[PATCH v4] cpukit/dev/can: Added CAN support
Prashanth S fishesprashanth at gmail.com
Sun Aug 14 08:26:16 UTC 2022
 cpukit/dev/can/can.c                     | 521 +++++++++++++++++++++++
 cpukit/include/dev/can/can-msg.h         | 105 +++++
 cpukit/include/dev/can/can-queue.h       | 219 ++++++++++
 cpukit/include/dev/can/can.h             | 258 +++++++++++
 spec/build/cpukit/librtemscpu.yml        |   6 +
 spec/build/testsuites/libtests/can01.yml |  19 +
 spec/build/testsuites/libtests/grp.yml   |   2 +
 testsuites/libtests/can01/init.c         | 257 +++++++++++
 8 files changed, 1387 insertions(+)
 create mode 100644 cpukit/dev/can/can.c
 create mode 100644 cpukit/include/dev/can/can-msg.h
 create mode 100644 cpukit/include/dev/can/can-queue.h
 create mode 100644 cpukit/include/dev/can/can.h
 create mode 100644 spec/build/testsuites/libtests/can01.yml
 create mode 100644 testsuites/libtests/can01/init.c
diff --git a/cpukit/dev/can/can.c b/cpukit/dev/can/can.c
new file mode 100644
index 0000000000..02377a9098
--- /dev/null
+++ b/cpukit/dev/can/can.c
@@ -0,0 +1,521 @@
+ * @file
+ * @ingroup CANBus
+ * @brief Controller Area Network (CAN) Bus Implementation
+ * Copyright (C) 2022 Prashanth S (fishesprashanth at gmail.com)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/imfs.h>
+#include <rtems/thread.h>
+#include <dev/can/can-queue.h>
+#include <dev/can/can.h>
+#include <string.h>
+#include <stdlib.h>
+#include <fcntl.h>
+#define can_interrupt_lock_acquire(bus) \
+                      do {              \
+                           CAN_DEBUG_LOCK("acquiring lock %s:%d\n", __FILE__, __LINE__); \
+                           real_can_interrupt_lock_acquire(bus);                              \
+                         } while (0);
+#define can_interrupt_lock_release(bus) \
+                      do {              \
+                           CAN_DEBUG_LOCK("releasing lock %s:%d\n", __FILE__, __LINE__); \
+                           real_can_interrupt_lock_release(bus);                              \
+                         } while (0);
+static ssize_t
+can_bus_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode);
+static ssize_t
+can_bus_read(rtems_libio_t *iop, void *buffer, size_t count);
+static ssize_t
+can_bus_write(rtems_libio_t *iop, const void *buffer, size_t count);
+static ssize_t
+can_bus_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer);
+static int can_xmit(struct can_bus *bus);
+static int can_create_sem(struct can_bus *);
+static int try_sem(struct can_bus *);
+static int take_sem(struct can_bus *);
+static int give_sem(struct can_bus *);
+/* sem_count this is for debug purpose, for debugging
+the take_sem and give_sem
+static int sem_count = 0;
+static void can_bus_obtain(can_bus *bus)
+  printf("can_bus_obtain Entry\n");
+  rtems_mutex_lock(&bus->mutex);
+  printf("can_bus_obtain Exit\n");
+static void can_bus_release(can_bus *bus)
+  printf("can_bus_release Entry\n");
+  rtems_mutex_unlock(&bus->mutex);
+  printf("can_bus_release Exit\n");
+static void can_bus_destroy_mutex(struct can_bus *bus)
+  rtems_mutex_destroy(&bus->mutex);
+static int can_create_sem(struct can_bus *bus)
+  int ret = 0;
+  ret = rtems_semaphore_create(rtems_build_name('c', 'a', 'n', bus->index),
+      CAN_TX_BUF_COUNT, RTEMS_FIFO | RTEMS_COUNTING_SEMAPHORE | RTEMS_LOCAL,
