[rtems-tools PATCH] rtemstoolkit: Fix conditions using "is" with literals
Chris Johns
chrisj at rtems.org
Fri Aug 12 00:11:11 UTC 2022
OK and thanks
On 12/8/2022 5:26 am, Ryan Long wrote:
> Fix warnings that come from python 3.8 about using the "is" operator with
> string literals.
> Closes #4700
> rtemstoolkit/config.py | 2 +-
> rtemstoolkit/macros.py | 58 +++++++++++++++++++++++++-------------------------
> 2 files changed, 30 insertions(+), 30 deletions(-)
> diff --git a/rtemstoolkit/config.py b/rtemstoolkit/config.py
> index be100f2..8fd4a32 100644
> --- a/rtemstoolkit/config.py
> +++ b/rtemstoolkit/config.py
> @@ -127,7 +127,7 @@ class file(object):
> self.opts.set_dry_run()
> def _label(self, name):
> - if name.startswith('%{') and name[-1] is '}':
> + if name.startswith('%{') and name[-1] == '}':
> return name
> return '%{' + name.lower() + '}'
> diff --git a/rtemstoolkit/macros.py b/rtemstoolkit/macros.py
> index d8012e1..136f52d 100644
> --- a/rtemstoolkit/macros.py
> +++ b/rtemstoolkit/macros.py
> @@ -260,7 +260,7 @@ class macros:
> return [rm[7:] for rm in self.read_maps]
> def key_filter(self, key):
> - if key.startswith('%{') and key[-1] is '}':
> + if key.startswith('%{') and key[-1] == '}':
> key = key[2:-1]
> return key.lower()
> @@ -295,29 +295,29 @@ class macros:
> print(']]]]]]]] c:%s(%d) s:%s t:"%s" m:%r M:%s' % \
> (c, ord(c), state, token, macro, map))
> l_remaining = l_remaining[1:]
> - if c is '#' and not state.startswith('value'):
> + if c == '#' and not state.startswith('value'):
> break
> if c == '\n' or c == '\r':
> - if not (state is 'key' and len(token) == 0) and \
> + if not (state == 'key' and len(token) == 0) and \
> not state.startswith('value-multiline'):
> self.macros = orig_macros
> raise error.general('malformed macro line:%d: %s' % (lc, l))
> - if state is 'key':
> + if state == 'key':
> if c not in string.whitespace:
> - if c is '[':
> + if c == '[':
> state = 'map'
> - elif c is '%':
> + elif c == '%':
> state = 'directive'
> - elif c is ':':
> + elif c == ':':
> macro += [token]
> token = ''
> state = 'attribs'
> - elif c is '#':
> + elif c == '#':
> break
> else:
> token += c
> - elif state is 'map':
> - if c is ']':
> + elif state == 'map':
> + if c == ']':
> if token not in self.macros:
> self.macros[token] = {}
> map = token
> @@ -328,7 +328,7 @@ class macros:
> else:
> raise error.general('invalid macro map:%d: %s' % (lc, l))
> - elif state is 'directive':
> + elif state == 'directive':
> if c in string.whitespace:
> if token == 'include':
> self.load(_clean(l_remaining))
> @@ -340,7 +340,7 @@ class macros:
> else:
> raise error.general('invalid macro directive:%d: %s' % (lc, l))
> - elif state is 'include':
> + elif state == 'include':
> if c is string.whitespace:
> state = 'include'
> @@ -349,49 +349,49 @@ class macros:
> else:
> - elif state is 'attribs':
> + elif state == 'attribs':
> - if c is ',':
> + if c == ',':
> macro += [token]
> token = ''
> if len(macro) == 3:
> state = 'value-start'
> else:
> token += c
> - elif state is 'value-start':
> - if c is "'":
> + elif state == 'value-start':
> + if c == "'":
> state = 'value-line-start'
> - elif state is 'value-line-start':
> - if c is "'":
> + elif state == 'value-line-start':
> + if c == "'":
> state = 'value-multiline-start'
> else:
> state = 'value-line'
> token += c
> - elif state is 'value-multiline-start':
> - if c is "'":
> + elif state == 'value-multiline-start':
> + if c == "'":
> state = 'value-multiline'
> else:
> macro += [token]
> state = 'macro'
> - elif state is 'value-line':
> - if c is "'":
> + elif state == 'value-line':
> + if c == "'":
> macro += [token]
> state = 'macro'
> else:
> token += c
> - elif state is 'value-multiline':
> - if c is "'":
> + elif state == 'value-multiline':
> + if c == "'":
> state = 'value-multiline-end'
> else:
> token += c
> - elif state is 'value-multiline-end':
> - if c is "'":
> + elif state == 'value-multiline-end':
> + if c == "'":
> state = 'value-multiline-end-end'
> else:
> token += "'" + c
> - elif state is 'value-multiline-end-end':
> - if c is "'":
> + elif state == 'value-multiline-end-end':
> + if c == "'":
> macro += [token]
> state = 'macro'
> else:
> @@ -400,7 +400,7 @@ class macros:
> else:
> raise error.internal('bad state: %s' % (state))
> - if state is 'macro':
> + if state == 'macro':
> self.macros[map][macro[0].lower()] = (macro[1], macro[2], macro[3])
> macro = []
> token = ''
