qoriq build of rtems-libbsd
Joel Sherrill
joel at rtems.org
Wed Aug 17 21:05:12 UTC 2022
And the same error happens on qm8xx_stk8xx.
On Wed, Aug 17, 2022 at 4:01 PM Joel Sherrill <joel at rtems.org> wrote:
> Sorry. Forgot to update my libbsd tree and got the wrong error. It is this:
> /home/joel/rtems-work/tools/6/lib/gcc/powerpc-rtems6/12.1.1/../../../../powerpc-rtems6/bin/ld:
> ./libbsd.a(nfs_clbio.c.10.o): the target (_bsd_unmapped_buf) of a
> R_PPC_SDAREL16 relocation is in the wrong output section (.data)
> ./libbsd.a(nfs_clbio.c.10.o): in function `ncl_putpages':
> /home/joel/rtems-work/rtems-libbsd/build/powerpc-rtems6-qoriq_e6500_32-default/../../freebsd/sys/fs/nfsclient/nfs_clbio.c:349:(.text.ncl_putpages+0x22a):
> relocation truncated to fit: R_PPC_SDAREL16 against symbol
> `_bsd_unmapped_buf' defined in .data.read_mostly section in
> ./libbsd.a(vfs_bio.c.20.o)
> collect2: error: ld returned 1 exit status
> On Wed, Aug 17, 2022 at 3:44 PM Joel Sherrill <joel at rtems.org> wrote:
>> Hi
>> Not sure what's going on but 6-freebsd-12 does not build for
>> qoriq_e6500_32
>> In file included from parse.y:88:
>> ../../freebsd/sbin/pfctl/pfctl_parser.h:181:27: error: expected ')'
>> before numeric constant
>> 181 | BITSET_DEFINE(qpri_bitset, QPRI_BITSET_SIZE);
>> ../../freebsd/sbin/pfctl/pfctl_parser.h:189:49: error: field 'qpris' has
>> incomplete type
>> 189 | struct qpri_bitset qpris;
>> Waf: Leaving directory
>> `/home/joel/rtems-work/rtems-libbsd/build/powerpc-rtems6-qoriq_e6500_32-default'
>> Build failed
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220817/44bd8212/attachment-0001.htm>
