[PATCH v1 09/12] malloctest/init.c: Added pragmas to address gcc 12 warnings
Ryan Long
ryan.long at oarcorp.com
Tue Aug 16 20:11:57 UTC 2022
Fixed four warnings disabled were for "-Wuse-after-free" and one for a
"-Wfree-nonheap-object."
Updates #4662
testsuites/libtests/malloctest/init.c | 41 ++++++++++++++++++++++++++++++++---
1 file changed, 38 insertions(+), 3 deletions(-)
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index 05d97a27d5..ae3719c2cd 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -60,8 +60,15 @@ static void test_realloc(void)
for (i=2 ; i<2048 ; i++) {
p2 = realloc(p1, i);
if (p2 != p1)
+ * This was added to address the following warning.
+ * warning: pointer 'p1' may be used after 'realloc'
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Wuse-after-free"
printf( "realloc - failed grow in place: "
"%p != realloc(%p,%zu)\n", p1, p2, i);
+#pragma GCC diagnostic pop
p1 = p2;
free(p1);
@@ -71,8 +78,15 @@ static void test_realloc(void)
for (i=2047 ; i>=1; i--) {
if (p2 != p1)
- printf( "realloc - failed shrink in place: "
+ printf( "realloc - failed shrink in place: "
p1 = p2;
free(p1);
@@ -84,8 +98,15 @@ static void test_realloc(void)
p2 = malloc(32);
p3 = realloc(p1, 64);
if (p3 == p1 || p3 == NULL)
- printf(
+ * warning: pointer may be used after 'realloc'
+ printf(
"realloc - failed non-in place: realloc(%p,%d) = %p\n", p1, 64, p3);
free(p3);
free(p2);
@@ -122,7 +143,14 @@ static void test_realloc(void)
* Realloc with a bad pointer to force a point
- p4 = realloc( test_realloc, 32 );
+ * warning: 'realloc' called on unallocated object
+#pragma GCC diagnostic ignored "-Wfree-nonheap-object"
+ p4 = realloc( test_realloc, 32 );
p4 = _realloc_r( NULL, NULL, 1 );
@@ -1528,8 +1556,15 @@ static void test_early_malloc( void )
free( q );
+ * warning: pointer 'q' used after 'free'
r = realloc( q, 128 );
rtems_test_assert( r == q );
s = malloc( 1 );
rtems_test_assert( s != NULL );
2.11.0