+      0, &bus->tx_fifo_sem_id);
+  if (ret != 0) {
+    printf("can_create_sem: rtems_semaphore_create failed %d\n", ret);
+  return ret;
+static void can_free_tx_semaphore(struct can_bus *bus)
+  rtems_semaphore_delete(bus->tx_fifo_sem_id);
+static void real_can_interrupt_lock_acquire(struct can_bus *bus)
+  bus->can_dev_ops->dev_int(bus->priv, false);
+  can_bus_obtain(bus);
+static void real_can_interrupt_lock_release(struct can_bus *bus)
+  can_bus_release(bus);
+  bus->can_dev_ops->dev_int(bus->priv, true);
+static int take_sem(struct can_bus *bus)
+  int ret = rtems_semaphore_obtain(bus->tx_fifo_sem_id, RTEMS_WAIT,
+                                RTEMS_NO_TIMEOUT);
+  if (ret == RTEMS_SUCCESSFUL) {
+    sem_count++;
+    CAN_DEBUG_LOCK("take_sem: Semaphore count = %d\n", sem_count);
+    if (sem_count > CAN_TX_BUF_COUNT) {
+      printf("take_sem error: sem_count is misleading\n");
+      while (1);
+  return ret;
+static int give_sem(struct can_bus *bus)
+  int ret = rtems_semaphore_release(bus->tx_fifo_sem_id);
+    sem_count--;
+    CAN_DEBUG_LOCK("give_sem: Semaphore count = %d\n", sem_count);
+    if (sem_count < 0) {
+      printf("give_sem error: sem_count is misleading\n");
+      while (1);
+  return ret;
+static int try_sem(struct can_bus *bus)
+  int ret = rtems_semaphore_obtain(bus->tx_fifo_sem_id, RTEMS_NO_WAIT,
+    sem_count++;
+    CAN_DEBUG_LOCK("try_sem: Semaphore count = %d\n", sem_count);
+      while (1);
+  return ret;
+static ssize_t
+  CAN_DEBUG("can_bus_open\n");
+  can_bus *bus = IMFS_generic_get_context_by_iop(iop);
+  if (bus == NULL) {
+    return -RTEMS_NOT_DEFINED;
+  return 0;
+int can_receive(struct can_bus *bus, struct can_msg *msg)
+  int32_t ret = 0;
+  uint32_t count = 0;
+  ret = rtems_message_queue_broadcast(bus->rx_queue_id, msg, CAN_MSGLEN(msg),
+                                                              &count);
+  if (ret != RTEMS_SUCCESSFUL) {
+    CAN_DEBUG_RX("rtems_message_queue_send failed\n");
+  CAN_DEBUG_RX("rtems_message_queue_broadcast = %u\n", count);
+  return ret;
+/* count argument is not used here as struct can_msg has the dlc member */
+static ssize_t can_bus_read(rtems_libio_t *iop, void *buffer, size_t count)
+  int32_t ret = 0;
+  uint32_t flags = 0;
+  struct can_msg *msg = (struct can_msg *)buffer;
+  if ((iop->flags & O_NONBLOCK) != 0) {
+    flags = RTEMS_NO_WAIT;
+  ret = rtems_message_queue_receive(bus->rx_queue_id, (void *)msg, &count,
+                                    flags, 0);
+    return ret;
+  return count;
+/* This function is a critical section and should be called
+ * with CAN interrupts disabled and mutual exclusive
+  int ret = RTEMS_SUCCESSFUL;
+  struct can_msg *msg = NULL;
+  CAN_DEBUG(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> can_xmit Entry\n");
+  while (1) {
+    printf("can_dev_ops->dev_tx_ready\n");
+    ret = bus->can_dev_ops->dev_tx_ready(bus->priv);
+    if (ret != true) {
+      break;
+    printf("can_tx_get_data_buf\n");
+    msg = can_tx_get_data_buf(bus);
+    if (msg == NULL) {
+      break;
+    printf("can_dev_ops->dev_tx\n");
+    ret = bus->can_dev_ops->dev_tx(bus->priv, msg);
+        printf("can_xmit: dev_send failed\n");
+    ret = give_sem(bus);
