[PATCH] bsp/riscv: Work area size based on /memory node in fdt
Daniel Cederman cederman at gaisler.com
Wed Aug 17 11:34:29 UTC 2022
Sure, I can move it to the shared directory (riscv/shared/start).
On 2022-08-17 11:16, Hesham Almatary wrote:
> Thanks for the patch. LGTM. I wonder if we can also reuse that for the
> generic shared RISC-V BSP (e.g., bsps/riscv/riscv) instead of just NOEL?
> On Wed, 17 Aug 2022 at 09:58, Daniel Cederman <cederman at gaisler.com>
> wrote:
>     Uses the first entry in the /memory node to determine the end of the
>     work area. Falls back on linker symbol if unable to parse the node.
>      bsps/riscv/noel/start/bspgetworkarea.c | 144
>      spec/build/bsps/riscv/noel/obj.yml     |   1 +
>      2 files changed, 145 insertions(+)
>      create mode 100644 bsps/riscv/noel/start/bspgetworkarea.c
>     diff --git a/bsps/riscv/noel/start/bspgetworkarea.c
>     b/bsps/riscv/noel/start/bspgetworkarea.c
>     new file mode 100644
>     index 0000000000..1fa051d25e
>     --- /dev/null
>     +++ b/bsps/riscv/noel/start/bspgetworkarea.c
>     @@ -0,0 +1,144 @@
>     +/* SPDX-License-Identifier: BSD-2-Clause */
>     + * @file
>     + * @brief BSP specific initialization support routines
>     + * COPYRIGHT (c) 1989-2020.
>     + * On-Line Applications Research Corporation (OAR).
>     + * Cobham Gaisler AB.
>     + * Redistribution and use in source and binary forms, with or without
>     + * modification, are permitted provided that the following conditions
>     + * are met:
>     + * 1. Redistributions of source code must retain the above copyright
>     + *    notice, this list of conditions and the following disclaimer.
>     + * 2. Redistributions in binary form must reproduce the above
>     copyright
>     disclaimer in the
>     + *    documentation and/or other materials provided with the
>     distribution.
>     + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>     CONTRIBUTORS "AS IS"
>     + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>     LIMITED TO, THE
>     + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>     PARTICULAR PURPOSE
>     + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>     CONTRIBUTORS BE
>     + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>     EXEMPLARY, OR
>     + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>     PROCUREMENT OF
>     + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
>     OR BUSINESS
>     + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>     WHETHER IN
>     + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>     OTHERWISE)
>     + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>     ADVISED OF THE
>     + * POSSIBILITY OF SUCH DAMAGE.
>     +#include <bsp.h>
>     +#include <bsp/fdt.h>
>     +#include <rtems/sysinit.h>
>     +#include <libfdt.h>
>     + *  These are provided by the linkcmds for ALL of the BSPs which
>     use this file.
>     +extern char WorkAreaBase[];
>     +extern char RamEnd[];
>     +static Memory_Area _Memory_Areas[ 1 ];
>     +static const char memory_path[] = "/memory";
>     +static void* get_end_of_memory_from_fdt(void)
>     +  const void *fdt;
>     +  const void *val;
>     +  int node;
>     +  int parent;
>     +  int ac;
>     +  int sc;
>     +  int len;
>     +  uintptr_t start;
>     +  uintptr_t size;
>     +  fdt = bsp_fdt_get();
>     +  node = fdt_path_offset_namelen(
>     +    fdt,
>     +    memory_path,
>     +    (int) sizeof(memory_path) - 1
>     +  if (node < 0) {
>     +    return NULL;
>     +  parent = fdt_parent_offset(fdt, node);
>     +  if (parent < 0) {
>     +    return NULL;
>     +  ac = fdt_address_cells(fdt, parent);
>     +  if (ac != 1 && ac != 2) {
>     +    return NULL;
>     +  sc = fdt_size_cells(fdt, parent);
>     +  if (sc != 1 && sc != 2) {
>     +    return NULL;
>     +  if (sc > ac) {
>     +    return NULL;
>     +  val = fdt_getprop(fdt, node, "reg", &len);
>     +  if (len < sc + ac) {
>     +    return NULL;
>     +  if (ac == 1) {
>     +    start = fdt32_to_cpu(((fdt32_t *)val)[0]);
>     +    size = fdt32_to_cpu(((fdt32_t *)val)[1]);
>     +  if (ac == 2) {
>     +    start = fdt64_to_cpu(((fdt64_t *)val)[0]);
>     +    if (sc == 1)
>     +      size = fdt32_to_cpu(((fdt32_t *)(val+8))[0]);
>     +    else
>     +      size = fdt64_to_cpu(((fdt64_t *)val)[1]);
>     +  return (void*) (start + size);
>     +static void bsp_memory_initialize( void )
>     +  void *end;
>     +  /* get end of memory from the "/memory" node in the fdt */
>     +  end = get_end_of_memory_from_fdt();
>     +  if (end == 0) {
> NULL instead of 0?
>     +    /* fall back to linker symbol if "/memory" node not found or
>     invalid */
>     +    end = RamEnd;
>     +  _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
>     +RTEMS_SYSINIT_ITEM(
>     +  bsp_memory_initialize,
>     +  RTEMS_SYSINIT_MEMORY,
>     +  RTEMS_SYSINIT_ORDER_MIDDLE
>     +static const Memory_Information _Memory_Information =
>     +  MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
>     +const Memory_Information *_Memory_Get( void )
>     +  return &_Memory_Information;
>     diff --git a/spec/build/bsps/riscv/noel/obj.yml
>     b/spec/build/bsps/riscv/noel/obj.yml
>     index e1b652fa93..f9902f83b5 100644
>     --- a/spec/build/bsps/riscv/noel/obj.yml
>     +++ b/spec/build/bsps/riscv/noel/obj.yml
>     @@ -22,6 +22,7 @@ source:
>      - bsps/riscv/noel/console/console-config.c
>      - bsps/riscv/riscv/irq/irq.c
>      - bsps/riscv/noel/start/bsp_fatal_halt.c
>     +- bsps/riscv/noel/start/bspgetworkarea.c
>      - bsps/riscv/riscv/start/bspstart.c
>      - bsps/shared/cache/nocache.c
>      - bsps/shared/dev/btimer/btimer-cpucounter.c
>     2.34.1
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org
>     http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220817/84958e84/attachment-0001.htm>
