[PATCH RSB] Fixes for getting sources
Wed Aug 17 02:13:44 UTC 2022
On Tue, Aug 16, 2022, 6:34 PM <chrisj at rtems.org> wrote:
> Hi
> These patches fix getting sources for all the packages so releases
> can be CI tested to catch breakages closer to the time they happen.
Thanks. I didn't expect a question to turn into a quest for you.
Is this for 5 and 6?
> The get sources tool now finds the top level buildset files and only
> fetches the sources for them. This avoids processing and handling
> configurations that are out of date.
What's an example command for this?
> The tool also captures the used buildset and config files and if
> all top level buildset files are fetched the unused files can be
> listed. This can be used to clean up the repo.
> I think it is time to remove old configs. There are some using CVS
> or depending on host versions of tools no one runs anymore.
I'm good with these patches and removing unused configurations.
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220816/8b00525c/attachment.htm>