+      printf("can_tx_done: rtems_semaphore_release failed = %d\n", ret);
+  CAN_DEBUG(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> can_xmit Exit\n");
+  return ret;
+void can_print_msg(struct can_msg const *msg)
+  printf("\n----------------------------------------------------------------\n");
+  printf("id = %d len = %d flags = 0x%08X\n", msg->id, msg->len, msg->flags);
+  for (int i = 0; i < msg->len; i++) {
+    printf("%02x ", msg->data[i]);
+  printf("\n-----------------------------------------------------------------\n");
+/* can_tx_done should be called only with interrupts disabled */
+int can_tx_done(struct can_bus *bus)
+  CAN_DEBUG("------------ can_tx_done Entry\n");
+  int ret = 0;
+  if (bus->can_dev_ops->dev_tx_ready(bus->priv) == true) {
+    can_xmit(bus);
+  CAN_DEBUG("------------ can_tx_done Exit\n");
+  return ret;
+static ssize_t
+  if (bus == NULL || bus->can_dev_ops->dev_tx == NULL) {
+  int32_t ret = 0;
+  struct can_msg const *msg = buffer;
+  struct can_msg *fifo_buf = NULL;
+    ret = try_sem(bus);
+      return -ret;
+  } else {
+    ret = take_sem(bus);
+      printf("can_bus_write: cannot take semaphore\n");
+      return -ret;
+  /* sleep is for debug purpose to test concurrency issues */
+  printf("can_bus_write: calling sleep\n");
+  //sleep(1);
+  printf("can_bus_write: coming out sleep\n");
+  can_interrupt_lock_acquire(bus);
+  fifo_buf = can_tx_get_empty_buf(bus);
+  if (fifo_buf == NULL) {
+    printf("can_bus_write: Buffer counts are not synchronized with semaphore count\n");
+    return -RTEMS_INTERNAL_ERROR;
+  CAN_DEBUG_TX("can_bus_write: empty_count = %u\n", bus->tx_fifo.empty_count);
+  //sleep(1);
+  uint32_t msg_size = (char *)&msg->data[msg->len] - (char *)msg;
+  CAN_DEBUG_TX("can_bus_write: can_msg_size = %u\n", msg_size);
+  if (msg_size > sizeof(struct can_msg)) {
+    printf("can_bus_write:"
+          "can message len error msg_size = %u struct can_msg = %u\n",
+          msg_size, sizeof(struct can_msg));
+    return -RTEMS_INVALID_SIZE;
+  CAN_DEBUG_TX("can_bus_write: copying msg from application to driver buffer\n");
+  memcpy(fifo_buf, msg, msg_size);
+  ret = msg_size;
+  //sleep(1);
+    can_xmit(bus);
+  can_interrupt_lock_release(bus);
+  return ret;
+static ssize_t
+  if (bus == NULL || bus->can_dev_ops->dev_ioctl == NULL) {
+  bus->can_dev_ops->dev_ioctl(bus->priv, NULL, 0);
+  return RTEMS_SUCCESSFUL;
+static const rtems_filesystem_file_handlers_r can_bus_handler = {
+  .open_h = can_bus_open,
+  .close_h = rtems_filesystem_default_close,
+  .read_h = can_bus_read,
+  .write_h = can_bus_write,
+  .ioctl_h = can_bus_ioctl,
+  .lseek_h = rtems_filesystem_default_lseek,
+  .fstat_h = IMFS_stat,
+  .ftruncate_h = rtems_filesystem_default_ftruncate,
+  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+  .fcntl_h = rtems_filesystem_default_fcntl,
+  .kqfilter_h = rtems_filesystem_default_kqfilter,
+  .mmap_h = rtems_filesystem_default_mmap,
+  .poll_h = rtems_filesystem_default_poll,
+  .readv_h = rtems_filesystem_default_readv,
+  .writev_h = rtems_filesystem_default_writev
+static void can_bus_node_destroy(IMFS_jnode_t *node)
+  can_bus *bus;
+  bus = IMFS_generic_get_context_by_node(node);
+  (*bus->destroy)(bus);
+  IMFS_node_destroy_default(node);
+static const
