[PATCH v4 0/2] NOEL-V BSP
Daniel Cederman
cederman at gaisler.com
Mon Aug 15 07:16:22 UTC 2022
v4
Changed .data to .bsp_start_data
Moved assembly defines to asm.h
Use the common optextirqmax
Use optconsoleirq instead of optconirq
Declared riscv_start_stack_pointer as const
Martin Aberg (2):
bsp/riscv: Work area size based on stack pointer
bsp/riscv: Add NOEL-V BSP
bsps/riscv/include/bsp/start.h | 67 ++++++
bsps/riscv/noel/console/console-config.c | 209 ++++++++++++++++++
bsps/riscv/noel/include/bsp.h | 76 +++++++
bsps/riscv/noel/include/bsp/irq.h | 75 +++++++
bsps/riscv/noel/include/tm27.h | 1 +
bsps/riscv/noel/start/bsp_fatal_halt.c | 46 ++++
bsps/riscv/riscv/include/bsp.h | 2 +
bsps/riscv/riscv/include/bsp/irq.h | 2 +
.../shared/start/bspgetworkarea-fromstack.c | 76 +++++++
bsps/riscv/shared/start/start.S | 15 ++
cpukit/score/cpu/riscv/include/rtems/asm.h | 12 +
spec/build/bsps/riscv/noel/abi.yml | 48 ++++
spec/build/bsps/riscv/noel/bspnoel32im.yml | 19 ++
spec/build/bsps/riscv/noel/bspnoel32imafd.yml | 19 ++
spec/build/bsps/riscv/noel/bspnoel64imac.yml | 19 ++
spec/build/bsps/riscv/noel/bspnoel64imafd.yml | 19 ++
.../build/bsps/riscv/noel/bspnoel64imafdc.yml | 19 ++
spec/build/bsps/riscv/noel/grp.yml | 59 +++++
spec/build/bsps/riscv/noel/obj.yml | 38 ++++
spec/build/bsps/riscv/noel/objsmp.yml | 15 ++
spec/build/bsps/riscv/optrambegin.yml | 3 +
spec/build/cpukit/optarchbits.yml | 2 +
spec/build/cpukit/optsmp.yml | 4 +
23 files changed, 845 insertions(+)
create mode 100644 bsps/riscv/include/bsp/start.h
create mode 100644 bsps/riscv/noel/console/console-config.c
create mode 100644 bsps/riscv/noel/include/bsp.h
create mode 100644 bsps/riscv/noel/include/bsp/irq.h
create mode 100644 bsps/riscv/noel/include/tm27.h
create mode 100644 bsps/riscv/noel/start/bsp_fatal_halt.c
create mode 100644 bsps/riscv/shared/start/bspgetworkarea-fromstack.c
create mode 100644 spec/build/bsps/riscv/noel/abi.yml
create mode 100644 spec/build/bsps/riscv/noel/bspnoel32im.yml
create mode 100644 spec/build/bsps/riscv/noel/bspnoel32imafd.yml
create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imac.yml
create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafd.yml
create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafdc.yml
create mode 100644 spec/build/bsps/riscv/noel/grp.yml
create mode 100644 spec/build/bsps/riscv/noel/obj.yml
create mode 100644 spec/build/bsps/riscv/noel/objsmp.yml
2.34.1
