[rtems-tools 5 PATCH] Python 3.8 warning about "is" vs "==" in comparisons of literals
Ryan Long
ryan.long at oarcorp.com
Thu Aug 11 19:25:47 UTC 2022
From: Konrad Schwarz <konrad.schwarz at siemens.com>
Signed-off-by: Konrad Schwarz <konrad.schwarz at siemens.com>
Closes #4692
rtemstoolkit/config.py | 2 +-
rtemstoolkit/macros.py | 58 +++++++++++++++++++++++++-------------------------
2 files changed, 30 insertions(+), 30 deletions(-)
diff --git a/rtemstoolkit/config.py b/rtemstoolkit/config.py
index be100f2..8fd4a32 100644
--- a/rtemstoolkit/config.py
+++ b/rtemstoolkit/config.py
@@ -127,7 +127,7 @@ class file(object):
self.opts.set_dry_run()
def _label(self, name):
- if name.startswith('%{') and name[-1] is '}':
+ if name.startswith('%{') and name[-1] == '}':
return name
return '%{' + name.lower() + '}'
diff --git a/rtemstoolkit/macros.py b/rtemstoolkit/macros.py
index d8012e1..136f52d 100644
--- a/rtemstoolkit/macros.py
+++ b/rtemstoolkit/macros.py
@@ -260,7 +260,7 @@ class macros:
return [rm[7:] for rm in self.read_maps]
def key_filter(self, key):
- if key.startswith('%{') and key[-1] is '}':
+ if key.startswith('%{') and key[-1] == '}':
key = key[2:-1]
return key.lower()
@@ -295,29 +295,29 @@ class macros:
print(']]]]]]]] c:%s(%d) s:%s t:"%s" m:%r M:%s' % \
(c, ord(c), state, token, macro, map))
l_remaining = l_remaining[1:]
- if c is '#' and not state.startswith('value'):
+ if c == '#' and not state.startswith('value'):
break
if c == '\n' or c == '\r':
- if not (state is 'key' and len(token) == 0) and \
+ if not (state == 'key' and len(token) == 0) and \
not state.startswith('value-multiline'):
self.macros = orig_macros
raise error.general('malformed macro line:%d: %s' % (lc, l))
- if state is 'key':
+ if state == 'key':
if c not in string.whitespace:
- if c is '[':
+ if c == '[':
state = 'map'
- elif c is '%':
+ elif c == '%':
state = 'directive'
- elif c is ':':
+ elif c == ':':
macro += [token]
token = ''
state = 'attribs'
- elif c is '#':
+ elif c == '#':
break
else:
token += c
- elif state is 'map':
- if c is ']':
+ elif state == 'map':
+ if c == ']':
if token not in self.macros:
self.macros[token] = {}
map = token
@@ -328,7 +328,7 @@ class macros:
else:
raise error.general('invalid macro map:%d: %s' % (lc, l))
- elif state is 'directive':
+ elif state == 'directive':
if c in string.whitespace:
if token == 'include':
self.load(_clean(l_remaining))
@@ -340,7 +340,7 @@ class macros:
else:
raise error.general('invalid macro directive:%d: %s' % (lc, l))
- elif state is 'include':
+ elif state == 'include':
if c is string.whitespace:
state = 'include'
@@ -349,49 +349,49 @@ class macros:
else:
- elif state is 'attribs':
+ elif state == 'attribs':
- if c is ',':
+ if c == ',':
macro += [token]
token = ''
if len(macro) == 3:
state = 'value-start'
else:
token += c
- elif state is 'value-start':
- if c is "'":
+ elif state == 'value-start':
+ if c == "'":
state = 'value-line-start'
- elif state is 'value-line-start':
- if c is "'":
+ elif state == 'value-line-start':
+ if c == "'":
state = 'value-multiline-start'
else:
state = 'value-line'
token += c
- elif state is 'value-multiline-start':
- if c is "'":
+ elif state == 'value-multiline-start':
+ if c == "'":
state = 'value-multiline'
else:
macro += [token]
state = 'macro'
- elif state is 'value-line':
- if c is "'":
+ elif state == 'value-line':
+ if c == "'":
macro += [token]
state = 'macro'
else:
token += c
- elif state is 'value-multiline':
- if c is "'":
+ elif state == 'value-multiline':
+ if c == "'":
state = 'value-multiline-end'
else:
token += c
- elif state is 'value-multiline-end':
- if c is "'":
+ elif state == 'value-multiline-end':
+ if c == "'":
state = 'value-multiline-end-end'
else:
token += "'" + c
- elif state is 'value-multiline-end-end':
- if c is "'":
+ elif state == 'value-multiline-end-end':
+ if c == "'":
macro += [token]
state = 'macro'
else:
@@ -400,7 +400,7 @@ class macros:
else:
raise error.internal('bad state: %s' % (state))
- if state is 'macro':
+ if state == 'macro':
self.macros[map][macro[0].lower()] = (macro[1], macro[2], macro[3])
macro = []
token = ''
2.11.0