+IMFS_node_control can_bus_node_control = IMFS_GENERIC_INITIALIZER(&can_bus_handler,
+                    IMFS_node_initialize_generic, can_bus_node_destroy);
+rtems_status_code can_bus_register(can_bus *bus, const char *bus_path)
+  static uint8_t index = 0;
+  if (index == 255) {
+    printf("can_bus_register: can bus registration limit reached\n");
+    return RTEMS_TOO_MANY;
+  bus->index = index++;
+  CAN_DEBUG("Registering CAN bus index = %u\n", bus->index);
+  ret = IMFS_make_generic_node(bus_path, S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
+                              &can_bus_node_control, bus);
+    printf("can_bus_register: Creating node failed = %d\n", ret);
+    goto fail;
+  if ((ret = can_create_sem(bus)) != RTEMS_SUCCESSFUL) {
+    printf("can_bus_register: can_create_sem failed = %d\n", ret);
+    goto fail;
+  if ((ret = can_create_tx_buffers(bus)) != RTEMS_SUCCESSFUL) {
+    printf("can_bus_register: can_create_tx_buffers failed = %d\n", ret);
+    goto free_tx_semaphore;
+  if ((ret = can_create_rx_buffers(bus)) != RTEMS_SUCCESSFUL) {
+    printf("can_bus_register: can_create_rx_buffers failed = %d\n", ret);
+    goto free_tx_buffers;
+  return ret;
+free_tx_buffers:
+  free(bus->tx_fifo.pbuf);
+free_tx_semaphore:
+fail:
+  can_bus_destroy_mutex(bus);
+  return ret;
+static void can_bus_destroy(can_bus *bus)
+  can_free_rx_buffers(bus);
+  can_free_tx_buffers(bus);
+  can_free_tx_semaphore(bus);
+static int can_bus_do_init(can_bus *bus, void (*destroy)(can_bus *bus))
+  rtems_mutex_init(&bus->mutex, "CAN Bus");
+  bus->destroy = can_bus_destroy;
+static void can_bus_destroy_and_free(can_bus *bus)
+  can_bus_destroy(bus);
+  free(bus);
+int can_bus_init(can_bus *bus)
+  memset(bus, 0, sizeof(*bus));
+  return can_bus_do_init(bus, can_bus_destroy);
+can_bus *can_bus_alloc_and_init(size_t size)
+  can_bus *bus = NULL;
+  if (size >= sizeof(*bus)) {
+    bus = calloc(1, size);
+      printf("can_bus_alloc_and_init: calloc failed\b");
+      return NULL;
+    int rv = can_bus_do_init(bus, can_bus_destroy_and_free);
+    if (rv != 0) {
+      printf("can_bus_alloc_and_init: can_bus_do_init failed\n");
+      return NULL;
+  return bus;
diff --git a/cpukit/include/dev/can/can-msg.h b/cpukit/include/dev/can/can-msg.h
index 0000000000..9863e14d84
--- /dev/null
+++ b/cpukit/include/dev/can/can-msg.h
@@ -0,0 +1,105 @@
+ * @file
+ * @ingroup CANBus
+ * Copyright (C) 2022 Prashanth S <fishesprashanth at gmail.com>
+ * are met:
+#ifndef _DEV_CAN_CAN_MSG_H
+#define _DEV_CAN_CAN_MSG_H
+ * @defgroup Controller Area Network (CAN) Driver
+ * @ingroup RTEMSDeviceDrivers
+ * @brief Controller Area Network (CAN) bus and device driver support.
+ * @defgroup CANBus CAN Bus Driver
+ * @ingroup CAN
+ * @brief CAN message size
+#define CAN_MSG_MAX_SIZE  (8u)
+ * @brief Number of CAN tx buffers
+#define CAN_TX_BUF_COUNT  (10u)
+ * @brief Number of CAN rx buffers
+#define CAN_RX_BUF_COUNT  (2u)
+#define CAN_MSGLEN(msg) (sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len))
+ * @brief CAN message structure.
+struct can_msg {
+   * @brief CAN message id.
+  uint32_t id;
+   * @brief CAN message timestamp.
+  uint32_t timestamp;
+   * @brief CAN message flags RTR | BRS | EXT.
+  uint16_t flags;
+   * @brief CAN message length.
+  uint16_t len;
+   * @brief CAN message.
