SCB_DisableDCache (void)
__STATIC_INLINE void SCB_InvalidateDCache (void)
uint32_t ccsidr;
uint32_t sets;
uint32_t ways;
__DSB();
@@ -2220,8 +2376,8 @@ __STATIC_INLINE void SCB_InvalidateDCache (void)
#endif
- } while (ways--);
- } while(sets--);
__DSB();
__ISB();
@@ -2235,13 +2391,13 @@ __STATIC_INLINE void SCB_InvalidateDCache (void)
__STATIC_INLINE void SCB_CleanDCache (void)
uint32_t ccsidr;
uint32_t sets;
uint32_t ways;
- __DSB();
+ __DSB();
@@ -2255,8 +2411,8 @@ __STATIC_INLINE void SCB_CleanDCache (void)
#endif
- } while (ways--);
- } while(sets--);
__DSB();
__ISB();
@@ -2270,12 +2426,12 @@ __STATIC_INLINE void SCB_CleanDCache (void)
__STATIC_INLINE void SCB_CleanInvalidateDCache (void)
uint32_t ccsidr;
uint32_t sets;
uint32_t ways;
__DSB();
@@ -2290,8 +2446,8 @@ __STATIC_INLINE void SCB_CleanInvalidateDCache (void)
#endif
- } while (ways--);
- } while(sets--);
__DSB();
__ISB();
@@ -2307,17 +2463,17 @@ __STATIC_INLINE void SCB_CleanInvalidateDCache (void)
__STATIC_INLINE void SCB_InvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
int32_t op_size = dsize;
uint32_t op_addr = (uint32_t)addr;
- int32_t linesize = 32U; /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
+ int32_t linesize = 32; /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
__DSB();
while (op_size > 0) {
SCB->DCIMVAC = op_addr;
- op_addr += linesize;
- op_size -= linesize;
+ op_addr += (uint32_t)linesize;
+ op_size -= linesize;
__DSB();
@@ -2334,17 +2490,17 @@ __STATIC_INLINE void SCB_InvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize
__STATIC_INLINE void SCB_CleanDCache_by_Addr (uint32_t *addr, int32_t dsize)
- #if (__DCACHE_PRESENT == 1)
uint32_t op_addr = (uint32_t) addr;
__DSB();
SCB->DCCMVAC = op_addr;
__DSB();
@@ -2361,17 +2517,17 @@ __STATIC_INLINE void SCB_CleanDCache_by_Addr (uint32_t *addr, int32_t dsize)
__STATIC_INLINE void SCB_CleanInvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
__DSB();
SCB->DCCIMVAC = op_addr;
__DSB();
@@ -2392,7 +2548,7 @@ __STATIC_INLINE void SCB_CleanInvalidateDCache_by_Addr (uint32_t *addr, int32_t
@@ -2435,8 +2591,8 @@ __STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
diff --git a/bsps/arm/include/mpu_armv7.h b/bsps/arm/include/mpu_armv7.h
index 0000000000..01422033d0
--- /dev/null
+++ b/bsps/arm/include/mpu_armv7.h
@@ -0,0 +1,270 @@
+ * @file mpu_armv7.h
+ * @brief CMSIS MPU API for Armv7-M MPU
+ * @version V5.0.4
+ * @date 10. January 2018
+ * Copyright (c) 2017-2018 Arm Limited. All rights reserved.
