[PATCH v1 02/12] linkersets.h: Fix gcc 12 warning
Ryan Long ryan.long at oarcorp.com
Tue Aug 16 20:11:49 UTC 2022
Changing the offset from 0 to 1 got rid of a warning stating that offset 0 is
out of bounds.
Updates #4662
 cpukit/include/rtems/linkersets.h | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/linkersets.h b/cpukit/include/rtems/linkersets.h
index cdfcd54cde..45f9dc1ef7 100644
--- a/cpukit/include/rtems/linkersets.h
+++ b/cpukit/include/rtems/linkersets.h
@@ -92,7 +92,7 @@ extern "C" {
   extern RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_END( set )[]
 #define RTEMS_LINKER_RWSET( set, type ) \
-  RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_BEGIN( set )[ 0 ] \
+  RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_BEGIN( set )[ 1 ] \
   RTEMS_SECTION( ".rtemsrwset." #set ".begin" ) RTEMS_USED; \
   RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_END( set )[ 0 ] \
   RTEMS_SECTION( ".rtemsrwset." #set ".end" ) RTEMS_USED
2.11.0