+  uint8_t data[CAN_MSG_MAX_SIZE];
+/** @} */  /* end of CAN message */
+#endif /* _DEV_CAN_CAN_MSG_H */
diff --git a/cpukit/include/dev/can/can-queue.h b/cpukit/include/dev/can/can-queue.h
index 0000000000..0d8aa78a84
--- /dev/null
+++ b/cpukit/include/dev/can/can-queue.h
@@ -0,0 +1,219 @@
+ * @file
+ * @ingroup CANBus
+ * are met:
+#ifndef _DEV_CAN_CAN_QUEUE_H
+#define _DEV_CAN_CAN_QUEUE_H
+#include <stdio.h>
+#include <dev/can/can-msg.h>
+ * @ingroup CAN
+ * @brief Create CAN tx buffers.
+ * @param[in] bus Bus control structure.
+ * @retval 0 Successful operation.
+ * @retval >0 error number in case of an error.
+static rtems_status_code can_create_tx_buffers(struct can_bus *bus);
+ * @brief Create CAN rx buffers.
+static rtems_status_code can_create_rx_buffers(struct can_bus *bus);
+ * @brief Free CAN tx buffers.
+static void can_free_tx_buffers(struct can_bus *bus);
+ * @brief Free CAN rx buffers.
+static void can_free_rx_buffers(struct can_bus *bus);
+ * @brief Check for atleast one empty CAN tx buffer.
+ * @retval true If atleast one CAN buffer is empty.
+ * @retval false If no CAN buffer is empty.
+static bool can_tx_buf_isempty(struct can_bus *bus);
+ * @brief Get a produced tx buffer to process.
+ * @retval can_msg Pointer to can_msg structure buffer.
+ * @retval NULL If no can_msg buffer.
+static struct can_msg *can_tx_get_data_buf(struct can_bus *bus);
+ * @brief Get a empty tx buffer.
+ * @retval NULL If no empty can_msg buffer.
+static struct can_msg *can_tx_get_empty_buf(struct can_bus *bus);
+/** @} */  /* end of i2c device driver */
+  return rtems_message_queue_create(rtems_build_name('c', 'a', 'n', bus->index),
+           CAN_RX_BUF_COUNT, sizeof(struct can_msg),
+           RTEMS_FIFO | RTEMS_LOCAL, &bus->rx_queue_id);
+  bus->tx_fifo.pbuf = (struct can_msg *)malloc(CAN_TX_BUF_COUNT *
+                              sizeof(struct can_msg));
+  if (bus->tx_fifo.pbuf == NULL) {
+    printf("can_create_tx_buffers: malloc failed\n");
+    return RTEMS_NO_MEMORY;
+  bus->tx_fifo.empty_count = CAN_TX_BUF_COUNT;
+  rtems_message_queue_delete(bus->rx_queue_id);
+  if (bus->tx_fifo.empty_count == 0) {
+    return false;
+  return true;
+// TODO: free the given data buf is done in the same function
+// SO the returned buffer should be consumed before releasing the
+// lock acquired while calling this function.
+  if (bus->tx_fifo.empty_count == CAN_TX_BUF_COUNT) {
+    CAN_DEBUG_BUF("can_tx_get_data_buf: All buffers are empty\n");
+    return NULL;
+  msg = &bus->tx_fifo.pbuf[bus->tx_fifo.tail];
+  bus->tx_fifo.empty_count++;
+  bus->tx_fifo.tail = (bus->tx_fifo.tail + 1) % CAN_TX_BUF_COUNT;
+  return msg;
+// TODO: marking the given buf as produced is done in the same function
+// So the returned buffer should be produced before releasing the
+  /* Check whether there is a empty CAN msg buffer */
+  if (can_tx_buf_isempty(bus) == false) {
+    CAN_DEBUG_BUF("can_tx_get_empty_buf: No empty buffer\n");
+    return NULL;
+  bus->tx_fifo.empty_count--;
+  /* tx_fifo.head always points to a empty buffer if there is atleast one */
+  msg = &bus->tx_fifo.pbuf[bus->tx_fifo.head];
+  bus->tx_fifo.head = (bus->tx_fifo.head + 1) % CAN_TX_BUF_COUNT;
+  return msg;
+#endif /*_DEV_CAN_CAN_QUEUE_H */
diff --git a/cpukit/include/dev/can/can.h b/cpukit/include/dev/can/can.h
index 0000000000..0074a3dd8f
--- /dev/null