+#endif
+#ifndef ARM_MPU_ARMV7_H
+#define ARM_MPU_ARMV7_H
+#define ARM_MPU_REGION_SIZE_32B ((uint8_t)0x04U) ///!< MPU Region Size 32 Bytes
+#define ARM_MPU_REGION_SIZE_64B ((uint8_t)0x05U) ///!< MPU Region Size 64 Bytes
+#define ARM_MPU_REGION_SIZE_128B ((uint8_t)0x06U) ///!< MPU Region Size 128 Bytes
+#define ARM_MPU_REGION_SIZE_256B ((uint8_t)0x07U) ///!< MPU Region Size 256 Bytes
+#define ARM_MPU_REGION_SIZE_512B ((uint8_t)0x08U) ///!< MPU Region Size 512 Bytes
+#define ARM_MPU_REGION_SIZE_1KB ((uint8_t)0x09U) ///!< MPU Region Size 1 KByte
+#define ARM_MPU_REGION_SIZE_2KB ((uint8_t)0x0AU) ///!< MPU Region Size 2 KBytes
+#define ARM_MPU_REGION_SIZE_4KB ((uint8_t)0x0BU) ///!< MPU Region Size 4 KBytes
+#define ARM_MPU_REGION_SIZE_8KB ((uint8_t)0x0CU) ///!< MPU Region Size 8 KBytes
+#define ARM_MPU_REGION_SIZE_16KB ((uint8_t)0x0DU) ///!< MPU Region Size 16 KBytes
+#define ARM_MPU_REGION_SIZE_32KB ((uint8_t)0x0EU) ///!< MPU Region Size 32 KBytes
+#define ARM_MPU_REGION_SIZE_64KB ((uint8_t)0x0FU) ///!< MPU Region Size 64 KBytes
+#define ARM_MPU_REGION_SIZE_128KB ((uint8_t)0x10U) ///!< MPU Region Size 128 KBytes
+#define ARM_MPU_REGION_SIZE_256KB ((uint8_t)0x11U) ///!< MPU Region Size 256 KBytes
+#define ARM_MPU_REGION_SIZE_512KB ((uint8_t)0x12U) ///!< MPU Region Size 512 KBytes
+#define ARM_MPU_REGION_SIZE_1MB ((uint8_t)0x13U) ///!< MPU Region Size 1 MByte
+#define ARM_MPU_REGION_SIZE_2MB ((uint8_t)0x14U) ///!< MPU Region Size 2 MBytes
+#define ARM_MPU_REGION_SIZE_4MB ((uint8_t)0x15U) ///!< MPU Region Size 4 MBytes
+#define ARM_MPU_REGION_SIZE_8MB ((uint8_t)0x16U) ///!< MPU Region Size 8 MBytes
+#define ARM_MPU_REGION_SIZE_16MB ((uint8_t)0x17U) ///!< MPU Region Size 16 MBytes
+#define ARM_MPU_REGION_SIZE_32MB ((uint8_t)0x18U) ///!< MPU Region Size 32 MBytes
+#define ARM_MPU_REGION_SIZE_64MB ((uint8_t)0x19U) ///!< MPU Region Size 64 MBytes
+#define ARM_MPU_REGION_SIZE_128MB ((uint8_t)0x1AU) ///!< MPU Region Size 128 MBytes
+#define ARM_MPU_REGION_SIZE_256MB ((uint8_t)0x1BU) ///!< MPU Region Size 256 MBytes
+#define ARM_MPU_REGION_SIZE_512MB ((uint8_t)0x1CU) ///!< MPU Region Size 512 MBytes
+#define ARM_MPU_REGION_SIZE_1GB ((uint8_t)0x1DU) ///!< MPU Region Size 1 GByte
+#define ARM_MPU_REGION_SIZE_2GB ((uint8_t)0x1EU) ///!< MPU Region Size 2 GBytes
+#define ARM_MPU_REGION_SIZE_4GB ((uint8_t)0x1FU) ///!< MPU Region Size 4 GBytes
+#define ARM_MPU_AP_NONE 0U ///!< MPU Access Permission no access
+#define ARM_MPU_AP_PRIV 1U ///!< MPU Access Permission privileged access only
+#define ARM_MPU_AP_URO 2U ///!< MPU Access Permission unprivileged access read-only
+#define ARM_MPU_AP_FULL 3U ///!< MPU Access Permission full access
+#define ARM_MPU_AP_PRO 5U ///!< MPU Access Permission privileged access read-only
+#define ARM_MPU_AP_RO 6U ///!< MPU Access Permission read-only access
+/** MPU Region Base Address Register Value
+* \param Region The region to be configured, number 0 to 15.
