[PATCH v2 1/1] bsp/riscv: Work area size based on /memory node in fdt
Daniel Cederman
cederman at gaisler.com
Thu Aug 18 12:55:31 UTC 2022
I missed your comment, but have made the change now. Are there any
instructions on how to run the RISCV BSP tests on QEMU or Spike? I could
not get it to work. Do I need a special version of QEMU or Spike?
On 2022-08-18 10:24, Hesham Almatary wrote:
> All good, I'd just replace the "end == 0" with "end == NULL" as per my
> comment above. Also please test on other RISC-V QEMU platforms to make
> sure nothing got broken.
> On Wed, 17 Aug 2022 at 14:10, Joel Sherrill<joel at rtems.org> wrote:
>> I'm ok with this if Hesham acks as well.
>> --joel
>> On Wed, Aug 17, 2022 at 6:35 AM Daniel Cederman<cederman at gaisler.com> wrote:
>>> Uses the first entry in the /memory node to determine the end of the
>>> work area. Falls back on linker symbol if unable to parse the node.
>>> bsps/riscv/shared/start/bspgetworkarea.c | 144 +++++++++++++++++++++++
>>> spec/build/bsps/riscv/riscv/obj.yml | 1 +
>>> 2 files changed, 145 insertions(+)
>>> create mode 100644 bsps/riscv/shared/start/bspgetworkarea.c
>>> diff --git a/bsps/riscv/shared/start/bspgetworkarea.c b/bsps/riscv/shared/start/bspgetworkarea.c
>>> new file mode 100644
>>> index 0000000000..1fa051d25e
>>> --- /dev/null
>>> +++ b/bsps/riscv/shared/start/bspgetworkarea.c
>>> @@ -0,0 +1,144 @@
>>> +/* SPDX-License-Identifier: BSD-2-Clause */
>>> + * @file
>>> + * @brief BSP specific initialization support routines
>>> + * COPYRIGHT (c) 1989-2020.
>>> + * On-Line Applications Research Corporation (OAR).
>>> + * Cobham Gaisler AB.
>>> + * Redistribution and use in source and binary forms, with or without
>>> + * modification, are permitted provided that the following conditions
>>> + * are met:
>>> + * 1. Redistributions of source code must retain the above copyright
>>> + * notice, this list of conditions and the following disclaimer.
>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>> + * notice, this list of conditions and the following disclaimer in the
>>> + * documentation and/or other materials provided with the distribution.
>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>>> + * POSSIBILITY OF SUCH DAMAGE.
>>> +#include <bsp.h>
>>> +#include <bsp/fdt.h>
>>> +#include <rtems/sysinit.h>
>>> +#include <libfdt.h>
>>> + * These are provided by the linkcmds for ALL of the BSPs which use this file.
>>> +extern char WorkAreaBase[];
>>> +extern char RamEnd[];
>>> +static Memory_Area _Memory_Areas[ 1 ];
>>> +static const char memory_path[] = "/memory";
>>> +static void* get_end_of_memory_from_fdt(void)
>>> + const void *fdt;
>>> + const void *val;
>>> + int node;
>>> + int parent;
>>> + int ac;
>>> + int sc;
>>> + int len;
>>> + uintptr_t start;
>>> + uintptr_t size;
>>> + fdt = bsp_fdt_get();
>>> + node = fdt_path_offset_namelen(
>>> + fdt,
>>> + memory_path,
>>> + (int) sizeof(memory_path) - 1
>>> + if (node < 0) {
>>> + return NULL;
>>> + parent = fdt_parent_offset(fdt, node);
>>> + if (parent < 0) {
>>> + return NULL;
>>> + ac = fdt_address_cells(fdt, parent);
>>> + if (ac != 1 && ac != 2) {
>>> + return NULL;
>>> + sc = fdt_size_cells(fdt, parent);
>>> + if (sc != 1 && sc != 2) {
>>> + return NULL;
>>> + if (sc > ac) {
>>> + return NULL;
>>> + val = fdt_getprop(fdt, node, "reg", &len);
>>> + if (len < sc + ac) {
>>> + return NULL;
>>> + if (ac == 1) {
>>> + start = fdt32_to_cpu(((fdt32_t *)val)[0]);
>>> + size = fdt32_to_cpu(((fdt32_t *)val)[1]);
>>> + if (ac == 2) {
>>> + start = fdt64_to_cpu(((fdt64_t *)val)[0]);
>>> + if (sc == 1)
>>> + size = fdt32_to_cpu(((fdt32_t *)(val+8))[0]);
>>> + else
>>> + size = fdt64_to_cpu(((fdt64_t *)val)[1]);
>>> + return (void*) (start + size);
>>> +static void bsp_memory_initialize( void )
>>> + void *end;
>>> + /* get end of memory from the "/memory" node in the fdt */
>>> + end = get_end_of_memory_from_fdt();
>>> + if (end == 0) {
>>> + /* fall back to linker symbol if "/memory" node not found or invalid */
>>> + end = RamEnd;
>>> + _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
>>> +RTEMS_SYSINIT_ITEM(
>>> + bsp_memory_initialize,
>>> + RTEMS_SYSINIT_MEMORY,
>>> + RTEMS_SYSINIT_ORDER_MIDDLE
>>> +static const Memory_Information _Memory_Information =
>>> + MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
>>> +const Memory_Information *_Memory_Get( void )
>>> + return &_Memory_Information;
>>> diff --git a/spec/build/bsps/riscv/riscv/obj.yml b/spec/build/bsps/riscv/riscv/obj.yml
>>> index 5e767be1bb..b2eb467824 100644
>>> --- a/spec/build/bsps/riscv/riscv/obj.yml
>>> +++ b/spec/build/bsps/riscv/riscv/obj.yml
>>> @@ -29,6 +29,7 @@ source:
>>> - bsps/riscv/riscv/irq/irq.c
>>> - bsps/riscv/riscv/start/bsp_fatal_halt.c
>>> - bsps/riscv/riscv/start/bspstart.c
>>> +- bsps/riscv/shared/start/bspgetworkarea.c
>>> - bsps/shared/cache/nocache.c
>>> - bsps/shared/dev/btimer/btimer-cpucounter.c
>>> - bsps/shared/dev/getentropy/getentropy-cpucounter.c
>>> 2.34.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220818/1f76a92c/attachment.htm>