+++ b/cpukit/include/dev/can/can.h
@@ -0,0 +1,258 @@
+ * @file
+ * @ingroup CANBus
+ * are met:
+#ifndef _DEV_CAN_CAN_H
+#define _DEV_CAN_CAN_H
+#include <semaphore.h>
+#include <stdio.h>
+#define CAN_DEBUG(str, ...) printf("CAN: %s:%d ID: %08X ", __FILE__, __LINE__, rtems_task_self());printf(str, ##__VA_ARGS__)
+#define CAN_DEBUG_BUF(str, ...) printf("CAN: %s:%d ID: %08X ", __FILE__, __LINE__, rtems_task_self());printf(str, ##__VA_ARGS__)
+#define CAN_DEBUG_ISR(str, ...) printf("CAN: %s:%d ID: %08X ", __FILE__, __LINE__, rtems_task_self());printf(str, ##__VA_ARGS__)
+#define CAN_DEBUG_LOCK(str, ...) printf("CAN: %s:%d ID: %08X ", __FILE__, __LINE__, rtems_task_self());printf(str, ##__VA_ARGS__)
+#define CAN_DEBUG_RX(str, ...) printf("CAN: %s:%d ID: %08X ", __FILE__, __LINE__, rtems_task_self());printf(str, ##__VA_ARGS__)
+#define CAN_DEBUG_TX(str, ...) printf("CAN: %s:%d ID: %08X ", __FILE__, __LINE__, rtems_task_self());printf(str, ##__VA_ARGS__)
+ * @ingroup CAN
+ * @brief CAN tx fifo data structure.
+struct ring_buf {
+   * @brief Pointer to array of can_msg structure.
+  struct can_msg *pbuf;
+   * @brief Index of the next free buffer.
+  uint32_t head;
+   * @brief Index of the produced buffer.
+  uint32_t tail;
+   * @brief Number of empty buffers.
+  uint32_t empty_count;
+ * @brief CAN device specific operations.
+typedef struct can_dev_ops {
+   * @brief Transfers CAN messages to device fifo.
+   * @param[in] priv device control structure.
+   * @param[in] msg can_msg message structure.
+  int32_t (*dev_tx)(void *priv, struct can_msg *msg);
+   * @brief Check device is ready to transfer a CAN message
+   * @retval true device ready.
+   * @retval false device not ready.
+  bool (*dev_tx_ready)(void *priv);
+   * @brief Enable/Disable CAN interrupts.
+   * @param[in] flag true/false to Enable/Disable CAN interrupts.
+  void (*dev_int)(void *priv, bool flag);
+   * @brief CAN device specific I/O controls.
+   * @param[in] buffer This depends on the cmd.
+   * @param[in] cmd Device specific I/O commands.
+   * @retval 0 Depends on the cmd.
+  int32_t (*dev_ioctl)(void *priv, void *buffer, size_t cmd);
+} can_dev_ops;
+ * @name CAN bus control
+ * @brief Obtains the bus.
+ * This command has no argument.
+typedef struct can_bus {
+   * @brief Device specific control.
+  void *priv;
+   * @brief Device controller index.
+  uint8_t index;
+   * @brief Device specific operations.
+  struct can_dev_ops *can_dev_ops;
+   * @brief tx fifo.
+  struct ring_buf tx_fifo;
+   * @brief Counting semaphore id (for fifo sync).
+  rtems_id tx_fifo_sem_id;
+   * @brief rx message queue id.
+  rtems_id rx_queue_id;
+   * @brief rx message queue name.
+  uint32_t rx_queue_name;
+   * @brief Mutex to handle bus concurrency.
+  rtems_mutex mutex;              // For handling driver concurrency.
+   * @brief Destroys the bus.
+   * @param[in] bus control structure.
+  void (*destroy)(struct can_bus *bus);     // Clean the CAN controller specific resources.
+} can_bus;
+ * @brief Register a CAN node with the CAN bus driver.
+ * @param[in] bus bus control structure.
+ * @param[in] bus_path path of device node.
+ * @retval >=0 rtems status.
+extern rtems_status_code can_bus_register(can_bus *bus, const char *bus_path);
+ * @brief Allocate and initilaize bus control structure.
+ * @param[in] size Size of the bus control structure.