+* \param BaseAddress The base address for the region.
+#define ARM_MPU_RBAR(Region, BaseAddress) \
+ (((BaseAddress) & MPU_RBAR_ADDR_Msk) | \
+ ((Region) & MPU_RBAR_REGION_Msk) | \
+ (MPU_RBAR_VALID_Msk))
+* MPU Memory Access Attributes
+* \param TypeExtField Type extension field, allows you to configure memory access type, for example strongly ordered, peripheral.
+* \param IsShareable Region is shareable between multiple bus masters.
+* \param IsCacheable Region is cacheable, i.e. its value may be kept in cache.
+* \param IsBufferable Region is bufferable, i.e. using write-back caching. Cacheable but non-bufferable regions use write-through policy.
+#define ARM_MPU_ACCESS_(TypeExtField, IsShareable, IsCacheable, IsBufferable) \
+ ((((TypeExtField ) << MPU_RASR_TEX_Pos) & MPU_RASR_TEX_Msk) | \
+ (((IsShareable ) << MPU_RASR_S_Pos) & MPU_RASR_S_Msk) | \
+ (((IsCacheable ) << MPU_RASR_C_Pos) & MPU_RASR_C_Msk) | \
+ (((IsBufferable ) << MPU_RASR_B_Pos) & MPU_RASR_B_Msk))
+* MPU Region Attribute and Size Register Value
+* \param DisableExec Instruction access disable bit, 1= disable instruction fetches.
+* \param AccessPermission Data access permissions, allows you to configure read/write access for User and Privileged mode.
+* \param AccessAttributes Memory access attribution, see \ref ARM_MPU_ACCESS_.
+* \param SubRegionDisable Sub-region disable field.
+* \param Size Region size of the region to be configured, for example 4K, 8K.
+#define ARM_MPU_RASR_EX(DisableExec, AccessPermission, AccessAttributes, SubRegionDisable, Size) \
+ ((((DisableExec ) << MPU_RASR_XN_Pos) & MPU_RASR_XN_Msk) | \
+ (((AccessPermission) << MPU_RASR_AP_Pos) & MPU_RASR_AP_Msk) | \
+ (((AccessAttributes) ) & (MPU_RASR_TEX_Msk | MPU_RASR_S_Msk | MPU_RASR_C_Msk | MPU_RASR_B_Msk)))
+#define ARM_MPU_RASR(DisableExec, AccessPermission, TypeExtField, IsShareable, IsCacheable, IsBufferable, SubRegionDisable, Size) \
+ ARM_MPU_RASR_EX(DisableExec, AccessPermission, ARM_MPU_ACCESS_(TypeExtField, IsShareable, IsCacheable, IsBufferable), SubRegionDisable, Size)
+* MPU Memory Access Attribute for strongly ordered memory.
+* - TEX: 000b
+* - Shareable
+* - Non-cacheable
+* - Non-bufferable
+#define ARM_MPU_ACCESS_ORDERED ARM_MPU_ACCESS_(0U, 1U, 0U, 0U)
+* MPU Memory Access Attribute for device memory.
+* - TEX: 000b (if non-shareable) or 010b (if shareable)
+* - Shareable or non-shareable
+* - Non-cacheable
+* - Bufferable (if shareable) or non-bufferable (if non-shareable)
+* \param IsShareable Configures the device memory as shareable or non-shareable.
+#define ARM_MPU_ACCESS_DEVICE(IsShareable) ((IsShareable) ? ARM_MPU_ACCESS_(0U, 1U, 0U, 1U) : ARM_MPU_ACCESS_(2U, 0U, 0U, 0U))
+* MPU Memory Access Attribute for normal memory.
+* - TEX: 1BBb (reflecting outer cacheability rules)
+* - Cacheable or non-cacheable (reflecting inner cacheability rules)
+* - Bufferable or non-bufferable (reflecting inner cacheability rules)
+* \param OuterCp Configures the outer cache policy.
+* \param InnerCp Configures the inner cache policy.
+* \param IsShareable Configures the memory as shareable or non-shareable.