+ * @retval NULL No memory available.
+ * @retval Address Pointer to the allocated bus control structure.
+extern can_bus *can_bus_alloc_and_init(size_t size);
+ * @brief initilaize bus control structure.
+ * @retval 0 success.
+ * @retval >0 error number.
+extern int can_bus_init(can_bus *bus);
+ * @brief Initiates CAN message transfer.
+ * Should be called in interrupt context.
+extern int can_tx_done(struct can_bus *bus);
+ * @brief Sends the received CAN message to the application.
+ * Should be called by the device when CAN message should be sent to applicaiton.
+ * @param[in] msg can_msg structure.
+extern int can_receive(struct can_bus *bus, struct can_msg *msg);
+extern uint16_t can_len_to_dlc(uint16_t len);
+extern uint16_t can_dlc_to_len(uint16_t dlc);
+extern void can_print_msg(struct can_msg const *);
+/** @} */  /* end of CAN device driver */
+#endif /* _DEV_CAN_CAN_H */
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 31a68cf85a..b7f6c0457c 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -50,6 +50,11 @@ install:
 - destination: ${BSP_INCLUDEDIR}/dev/spi
   source:
   - cpukit/include/dev/spi/spi.h
+- destination: ${BSP_INCLUDEDIR}/dev/can
+  source:
+  - cpukit/include/dev/can/can.h
+  - cpukit/include/dev/can/can-msg.h
+  - cpukit/include/dev/can/can-queue.h
 - destination: ${BSP_INCLUDEDIR}/linux
   source:
   - cpukit/include/linux/i2c-dev.h
@@ -530,6 +535,7 @@ source:
 - cpukit/dev/serial/sc16is752-spi.c
 - cpukit/dev/serial/sc16is752.c
 - cpukit/dev/spi/spi-bus.c
+- cpukit/dev/can/can.c
 - cpukit/dtc/libfdt/fdt.c
 - cpukit/dtc/libfdt/fdt_addresses.c
 - cpukit/dtc/libfdt/fdt_empty_tree.c
diff --git a/spec/build/testsuites/libtests/can01.yml b/spec/build/testsuites/libtests/can01.yml
index 0000000000..2d5be51db1
--- /dev/null
+++ b/spec/build/testsuites/libtests/can01.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/can01/init.c
+stlib: []
+target: testsuites/libtests/can01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index 2aa7fa058e..9d91df75a0 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -76,6 +76,8 @@ links:
   uid: cpuuse
 - role: build-dependency
   uid: crypt01
+- role: build-dependency
+  uid: can01
   uid: debugger01
diff --git a/testsuites/libtests/can01/init.c b/testsuites/libtests/can01/init.c
index 0000000000..2fc7e2fe8a
--- /dev/null
+++ b/testsuites/libtests/can01/init.c
@@ -0,0 +1,257 @@
+ *  COPYRIGHT (c) 1989-2012.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+#include <unistd.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <inttypes.h>
+#include <rtems/error.h>
+#define TASKS	12
+#include <sys/time.h>
+#include <errno.h>
+#include <sched.h>
+#include <stdint.h>
+#include <pthread.h>
+#define NEXT_TASK_NAME(c1, c2, c3, c4)  \
+                 if (c4 == '9') {       \
+                   if (c3 == '9') {     \
+                     if (c2 == 'z') {   \
+                       if (c1 == 'z') { \
+                         printf("not enough task letters for names !!!\n"); \
+                         exit( 1 );     \
+                       } else           \
+                         c1++;          \
+                       c2 = 'a';        \
+                     } else             \
+                      c2++;             \
+                     c3 = '0';          \
+                   } else               \
+                     c3++;              \
+                   c4 = '0';            \
+                 else                   \
+                   c4++                 \
+const char rtems_test_name[] = "CAN test TX, RX with " "TASKS " "threads";
+void test_task_0(rtems_task_argument);
+bool status_code_bad(rtems_status_code);
+int create_task(int);
+void test_task_0(rtems_task_argument data)
+	sleep(1);
+	uint32_t count = 0, fd = 0;
+	struct can_msg msg;
+	char str[12];
+	snprintf(str, 12, "/dev/can%d", 1);
+  printf(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> CAN tx and rx for %s\n", str);
+	fd = open(str, O_RDWR);
+  	rtems_test_assert(fd >= 0);
+	if (fd < 0) {
+		printf("open error %s: %s\n", str, strerror(errno));
+		return;
+	for (int i = 0; i < 0xffff; i++) {
+		printf(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> test_task_0 %d\n", (int)data);
+		msg.id = (uint32_t)data;
+		msg.flags = 0;
+		msg.len = (i + 1) % 9;
+		msg.data[0] = '0';
+		msg.data[1] = '1';
+		msg.data[2] = 't';
+		msg.data[3] = 'a';
+		msg.data[4] = '-';
+		msg.data[5] = '0';
+    printf("calling write task = %d\n", (int)data);
+		count = write(fd, &msg, sizeof(msg));
+		printf(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> task = %d\n", (int)data);
+		printf("task = %d write count = %u\n", (int)data, count);
+    printf("calling read task = %d\n", (int)data);
+		count = read(fd, &msg, sizeof(msg));
+		printf("task = %d read count = %u\n", (int)data, count);
+		printf("++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ received message\n");
+		can_print_msg(&msg);
+	close(fd);
+  rtems_status_code status_code
+  if (status_code != RTEMS_SUCCESSFUL)
+    printf("failure, ");
+    if (status_code == RTEMS_TOO_MANY)
+      printf("too many.\n");
+      return TRUE;
+    if (status_code == RTEMS_UNSATISFIED)
+      printf("unsatisfied.\n");
+      return TRUE;
+    printf("error code = %i\n", status_code);
+    exit( 1 );
+  return FALSE;
+int create_task(int i)
+	printf("Creating task %d\n", i);
+#ifndef _POSIX_THREADS_
+	static rtems_id task_id[TASKS];
+  rtems_status_code    result;
+  rtems_name name;
+  char c1 = 'a';
+  char c2 = 'a';
+  char c3 = '1';
+  char c4 = '1';
+  name = rtems_build_name(c1, c2, c3, c4);
+  result = rtems_task_create(name,
+                             10,
+                             1024 * 12,
+                             RTEMS_PREEMPT | RTEMS_TIMESLICE,
+														 RTEMS_FIFO,
+                             &task_id[i]);
+  if (result != 0) {
+		printf("rtems_task_create %d\n", result);
+		return result;
+  printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ", i, task_id[i]);
+  fflush(stdout);
+  result = rtems_task_start(task_id[i],
+                            test_task_0,
+                            (rtems_task_argument)i);
+  if (status_code_bad(result)) {
+		printf("rtems_task_start failed\n");
+		return result;
+  NEXT_TASK_NAME(c1, c2, c3, c4);
+#else
+	static pthread_t Task_id[TASKS];
+	int status = pthread_create( &Task_id[i], NULL, test_task_0, (void *)i);
+	if (status != 0) {
+		printf("pthread_create failed %d\n", status);
+		return status;
+	printf("Creating tasks\n");
+#endif /* _POSIX_THREADS_ */
+	return 0;
+static rtems_task Init(
+  rtems_task_argument ignored
+	printf("Init\n");
+  rtems_print_printer_fprintf_putc(&rtems_test_printer);
+  TEST_BEGIN();
+  rtems_task_priority old_priority;
+  rtems_mode          old_mode;
+  rtems_task_set_priority(RTEMS_SELF, RTEMS_MAXIMUM_PRIORITY - 1, &old_priority);
+  rtems_task_mode(RTEMS_PREEMPT,  RTEMS_PREEMPT_MASK, &old_mode);
+	for (int i = 0; i < TASKS; i++) {
+		create_task(i);
+  while(1);
+  TEST_END();
+  rtems_test_exit( 0 );
+#define CONFIGURE_MICROSECONDS_PER_TICK 2000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 20
+#define CONFIGURE_MAXIMUM_TASKS 20
+#define CONFIGURE_MAXIMUM_SEMAPHORES 10
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 20
+//#define CONFIGURE_MESSAGE_BUFFER_MEMORY CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(1, 1)
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_MAXIMUM_POSIX_THREADS     TASKS
+//#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+//#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT POSIX_Init
+#include <rtems/confdefs.h>
2.25.1