+#define ARM_MPU_ACCESS_NORMAL(OuterCp, InnerCp, IsShareable) ARM_MPU_ACCESS_((4U | (OuterCp)), IsShareable, ((InnerCp) & 2U), ((InnerCp) & 1U))
+* MPU Memory Access Attribute non-cacheable policy.
+#define ARM_MPU_CACHEP_NOCACHE 0U
+* MPU Memory Access Attribute write-back, write and read allocate policy.
+#define ARM_MPU_CACHEP_WB_WRA 1U
+* MPU Memory Access Attribute write-through, no write allocate policy.
+#define ARM_MPU_CACHEP_WT_NWA 2U
+* MPU Memory Access Attribute write-back, no write allocate policy.
+#define ARM_MPU_CACHEP_WB_NWA 3U
+* Struct for a single MPU Region
+typedef struct {
+ uint32_t RBAR; //!< The region base address register value (RBAR)
+ uint32_t RASR; //!< The region attribute and size register value (RASR) \ref MPU_RASR
+} ARM_MPU_Region_t;
+/** Enable the MPU.
+* \param MPU_Control Default access permissions for unconfigured regions.
+__STATIC_INLINE void ARM_MPU_Enable(uint32_t MPU_Control)
+ __DSB();
+ __ISB();
+ MPU->CTRL = MPU_Control | MPU_CTRL_ENABLE_Msk;
+#ifdef SCB_SHCSR_MEMFAULTENA_Msk
+ SCB->SHCSR |= SCB_SHCSR_MEMFAULTENA_Msk;
+#endif
+/** Disable the MPU.
+__STATIC_INLINE void ARM_MPU_Disable(void)
+ __DSB();
+ __ISB();
+ SCB->SHCSR &= ~SCB_SHCSR_MEMFAULTENA_Msk;
+#endif
+ MPU->CTRL &= ~MPU_CTRL_ENABLE_Msk;
+/** Clear and disable the given MPU region.
+* \param rnr Region number to be cleared.
+__STATIC_INLINE void ARM_MPU_ClrRegion(uint32_t rnr)
+ MPU->RNR = rnr;
+ MPU->RASR = 0U;
+/** Configure an MPU region.
+* \param rbar Value for RBAR register.
+* \param rsar Value for RSAR register.
+__STATIC_INLINE void ARM_MPU_SetRegion(uint32_t rbar, uint32_t rasr)
+ MPU->RBAR = rbar;
+ MPU->RASR = rasr;
+/** Configure the given MPU region.
+* \param rnr Region number to be configured.
+__STATIC_INLINE void ARM_MPU_SetRegionEx(uint32_t rnr, uint32_t rbar, uint32_t rasr)
+ MPU->RNR = rnr;
+ MPU->RBAR = rbar;
+ MPU->RASR = rasr;
+/** Memcopy with strictly ordered memory access, e.g. for register targets.
+* \param dst Destination data is copied to.
+* \param src Source data is copied from.
+* \param len Amount of data words to be copied.
+__STATIC_INLINE void orderedCpy(volatile uint32_t* dst, const uint32_t* __RESTRICT src, uint32_t len)
+ uint32_t i;
+ for (i = 0U; i < len; ++i)
+ dst[i] = src[i];
+/** Load the given number of MPU regions from a table.
+* \param table Pointer to the MPU configuration table.
+* \param cnt Amount of regions to be configured.
+__STATIC_INLINE void ARM_MPU_Load(ARM_MPU_Region_t const* table, uint32_t cnt)
+ const uint32_t rowWordSize = sizeof(ARM_MPU_Region_t)/4U;
+ while (cnt > MPU_TYPE_RALIASES) {
+ orderedCpy(&(MPU->RBAR), &(table->RBAR), MPU_TYPE_RALIASES*rowWordSize);
+ table += MPU_TYPE_RALIASES;
+ cnt -= MPU_TYPE_RALIASES;
+ orderedCpy(&(MPU->RBAR), &(table->RBAR), cnt*rowWordSize);
+#endif
2.37.1
